Vintage Aircraft Safety Wiring
Discussion in 'The Antiquated' started by Crookshanks, Apr 25, 2023.
  1. Crookshanks
    Crookshanks
    Had a chance to get up close to the biplanes while parked at Flabob TROG. Really geeked out on the safety wire techniques and badging. Thought I’d share.
  2. aircap
    aircap
    Safety wiring is an art unto itself.
  3. lothiandon1940
    lothiandon1940
    It's a beautiful thing when done right.
    VANDENPLAS, Deuces, old chevy and 7 others like this.
  4. Budget36
    Budget36
    I bought a pair of HF safety wire pliers on a whim once when in the store. They actually work pretty well. I only used them 3 or 4 times, no idea if they’d last through a lot of use or not.
  5. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Ah, yes... Nothing like cutting/removing/re-saftieing all the boroscope plugs and EGT probes on a CF6-80.after Inspection. Oh. the first example I would have rejected. Twisted too tight. Pic for reference. 11082341_804805182943403_2083143237267945976_o.jpg
  6. bobss396
    bobss396
    We had a lady at work that did the best safety wire work I have ever seen. She did the EA-6B Band-1 ***embly-transmitter ***embly which was loaded with safety wire.
  7. brady1929
    brady1929
    Ah Hemiman 426. I know who you work for. Ha ha ha. I work in the Phoenix hangar in out of service.
  8. alanp561
    alanp561
    General Wiring Procedures
    Procedures for installing safety wire include the following (with quotations from AC 43.13):
    1. Safety wire must be new upon each application. (This seems fairly obvious until you catch yourself trying to redo a short run using the same wire.)
    2. All safety wires “must be tight after installation, but not under such tension that normal handling or vibration will break the wire.”
    3. Twists should be “tight and even, and the wire between nuts as taut as possible without over-twisting.” (Six to eight turns per inch.)
    4. A “pigtail” of 1/4- to 1/2-inch (three to six twists) should be made at the end of the wire run. This pigtail “must be bent back or under to prevent it from becoming a snag.”
    5. When castle nuts are safetied, “tighten the nut to the low side of the selected torque range, unless otherwise specified, and if necessary, continue tightening until a slot aligns with the hole.”
    6. The wire must be applied “so that all pull exerted by the wire tends to tighten the nut.”
    7. The wire should always “be installed and twisted so that the loop around the (bolt) head stays down and does not tend to come up causing a slack loop.”
  9. dana barlow
    dana barlow
    from Miami Fla.
    Beside being safe,if done right, I also thought it looked cool. My Dad showed me how in the 1950s,in WW2 he worked on XP77 for Navy & Bell. Used it on my hotrod a little too,in the 1960s.
    Some of my race car buddys called me Spider, a**** other things:p ,do to all the safety wire on my race cars.:D
  10. Budget36
    Budget36
    Okay, truth is out. YOU started the RR webbing thing;)
    dana barlow likes this.
  11. if i remember correctly, dont model a flywheels use a "safety wire" technique on the bolts?
  12. 41 GMC K-18
    41 GMC K-18
    Engine badges and information of various components have always been cool.
    When is the last time, you saw a 3 banger radial engine, with duel, "EDISON-SPLITDORF" magnetos.
    IMG_1571 (2).JPG IMG_1576 (2).JPG IMG_1638 (2).JPG IMG_1549 (2).JPG IMG_1551 (2).JPG
  13. Super Streak
    Super Streak
    from Florida
    Years ago, I worked with an older gentleman who had been a B17 mechanic during the second world war. He would safety wire by hand and never used wire pliers to twist it until the end. It always came out tight and beautiful with no nicks or s****es.
    Deuces, dmar836, bobss396 and 5 others like this.
  14. Budget36
    Budget36
    May have. Been awhile since I was into a early V8, but seem to recall safety wire on the flywheel bolts? I think the rod cap nuts too?
    The_Cat_Of_Ages likes this.
  15. alanp561
    alanp561
    lothiandon1940 and 41 GMC K-18 like this.
  16. 41 GMC K-18
    41 GMC K-18
    No, this is not a rotary, it has a standard mounting just like other radials from that time period.
    chryslerfan55 and lothiandon1940 like this.
  17. dana barlow
    dana barlow
    from Miami Fla.
    LOL,,:p ,I really hate rat carp. But love toy trains{RR}the only RR I like.
  18. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Retired in 2018. 32 1/2 years of fun.
  19. woodiewagon46
    woodiewagon46
    from New York
    It's one of those things that if done right, it's beautiful, but done wrong sicks out like a sore thumb. Even with the safety wire tool, I can't make it look good.
    chryslerfan55 and Crookshanks like this.
  20. Nacifan
    Nacifan
    How about a few more pictures of Safety Wire done right ?? (please)
  21. alanp561
    alanp561
    If you look at the examples shown, you will see that the wire is designed to keep the fastener from loosening and coming out of the hole or nut. For left handed threads, these illustrations would be reversed.
  22. Roothawg
    Roothawg
  23. gus gustafson
    gus gustafson
    Worked as a A&P in A/C engine overhaul shop in 1960's , never used safety wire pliers , to bulky between jugs (cylinders) here's my 1960s Snap On , learned to rotate (twist) these light weight plies in your palms of your hands .
  24. oj
    oj
    Is there a proper wire gauge for safety wiring? I've been using stainless steel wire and when I get it looking right and give the pliers another little tug to tighten it up the wire breaks and I have to start over. Am I using too light a wire?
    lothiandon1940 and hrm2k like this.
  25. Roothawg
    Roothawg
    Depends on the application. They make .020-.081 . For most applications .032 is sufficient. .051 is what you see on props etc. it’s harder to twist but it’s like a wire rope when you are done.
    You should have 7-10 twists per inch. There’s a book out there used by a lot of aviation folks called the 43.13-1B. It has a lot of good info in it that cross over to hot rods. You can access it online for free.
  26. fur biscuit
    fur biscuit
    43.13-1B
    bless the HAMB.
    chryslerfan55 and Roothawg like this.
  27. Ziggster
    Ziggster
    Yep. In the end stages of ****oning up my C59A Ford flathead. There is also a safety wire used on the sump oil pump pressure relief valve nut and the bolt that mounts the pump to the block.
  28. oj
    oj
    Thanks Rootie, I just googled and found it, I believe I have a hardbound copy of it, very old, that is where I learned the proper methods, tools, calculation etc to rivet. I had forgotten all about that book, I'll go look for it this evening.
    Thanks again. Oj
  29. alanp561
    alanp561
    FAR 43.13-1B. The Federal Acquisition Regulations. @Roothawg has it right. Lot of useful stuff to know.
  30. alanp561
    alanp561
    Okie Pete, Toms Dogs, Tman and 4 others like this.
