Technical 1956 Merc Wagon Question
Discussion in 'The Hokey Ass Message Board' started by andyh1956, May 1, 2023.
  1. andyh1956
    andyh1956
    Hey I found a '56 Merc 2 door wagon project out at the Pate Swap Meet. Perfect size little wagon but man that front end sheetmetal just don't do it for me. Looks like a Catfish layin up on the bank in the sun...:p But will a front cap from a '56 Ford fit on there? Looks to be the same general size & shape & a '56 Ford is so Pretty!
    Thanks!
  2. guthriesmith
    guthriesmith
    I know the doors on my buddies 56 Merc two door sedan appear to be exactly the same as my doors for whatever that is worth. Other than the trim difference, I don't see any other difference at least to the eye so would expect the front clips to interchange.
  3. HOTRODPRIMER
    HOTRODPRIMER
    The 52-55 Mercury & Ford wagon body is basically the same so I would think the same thing applies to the '56 wagons. HRP
  4. Mr48chev
    The designers subcribed to the more m***ive the better on those front ends. That two door makes for a great looking wagon though. 56 Merc wagon.jpg 56 Merc wagon BW.jpg
  5. goldmountain
    goldmountain
    Wouldn't the Merc have a longer wheelbase? Measure the distance from the front wheel to the door opening before you commit.
    jimmy six, pprather and guthriesmith like this.
  6. kabinenroller
    kabinenroller
    There is a big difference between Mercury’s and Fords.
    Mercury’s have lock washers- Fords don’t!!!
    AldeanFan likes this.
  7. andyh1956
    andyh1956
    That's a BIG Difference!;)
  8. andyh1956
    andyh1956
    I may could get used to that Merc front end...That looks like 300 lbs of Krome!:rolleyes:
    guthriesmith likes this.
  9. I’d take the merc front over the ford.
    Looks great as a mild custom
    oliver westlund likes this.
  10. guthriesmith
    guthriesmith
    I think both look good. I would leave it a Merc front end and I may even be biased the other way.
    Dos Cincos likes this.
  11. Mark T
    Mark T
    The ‘56 Ford wagon has a 115 1/2” wheelbase, the Mercury has a 118” wheel base. As goldmountain said, measure the distance from the door to the wheel center line if you decide to use the ford sheetmetal.
    Maybe use a ‘55 or ‘56 Ford front bumper and make a custom grille.
    If your looking for parts or technical information you can join the 1952-59 Ford Social group here on the HAMB.
  12. jaracer
    jaracer
  13. Fortunateson
    Fortunateson
    You could try to track down a “56 Meteor Rideau grille...
  14. Bandit Billy
    Bandit Billy
    Love that slanted B pillar on the 2 door wagon.
  15. I believe a Ford nose would work.
  16. pprather
    pprather
    @guthriesmith , do you have a side photo of your 1956, that we could see alongside the red and white Merc wagon photo above?
    The it should be easy to see the distance from the front of the door opening to the rear of the front wheel opening, to see if both cars are the same.
    I would guess they are different, as stated above.
  17. jimmy six
    jimmy six
    Even with a longer wheel base and the same tops…. The engine room is shorter on a Merc. You need to get any 56 Ford, preferably a 2 or 4 dr sedan, side by side , open the hood and start measuring.
  18. guthriesmith
    guthriesmith
    Here you go Phil.
    J. A. Miller likes this.
  19. 50Fraud
    50Fraud
    Pretty sure that the Merc's extra wheelbase is all in the front clip. The Ford fenders and hood would be too short for the Merc by 2.5".
  20. pprather
    pprather
  21. goldmountain
    goldmountain
    This wheelbase discrepancy reminds me of two bullet nose Studebakers a friend had. The convertible had a short nose and the coupe had the long nose. He swapped the front sheet metal from one to the other. That was a lot of work.
  22. 50Fraud
    50Fraud
