Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. Lloyd's paint & glass
    It's 3/8" all the way to the carburetor. No damage that I'm aware of though
  2. Lloyd's paint & glass
    As long as it's 36⁰ all in, isn't that all that matters? It starts fine the way it is.
    enloe and 427 sleeper like this.
  3. Budget36
    Budget36
    So, I’m confused a bit (by wording) but anyways, “15 initial and 35 total” the “dropped “ -I think you mean “upped” to 36? the initial is at 21? If it was me I’d pull the distributor and do some polishing/spring inspection, etc. look at where the weights ride, etc. seems like something is hanging up. I’d expect 1 more degree total to be 1 more degree initial.
  4. Lloyd's paint & glass
    The other day I set the timing at 15 initial, had 35 total. Dealt with the carburetor jelly and raised the timing to 40 total. Today I put it back at 36 total, adjusted my light to find initial and it's at 21. So right now it's 21 initial, and at 3000 rpm it's at 36. So it's only advancing 15⁰. But, the way I see it, the total number is my concern, right?
  5. Budget36
    Budget36
    Yes, but the times I’ve done it to get total, initial changed the same amount at total did.
    That was made me ask and thought it was strange.
    Edit: as you have heard before…9 of 10 fuel problems are ignition, 9 of 10 ignition problems are fuel.
  6. 427 sleeper
    427 sleeper
    Exactly!
    Are you running an amplifier box? That can fuck up the timing reading's with newer timing lights.
  7. Lloyd's paint & glass
    No sir
    enloe likes this.
  8. 427 sleeper
    427 sleeper
    I vote for the Delco points distributor. Simple as hell... NO Wizardry! :D
    alanp561, Bob Lowry, enloe and 3 others like this.
  9. lumpy 63
    lumpy 63
    Your advance weights are hanging up Lloyd.
  10. Lloyd's paint & glass
    I checked it all before I put it in, but I'll check it. It's aggravating lol
  11. Dick Stevens
    Dick Stevens
    Putting in the distributor that @Moriarity sent you will fix that problem!
  12. Lloyd's paint & glass
    Yeah that's my plan. Process of elimination lol
    enloe likes this.
  13. gene-koning
    gene-koning
    If you originally had 21 degrees of advance but now you only have 15 degrees, something in your spark advance isn't functioning correctly. The degrees of advance is not dependent on what the initial timing is set at, it is dependent on the advance weights movement and any vacuum advance the distributor has. Either advance process could cause an inconsistent number of advancement degrees.
    If the motor is seeing the full 21 degrees of advance at say 3,000 rpm, but the advance drops to 15 degrees at 5500 rpm, the motor is seeing an actual retard in the timing. When you let off the gas, if it gets those extra 6 degrees advance back, the motor will come back and will act like there was a lack of fuel.
    I also do not see a motor of this CI consuming the amount of fuel a 3/8" line can provide but 5500 rpm is running that $19 fuel pump pretty fast, maybe it can't keep up. I believe the loss of timing advance is your issue and would eliminate that possibility first.
    Then again I must point out that one time one of our dirt track cars experienced a loss of fuel delivery at higher rpm. What we found was that the hot exhaust was being trapped near a 3/8" fuel line and the heat was effecting the fuel delivery. Rerouting the fuel line solved that problem. Might be worth looking at your exhaust and your fuel line and be sure your not cooking the fuel in the gas line someplace under the ride. Its a long shot that can be easily eliminated.
  14. Lloyd's paint & glass
    Thanks for the info Gene. I'm gonna isolate the ignition system next. The way I plumbed the fuel line I'm positive its nowhere close to any heat. Once I sort out the ignition, if the problem still exists, I guess I'll go to the pump.
    enloe likes this.
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    The 600 Holley would have plenty cfm to feed a 283 at 5500 rpm, The distributer advance seems to be sticking on you so clean and check for smooth full movement of the distributor weights, Then I would check to see if it repeats the timing curve a few times with the help of someone one running the gas pedal while watching the tach for you to check the timing at idle and 1000 rpm then 2000 rpm and see if it's all in 36 degrees by 3000 rpm, write down the results at each rpm an check if you get the same results again, ;) if not something on the weights is rubbing or binding, might find it by looking for witness marks on weights or the bottom of rotor.
    Worked on a poochy 429 ford that would not spin a tire after a new 4-barrel Holley and ProForm's new HEI GM type distributor for fords?
    The owner thought it was carburetor problems but after checking the timing curve we found only 10-degree total movement, after a couple of dissembles we found a witness mark on the bottom of the rotor, filed enough plastic so it wouldn't rub the bottom and then installed a light spring kit, rechecked and now we had 22 degree total movement
    That motor turned into a tire peeling animal with a smiley faced owner :):D:D:D
    alanp561, enloe, rod1 and 3 others like this.
  16. LWEL9226
    LWEL9226
    from So. Oregon
    Several years ago I had an off topic F250 with a 4776 Holley on a 410FE that would run out of fuel on a hard pull....
    Turned out I had gone through the carb and some how the needle and seat I used was causing a restriction.... Changed that out and the problem went away.....
    LynnW
  17. SS327
    SS327
    Lloyd think of it this way. It’s a hot summer day and that ice cold Miller Lite is 12’ away from you and you want it bad, very bad! But the only way to get it is to suck it through a straw while you sit in the seat of a rocket sled with the beer behind you. You start sucking on the straw to get that delicious golden brew but you’re accelerating faster and faster! As you suck inertia is working against you to pull that icy goodness back to the bottle.
    The same thing is happening to the fuel in the line 2 opposing forces working against each other. Put an electric pump at the tank and don’t look back. It’s easier to push fuel with pressure than suck it with vacuum.
    enloe, Budget36, LWEL9226 and 2 others like this.
  18. Lloyd's paint & glass
    Changed the distributor out, got it running, set the timing, and it started raining. Straightened up the plug wires and the some other wires under the hood, and decided i wasn't going out in the rain lol. So here i am! It's at 15⁰ initial and 36 total without the vacuum advance hooked up. We'll see how it does when it isn't raining. Getting ready to go to the fireman's dinner. Y'all be good
    Bob Lowry, enloe, SS327 and 5 others like this.
  19. Budget36
    Budget36
    I don’t know if what you say is right, etc, but damn I enjoyed reading it!
  20. Lloyd's paint & glass
    Hey at least the sending unit is at the rear now, so it's not fighting to pull fuel under acceleration lol. Now I want a beer...
    enloe, SS327, 427 sleeper and 3 others like this.
  21. Lloyd's paint & glass
    Well I'm proud to say it's not a fuel delivery issue. Took it out today and it ran like a raped ape! Well, for what it is lol. No cutting out, spins to 5 grand without a hiccup. Feel much better about it now. 20230506_182758.jpg
  22. Budget36
    Budget36
    Soooo, what did you do to cure it?
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    did you put the points dist that I sent you in it???
    427 sleeper and guthriesmith like this.
  24. Lloyd's paint & glass
    Changed the ignition system. When I pulled the rotor on the other distributor, the holes in the weights were oval and the pins were wore down. So I just pulled it. Yeah Mark i put your distributor in it, and pulled it back out when I realized that I have 6 sets of plug wires, and none are for the points cap. So I put the aftermarket distributor in it that I had wires for.
  25. 51504bat
    51504bat
    Why didn't you just go to the kitchen cabinet with your plug wires and get a new set? Oops, not everyone has a kitchen cabinet full of plug wires like @Moriarity.:cool:
    alanp561, SS327, 427 sleeper and 6 others like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    D2B9CBC6-7432-4ABA-826C-478470FFFA78.jpeg B26B29E2-E883-43C7-8CCC-CB3CFE96ACC7.jpeg
    Bob Lowry, SS327, LOST ANGEL and 6 others like this.
  27. Budget36
    Budget36
    SS327, 427 sleeper, belair and 2 others like this.
  28. Lloyd's paint & glass
    Me too man. Only set they had here in my little town was the $19 junk. So I went the other route. I'll use the points setup in the big block
    enloe, guthriesmith and Budget36 like this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
  30. Budget36
    Budget36
