Projects The Flathead Flathead
Discussion in 'Traditional Hot Rods' started by Jeff34, Aug 30, 2021.
  1. Jeff34
    Jeff34
    Yup. Ordered the material yesterday. Hopefully get to them this week, but work keeps draggin me away.
  2. Jeff34
    Jeff34
    Thanks to @J.Ukrop, I’ve get a rear spring pack. Just need to source a reverse eye main leaf and buy some spring over mounts and I’ll have a complete rear end. Also took the plunge and cut the back of the frame to step it. Hope to get that tacked in later today. F43F5BBA-E9C8-4E6F-B9F5-D18F347A5014.jpeg 58DB545B-98A4-4B7E-A904-5A4EF347D507.jpeg
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Great hanging out and seeing your progress. Can't wait to see how it sits with the reverse-eye spring and the kick-up in the frame.
    JalopyJimbo and Outback like this.
  4. Jeff34
    Jeff34
    Thanks, Joey! I got it cut and gussets made, and started welding today. Unfortunately, my welding hood decided to **** out on me. Got flashed twice. I knew it was getting old. Ordered a new hood today so I can keep welding. I think I may have another hood (cheap brand) in the garage.
  5. Jeff34
    Jeff34
    Back in business! New helmet with headlight works great!
    OpenThrottle and Outback like this.
  6. atch
    atch
    Holy cow. I really liked this helmet 'til I looked it up and saw the price.
    I know; I've only got one set of eyes, but I'm 71 years old and have gotten along nicely all these years without spending this much. I doubt I'll be welding that much longer enough to justify that expenditure. Good for you though. I'm happy to see that you are being proactive with your eyes.
    Was the light an ESAB option or did you get it elsewhere? In my searches I've never seen one like that. I like it.
    Outback likes this.
  7. Jeff34
    Jeff34
    I just got the light at a local hardware store. I like it because the clip let me attach it to the back of the helmet and point it forward. Then I bent the clip until the beam from the light points right at the puddle.
    Jim the Sweep and JalopyJimbo like this.
  8. Jeff34
    Jeff34
    Cut the cross member out and put in the ‘40 “X” member. Lines up pretty good. Still need to figure out how to finesse the X member to work best. Also found some cracks on the front cross member I need to weld up. Progress is better than Congress (hehe)
    Cheers! 721F0449-15D0-456E-9DAE-79D136814FE8.jpeg 746CCD2D-3684-43ED-9975-5A1CDE485500.jpeg F6552713-02C3-4B94-BFD7-9D15CDDE1094.jpeg
  9. Jeff34
    Jeff34
    And the garage is a complete disaster. This week is cleaning week
    Crusty Chevy likes this.
  10. Jeff34
    Jeff34
    Thanks to a buddy, my bushings were machined to work with the old shackles. They’re flat now, but when the Flathead is in I expect them to be correct. Question: grease fittings face foreword or back? AD9779FC-8E31-44AD-BEB6-3C5E306AE9BA.jpeg D7AC1B81-8525-4EF9-B0F0-AEBDCEADEB24.jpeg
    JalopyJimbo and OpenThrottle like this.
  11. Outback
    Outback
    from NE Vic, Oz
    I would put them facing back to protect from road grime/debris. Though would be easier to get to from the front...?
    SS327 likes this.
  12. Jeff34
    Jeff34
    D8D0B57E-5011-46F4-B9AA-C91686564E5D.jpeg 9D016D02-2DDF-4537-B8F1-B8326D278A6D.jpeg 5D0A3F3D-179F-4B16-9444-F4AC044EB3A6.jpeg More mock up of the front end today. Got the tie rod dropped, shortened, and in. Drag link and steering box location still need work. Also got the Tardel wheel spacers welded to the rear wheels so I can install the rear end after I get new shackles Monday.
  13. Jeff34
    Jeff34
    03379099-5231-4C12-BBF1-DD551497F64E.jpeg DD487E17-6166-4B87-B382-B2E005650873.jpeg Got my shackles yesterday and ***embled the rear spring today. M***ive respect for table saws, angle grinders, and model A rear springs. Seems like a m***ive amount of potential energy in these when compressed. Unbelievable that a 3/8” bolt can retain all that energy. I’m pretty sure that I’ll need to remove leaves and possibly reverse the eyes, but it’s good for now to get the ch***is parts aligned.
    Vic Walter and OpenThrottle like this.
  14. Jeff34
    Jeff34
    Wasn’t happy with the height or stiffness of the rear pack so I removed some leaves. Then I rolled the rear end under the ch***is. Body goes back on today to see where I stand. Not sure if the ‘40 X member is the right way to go but I’m still going to try my best. IMG_2964.jpeg
  15. Hitchhiker
    Hitchhiker
    Looks great! Personally I think the 40 x member is great. It will really stiffen the ch***is up.
    Outback likes this.
  16. AmishMike
    AmishMike
    Looking good. Tie rod & drag link look parallel with frame, have you checked Ackermann steering angle?
    Outback likes this.
  17. Jeff34
    Jeff34
    @AmishMike The drag link is not connected to the steering box. It’s only connected to the p***enger steering arm. Trying to make the drag link and tie rod as parallel as possible. Planning to add a panhard bar as well. Does that answer the question? IMG_2965.jpeg
    AmishMike likes this.
  18. roseville carl
    roseville carl
    coming along nicely......
  19. Jeff34
    Jeff34
    IMG_2966.jpeg image.jpg Set the Engine in to see where we stand. Back of the car is about 2” higher than it will be because I haven’t trimmed the sub for the step in the frame. I need to rethink my accessories on the front of the engine. It’s too far forward. Or I need to move the radiator forward or trim the firewall. Not sure what to do.
  20. OpenThrottle
    OpenThrottle
    from So Cal
    Looking real good, I’m sure you are aware that on your rear spring pack you need to run spring clamps on both side, helps with all that energy held down with that puny bolt ✌️great job. Following
    Jeff34 likes this.
  21. j ripper
    j ripper
    from napa ca.
    Nice progress! I would address your subrails now and get that body bolted down where it wants to live and fit your engine and transmission where it wants to live then that will dictate your center crossmember. That later engine is doing you zero favors in the room department unfortunately. You can definitely eliminate some things on the front of that engine to gain some room, but it will definitely still be tight in there.
    Jeff34 likes this.
  22. Hitchhiker
    Hitchhiker
    I'd run 59ab style pumps and early single groove crank pulley and a fan mounted on the generator snout like a 32-36. That should get you all the space you need. You might have to swap to an early distributor too.
    Outback likes this.
  23. j ripper
    j ripper
    from napa ca.
    Or just harvest the current rotating ***embly and install into an earlier block and be done!
    Hitchhiker likes this.
  24. Jeff34
    Jeff34
    Looked back on Aaron’s ‘29 AV8 build and realized he had the same issues. Plan to do the same and place the generator over the head. That will allow me to use one belt for everything and cut down on the length of the engine. Hoping to get on that soon.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So exciting to see the body on the frame!
    Jeff34 likes this.
  26. Jeff34
    Jeff34
    coming back off today. Now that I have a plan for the ch***is, I can make more progress!
    Moving sloe because of “work”. Yes, I said Sloe
    Outback likes this.
  27. Outback
    Outback
    from NE Vic, Oz
    Excuse my ignorance, how are the 59ab pumps different?
  28. Hitchhiker
    Hitchhiker
    The pulley is much closer to the engine block. You gain several inches with the swap.
    Jeff34 and Outback like this.
  29. Tim
    Tim
    from KCMO
    Lookin good
  30. Jeff34
    Jeff34
    But I believe that if you use the 59AB pumps, you need to use a chevy distributor to move it up and out of the path of the drive belt, right?
