Technical 1947 Fleetmaster
Discussion in 'Traditional Hot Rods' started by 61dart, Apr 24, 2023.
  1. 61dart
    61dart
    Hey guys picked up a super nice ‘47 fleetmaster running project. this weekend. Guy before me had put in a power dual master cylinder but didn’t hook up any lines. Some what new to dual masters, it has 4 spots to run lines, still running the stock drums on the car. Am I able to just use two of the holes for front and back brakes (one front bowl,one back bowl) and block off the other two?
    thanks.
    Okie Pete and hillbilly like this.
  2. skooch
    skooch
  3. Daddy_O
    Daddy_O
    Good for you! It appears your '47 has a '46 grill.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    hillbilly likes this.
  5. BJR
    BJR
    Front port (the one farthest from the push rod) on master goes to the rear brakes, rear port (closest to the brake pedal) goes to front brakes.
    Okie Pete likes this.
  6. 61dart
    61dart
    Okay, awesome that was my next question about the ports. I figured it was opposite of a firewall mount just wanted to make sure. Also interesting to know about the grill, it is ***led and vin verified as a 47 so interesting. Pretty excited about the car, paint could use some love but looks decent from 20ft. Got a smoking deal, for the fact I traded my '78 Monza straight up for it and it needed a TON of work.
  7. Bob Lowry
    Bob Lowry
    Fun coupe...here was my '46.....keep us up to date on your progress...easy to put disc brakes on the front
    if you decide, bolt on kit....
    Okie Pete and 1952henry like this.
  8. sdluck
    sdluck
    Is the master cylinder same size on both?
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I want to know if it’s a manual drum (both reservoirs the same) or a disk drum Chevy or Ford. They swapped ends as to which end get’s to big reservoir.
  10. 61dart
    61dart
    So had about 20 mins to crawl under the car tonight with flag football and gymnastics. So I believe this is the kit I have right here. I was absolutely baffled about how the clutch hooks up but as I am typing this it’s hitting me after reading the website the original master sits top of this mount as there was plenty of room. Please advise me if I am wrong. 652FEEA2-5ACB-4071-9AD9-CF9D0A14D196.jpeg 652FEEA2-5ACB-4071-9AD9-CF9D0A14D196.jpeg
  11. 61dart
    61dart
    Never mind as I crawl under again there is no room. So I am stumped to how the clutch hooks up, as there is no other pivot arms.
  12. 24riverview
    24riverview
    This is stock, if you have the stock fork and related pieces it can be made to work with later chevy drivetrain.
