Technical What is this hole for? SBC 350
Discussion in 'The Hokey Ass Message Board' started by NewToMeT, Apr 30, 2023.
  1. NewToMeT
    NewToMeT
    Hi guys. Am completing a 350 swap for a beat 283 in my inherited t bucket. Just noticed these holes on the block as I ****on up the new block. Looking at The 283 it had them as well left open.
    just wondering what would go here. ***uming it’s ok to leave as is as the original was as well, but just in case wanted to check.
    Thanks!
  2. AngleDrive
    AngleDrive
    from Florida
    Where spark plug metal wire loom bolts to block.
  3. HomerFlattop
    HomerFlattop
    from Upstate NY
    I believe that was where the factory plug wire loom was mounted
    Deuces, Torkwrench, mad mikey and 3 others like this.
  4. squirrel
  5. NewToMeT
    NewToMeT
  6. Mr48chev
    Yuppers for when you correctly route the wires down and under the ram horns rather up and out and over.
  7. Blues4U
    Blues4U
    from So Cal
    Those engines sure look a whole lot better with the wires routed that way instead of out over the valve covers.
    Deuces, Tman, Moriarity and 5 others like this.
  8. Tim
    Tim
    from KCMO
    Yeah the top hole is for a bent over tang so it doesn’t rotate and the lower is threaded for the threw bolt
  9. Tim
    Tim
    from KCMO
    Drew a pic since the diagram above is pretty small if you don’t know what you’re looking for. I recently used them to route wires under my ram horns.
    Deuces, vtx1800, Bob Lowry and 4 others like this.
  10. NashRodMan
    NashRodMan
    Squirrel and Tim, This info is very timely for me at this time!! Thanks.
    Deuces likes this.
  11. Bob Lowry
    Bob Lowry
    Chevy parts sites...
    Deuces and Tim like this.
  12. You can also refurbish old ones with Plasti Dip.
