Projects A New Deuce Project.....Chevy II style!
Discussion in 'The Hokey Ass Message Board' started by Roadsir, Sep 30, 2019.
  1. TerrytheK
    TerrytheK
    When I read your thoughts earlier in the thread about front end upgrades, I was going to suggest the Church Boys setup partly due to the ability to upgrade as desired. I used the CPP setup under mine and it made a huge improvement; much better driving car. But I have had a couple issues - for one, the ball joint boots were some sort of translucent rubber (?) material that split apart after less than 3000 miles so the ball joints will now be replaced. If I had it to do over again the CB setup would be the choice. But I'm not sure that was even available when I did mine, so....
    Just about anything you do to upgrade the strut arm front suspension on these cars I think is a good thing.
    So FWIW, as far as your parts purchase goes, I think you done good! :)
    Great job so far.
    Roadsir likes this.
  2. Roadsir
    Roadsir
    The floor pan was another marketplace purchase...I am going to run the original bench seat, but I'll keep the braces as they do help stiffen the floor pan. Thinking about a roll bar too:)
    Thanks, appreciate it! You still have your Chevy II?
  3. TerrytheK
    TerrytheK
    Yep, and still doggedly moving forward.... I think.... :rolleyes:
    Mission creep. :D
  4. Jalopy Joker
    Jalopy Joker
    for those contemplating similar changes should take a look at the latest issue of Hot Rod 20230203_170613.jpg magazine - pg 60 / Reengineered!
    Roadsir likes this.
  5. DDDenny
    Anything happening with your ChevyII?
    Roadsir and TerrytheK like this.
  6. TerrytheK
    TerrytheK
    X2. Yes, please keep us updated. Somebody's got to serve as a role model for us slackers. :D
    Dick Stevens likes this.
  7. Roadsir
    Roadsir
    Thanks for prodding me.....A few updates:
    I used a laser level to get the car straight and level while I finished up the toe boards, and finished the floor pan plug-welding, and seam across the back. I have a bit of work to fit the the sub-frame subframe connectors, and add some inner plates that would support and inner roll bar brace. I’ve got some plates coming in the mail.
    A lot of little holes appeared during blasting mainly where the seam sealer resided. Some of this could have been fixed with duraglass or panel adhesive but I have replaced the rear trunk panel and one brace, and the bottoms of the taillight housings, and a few other pin-holes in the rear pan.
    Next up a little patches in one wheelhouse, lower rear quarter,
    I hope to have all the body and all the panels done this month if possible.
    5DB81DFA-04BC-4480-859D-34CAAB7BF23E.jpeg 3F575373-75CE-4D23-A8B3-31FF551EA1FA.jpeg 423707A0-5290-4C31-B81A-F162DCCDFD62.jpeg 37763F6C-CCFD-4E59-BA96-6B0873CA3544.jpeg 522BA0AA-6FFB-4835-BEAE-087AA2AC57F5.jpeg 67E36241-913B-4A70-ABBA-B87D8955A096.jpeg BA8A7165-B7AE-4356-9549-417E1945CCAB.jpeg 060F9247-C462-475F-8054-BDB654FD7B71.jpeg
    willysguy, Tman, swade41 and 12 others like this.
  8. DDDenny
    Nice work, really was hoping you were making progress!
  9. Roadsir
    Roadsir
    slow and steady..., still on the hunt for a deal on a big cube small block with 525-550hp.
    TerrytheK likes this.
  10. AHotRod
    AHotRod
  11. Roadsir
    Roadsir
    Thanks, glad to hear you’ve had multiple good experiences with blue print. I’ll give them a look.
    I’ve been thinking about White Performance.
    https://whiteperformance.com/products-1/ols/products/550-hp-sbc-406-stroker-engine
    Papas32 likes this.
  12. TerrytheK
    TerrytheK
    Thanks for the update. Don't worry, we'll keep nagging. :D
    Noting that the White Performance engine description says it uses a factory style HEI distributor, you might double check that you have firewall clearance for that. Mine didn't - I'm using a small body distributor and even then it's kinda tight. Just a heads-up.
    BTW, damn you do nice work!
    Roadsir likes this.
  13. Roadsir
    Roadsir
    Still plugging away …. Literally haha, here’s
    progress pics on the 63 post.
    I used the USCT Motorsports sub rail and modified them by:
    Extended the front sides 3” so I could get two big plug welds into the front rails.
    Added 3/4”flanges so I could plug weld them to the floor pan for what I think will be a cleaner and a little stronger means, than a corner tack.
    Modified the drain hole in the floor to move it outboard of the sub rail. Also added sub-belt nut plate that is concealed by the sub rail.
    Capped or boxed the rear section so I can use that to pick up a future diagonal bar for an 8 point roll bar.
    Added a few threaded nuts for future crossmembers or exhaust mounting, and added at the rear.
    Heavy coat of zinc rich primer on the inside.
    Making some simple plates to mount some leaf spring sliders too.
    ] 0FD417D8-C44F-48F1-90D5-36E7FDC5BE20.jpeg E929AFF9-F349-4EBF-B8F1-A4607C5360EF.jpeg 78923758-378B-4906-A65F-F40B2285E8FE.jpeg 82A01A39-2573-45C7-BBF8-BE2864AB5849.jpeg D6BD375F-6328-4071-ABF5-95BE1C4BCA6C.jpeg FBC3FFCE-2DE1-46F9-82F6-5489A7A9B1E5.jpeg 9B15B55E-42D3-42E6-8CC6-C12E30D24023.jpeg
    brEad, swade41, AHotRod and 2 others like this.
  14. The 377 is easier to build today then they were when we were still building claimer motors. Big bore blocks are easy to come by and with an after market block you do not have to have bearing spacers or oddball inserts.
    A log time ago we put a DZ 302 in one, sub frame connectors, and 5 lug brakes. It was a hoot to drive.
  15. Roadsir
    Roadsir
    I had dz302 in a 33 Plymouth coupe that was a blast!
    I did some research on Blueprint as mentioned earlier… pretty impressive performance / value / warranty and they can get 454 cubes out their block 545hp 563 ft lbs of torque 10:1 !
  16. I had one in a '64 Malibu. They were a fun motor if you didn't mind high rev cruising. They used to be pretty easy to come by. Not so much any more.
    The nice thing about the Chevy II is that it does not take a lot of engine to push one. That and they are easy cars to build. Lots can be done with one without going stone exotic. Should be a fun project.
    brEad likes this.
  17. Roadsir
    Roadsir
    2C07B228-602C-4527-86A7-485AE4CCFBF7.jpeg 015639C0-89A6-4168-945A-83BD814DF572.jpeg E0750189-99D0-46E6-BAC8-B7CF5F316D07.jpeg 4005AACC-82E8-49C5-B0EF-77AF0484D2F5.jpeg Not too much to report other finished up a trunk pan install, have a quick performance 31 spl housing and axles, and I did pull the pin at GG in Des Moines and bought a Blueprint 427 small block 540hp/535tq min fully dressed small block. Most dyno 10-15 over that so I’m hoping for 550.
    Hope to have a 6pt or 8pt progress to share soon. 1-5/8 docal
    tomkelly88, brEad, swade41 and 4 others like this.
  18. AHotRod
    AHotRod
  19. DDDenny
    Again, outstanding work and photo documenting, too bad there isn't more Chevy II activity on the HAMB as this is pretty valuable tech, especially to those that are new to modding these cars, unibody cars require a bit different approach compared to framed cars.
    Fun stuff, keep posting!
    slug, SS327, brEad and 1 other person like this.
  20. Roadsir
    Roadsir
    Still plugging away( literally) . I made some plates for the cage mounts and plug welded them in places, and then had Innovative Metalworks bend the tubes and tig up a 6pt roll bar. He asked me how bad I wanted the armrests and that was a must have so made it work. I really like how it came out! I borrowed a rotisserie to finish up some work on the underside.
    7DEAB048-99B2-42E7-9AD9-105940BCE319.jpeg 6F413452-8214-4DAC-9480-F55EEE7565D7.jpeg F4DFC743-EF9D-4AB4-ADFF-5B563D1908B8.jpeg 2D3825A0-940D-4218-9062-E90AFA397543.jpeg D6CC8C3C-3479-4BB3-8B4D-CAFE0ED4A33C.jpeg F0D1A787-3BFE-47A4-AE8B-726BB8BAD320.jpeg C23C82F4-A0CF-46F2-B30E-09FE2FE242BB.jpeg 2B26A804-F134-4CA0-896B-016ACEB30429.jpeg C60F914F-1775-4248-83F5-838B331C0A64.jpeg F20CEC95-04D3-46E7-B999-1E192C833008.jpeg DF691359-267D-4AB8-8721-C35518E484A1.jpeg
    40FORDPU, brEad, Shadow Creek and 2 others like this.
  21. squirrel
    I didn't know you could make the cross bar removeable....????
  22. Roadsir
    Roadsir
    You're right and that was my choice, I don't think it will cert., but most the places I'll be running won't be NHRA.
    If the car dips into the 10's and I get warned I may need to change it....
    slug likes this.
  23. DDDenny
    Same with mine, first thing people said here was my door bars(fixed) were not high enough to pass tech and I said I doubt there will be any tech at Safeway.
    Besides, I too wanted to keep my stock front door armrests.
    Looking good Roadsir, can we expect more Chevy II reports from you?
    brEad, slug and SS327 like this.
  24. Roadsir
    Roadsir
    Thanks Denny, yeah same with these door bars. … I’ll keep the posts coming!
    brEad, slug and Papas32 like this.
  25. Roadsir
    Roadsir
    Happy new year again…. A few updates on the Chevy II. I did have washers machined to to replace the front spring eye cups, and I tied the spring mount to the sub rail.
    Also did a lot of minor work to the doors, fenders, and hood. The paint and body guy should be ready next week!
    I have the 427 small block from blueprint. 541hp/541tq., I need to get the TKX, and figure out which 3rd member ratio????
    C9C9893F-7730-457D-BAEC-F95FA569A14B.jpeg 6567F74A-9663-4E13-B682-3FB85C776B48.jpeg C8E0B00E-85FA-42D5-8E91-BFE789DAF4DD.jpeg 90D3E533-A9AF-4FE7-82AA-37EC373A0505.jpeg 30683903-0ADC-4227-8CE0-E3D355C6F7BF.jpeg
    brEad, Shadow Creek, Magfiend and 6 others like this.
  26. slug
    slug
  27. DDDenny
    Yes, neat pickup too.
  28. Roadsir
    Roadsir
    Thanks Denny, it's a 72 67K mile truck from Wyoming, 6cyl 4 speed, 16" wheels. Super, rust free but has some major hail damage.
    Magfiend likes this.
  29. Roadsir
    Roadsir
    Getting close to having some color. Dash and cage will be original dark turquoise, interior trim turquoise like original. Underside will be red oxide, and outside Ermine white.
    Resized_20240222_092429.jpeg Resized_20240222_093236.jpeg Resized_20240222_114721.jpeg Resized_20240222_114713.jpeg Resized_20240222_105915.jpeg Resized_20240222_092429.jpeg Resized_20240222_093236.jpeg Resized_20240222_114721.jpeg Resized_20240222_114713.jpeg Resized_20240222_105915.jpeg
  30. squirrel
    nice!
    but you forgot to move the rear floor forward?
