Projects my first project thread, 52 Desoto
Discussion in 'The Hokey Ass Message Board' started by BRAINS!, Jun 2, 2013.
  1. BJR
    BJR
    If you have a factory shop manual it will show how to adjust the steering gear. I have never seen one that you couldn't adjust. Was that flipper on the front cover a timing chain tensioner?
  2. BRAINS!
    BRAINS!
    I am not sure what the purpose of the flipper was. Still haven’t figured that out. The 57 cover didn’t have it so I’m guessing it’ll be fine. I’m anxious to see how the steering is with the p/s finally working
  3. BRAINS!
    BRAINS!
    I am almost finished. Should be done tomorrow and everything will come together. Just have to get some new belts that fit and install the power steering hoses. I can’t use the bottom half of the fan shroud anymore bc the 57 pump sits slightly lower and it rubs but it should be fine. E226CCA0-D839-42FA-8F36-ED2D5720CAD6.jpeg 7A1566FA-0136-460C-ACB5-993F4ACD5F4B.jpeg
  4. BRAINS!
    BRAINS!
    It says on the pump use mopar type A oil for the ps fluid. I can’t find a clear answer online. Is it just motor oil?
  5. George
    George
    My understanding is it is Type A ****** fluid, now obsolete, there is a modern fluid called A but not the same.
  6. BRAINS!
    BRAINS!
    I ended up just throwing some dex Merc ****** fluid in and it. It is amazing to finally have working p/s
    junkers72 and SS327 like this.
  7. BRAINS!
    BRAINS!
    I got new window seals for the side windows. I am wondering if and what kind of glue I need to use?
  8. BRAINS!
    BRAINS!
    So I picked up a true 345(S26 A) casting # and am wondering if the tall deck will fit in my 52 sportsman, cant find much info about it. Anyone have any ideas, thoughts?
  9. 73RR
    73RR
    ...one for one interchange as complete units. Minor differences with exhaust pipe and such. The 'flipper' was to control t-chain flopping around when it stretches. Major score on the Edelbrock by the way.
  10. BRAINS!
    BRAINS!
    I ruined the threads on the high pressure power steering fitting that threads into the box and the fitting is seemingly impossible to find. Tried the hydraulic shop, eBay, internet, French lake auto parts. Anybody have any idea where I might be able to find this fitting or know of a junkyard that may have some 51-54 Chrysler products
  11. gatz
    gatz
  12. George
    George
    Big M in California, it Googles.
  13. BRAINS!
    BRAINS!
    Thanks for the info
