Vintage Aircraft Safety Wiring
Discussion in 'The Antiquated' started by Crookshanks, Apr 25, 2023.
  1. Cleaner, works better, I am sold ;)
    XXL__ and hrm2k like this.
  2. warbird1
    warbird1
    Guess I'm just old... never used any of this stuff. And only one aircraft I ever worked on used clips on the turnbuckles, rest were all safety wire.
    dmar836 likes this.
  3. I still have my safety wire pliers
  4. krylon32
    krylon32
    from Nebraska
    I was told to safety wire the knockoffs on my pin drive wheels. I didn't and just got out the lead hammer every time I stopped for gas. Never lost a wheel. Doesn't the theory that the wing nuts get tighter as the car goes forward apply? Sold the wheels.
    bobss396 likes this.
  5. Harv
    Harv
    from Sydney
    Curious… what component is this?
    I think I’m seeing lead seals to prevent tampering… still remember when mail bags and taxi meters were lead-sealed.
    Cheers,
    Harv
  6. dmar836
    dmar836
    I’ve never seen safety cable before. I’m sure it works but...
  7. bobss396
    bobss396
    We had one bomb rack at work, this one was loaded to the gills with safety wire. The inspectors went over each one and had to be told not to look at anything too close, a 6X loupe was fine. Big things were nicked wire and tails not finished properly.
  8. metlmunchr
    metlmunchr
    Somewhat OT, but a good demonstration of the importance of doing stuff right on any fastener locking devices.
    Niece's husband takes her '18 Toyota Sienna minivan to a guy he knows this past week to get an oil change and have him check the front hubs as he thinks he's hearing a bearing noise on the RF. Happens to mention that lately the engine seems to speed up for a couple seconds every once in a while as they're driving along. At that point, the shop owner says Whoa. No need to spend a cent on this thing until that's resolved. Car has over 100K miles so its well out of warranty.
    This guy doesn't do transmission work, but he says he's heard there's a recall for this very symptom on certain Toyotas that covers 2 or 3 years. Says it involves a lock tab washer on a nut in the trans that isn't bent up far enough to keep the nut locked in place. The nut backs off over time and once its loose enough to cause problems, the solution is to replace the trans. Says this is just what he's heard and doesn't know any details of whether its covered past the warranty or not, but he wouldn't recommend even spending the price of an oil change on the car until they know for sure as a trans replacement would be $$thousands so he might just want to dump the car while its just happening now and then rather than all the time.
    So he goes home and calls some number for Toyota. Gives them the VIN and symptoms and sure enough its covered regardless of mileage. To Toyota's credit, they're extending the trans warranty for 10 yrs from date of manufacture regardless of mileage.
    Although its not a life threatening situation, someone not paying attention to a 2 cent part and a 5 second operation will ultimately cost Toyota $millions.
    VANDENPLAS likes this.
  9. There hasn't been much comment on the engine manufacturer's name tags, but those enameled examples are works of art!
    41 GMC K-18 likes this.
  10. 41 GMC K-18
    41 GMC K-18
  11. CSPIDY
    CSPIDY
    Nothing like pushing safety wire through one side of your finger and out the other
    Ouch
  12. Splitbudaba
    Splitbudaba
    Fifty years fixing aircraft, guess who's car has aviation touches. Here's one. See pic PXL_20230106_175513688.jpg
  13. CSPIDY
    CSPIDY
    And how many times I caught my finger on cotter pin ends
    Brutal
    Splitbudaba and 41 GMC K-18 like this.
  14. 1930artdeco
    1930artdeco
    from Lynden, Wa
    I had to safety wire in the Air Force and I was OK at it-looked like **** but was functional. It was always something that I tried to improve upon though. Thanks for the page on the lacing of wires, I am going to try that on my car when everything gets tightened down and ready to be ****oned up.
  15. Harv
    Harv
    from Sydney
    Is there a “correct” way to finish split pins?
    I trim the split pin legs to a suitable length with dry yes, then bend both split pin legs back and tap them down to flush with a hammer. Dad always cut one leg off, then bent the remaining leg around.
    Makes me smile every time I pull something apart with one leg off, knowing he ***embled it last.
    cheers,
    Harv
    41 GMC K-18 and down-the-road like this.
  16. CSPIDY
    CSPIDY
    @Harv, with cotter (split pins) from what I’v seen in my time
    function is the right way
    I have seen nails used and they did the job
    that being said
    If the pin is slid in so the ends can be curled back into the nut instead of back over the end of the bolt, that would be better in my mind.
    I spent my youth working for/with my dad and understand seeing his work since he’s gone
    down-the-road and 41 GMC K-18 like this.
  17. Harv
    Harv
    from Sydney
    I’ve never seen the ends tucked back into the castellations before… that is very neat. I’ll be doing mine like that from now on.
    cheers,
    Harv
    CSPIDY likes this.
