Hot Rods 1940 ford bumper
Discussion in 'The Hokey Ass Message Board' started by jhoward51, Apr 30, 2023.
  1. jhoward51
    jhoward51
    from Georgia
    Any tips for installing new front bumper on a 40 Ford Sedan. Bracket holes way off. Put the rear on yesterday. Rough job getting bolts lined up with brackets. Got to be a trick somewhere.
  2. 40FORDPU
    40FORDPU
    As you've discovered each side consists of two brackets bolted together...keep all of the bolts/nuts loose, to get complete adjustment/movement to align things, also keep them loose on the frame ends.
    Should not be an issue, providing you have the correct bumper and brackets.
    lothiandon1940 and warbird1 like this.
  3. Dak Rat
    Dak Rat
    from NoDak
    Bumper bracket are always "tweeked" You need to pull them back into shape until they line up with the holes in the bumper. Some times takes heat because they are spring steel.
    lothiandon1940 likes this.
  4. alchemy
    alchemy
    Bend the brackets to fit the bumper and frame. Pick the nicest inner one to start, and then make the other side match. I mean bolt it to the frame and bend the other side so they have the proper distance between holes, and the bumper fits. Then start with the outer brackets. To bend them, clamp in your strong vise and put a long pipe on the end for leverage. Use heat as a last resort.
    Note that Standard brackets are different than Deluxe brackets. Maybe you have a mismatched set?
    Packrat, jimmy six and lothiandon1940 like this.
  5. lothiandon1940
    lothiandon1940
    As @Dak Rat said, they are almost always "tweeked", some worse than others. Follow like @alchemy describes and you should be able to work it out.
  6. 40Standard
    40Standard
    from Indy
    just a question-how are front bumper bkts from a standard different from a deluxe
  7. lothiandon1940
    lothiandon1940
    ...I believe the DeLuxe arms push the bumper out a tad farther due to the DeLuxe grill protruding a bit more than the Standard.
  8. FritzFord
    FritzFord
    from Nashville
    Mine were way off. So I just bought new brackets from Bob Drake. They fit like a glove.
