Technical What is This Carb & is It Worth a Sh*t if Rebuilt?
Discussion in 'The Hokey Ass Message Board' started by brigrat, May 2, 2023.
  1. brigrat
    brigrat
    from Wa.St.
    Took this off a '53 Flathead with an Eddy 452 intake with a square bore base. What is it? Autolite? Worth running if rebuilt? Thanks!
    Deuces, chryslerfan55 and hrm2k like this.
  2. Some of those Autolites are getting to be worth a few dollars. I see it doesn't have a tag, but there should be some numbers stamped right near the drivers side front bolt. Something like C9AF B. You should be able to Google what it's from. Gene.
    chryslerfan55, hrm2k and brigrat like this.
  3. brigrat
    brigrat
    from Wa.St.
    Just like you said, front drivers side bolt, clean, brush & clean again! C2SF A
    hrm2k likes this.
  4. jimmy six
    jimmy six
    They are good carburetors. Your engine could actually run with entire top off. This style were very common on the early 4 barrel Mustangs and Fords in the early 60’s. I would have it professionally rebuilt as all the original parts appear to be there. The second photo shows where the cable attaches for a choke so I’m guessing it came off a truck. I believe they were in the 400-500 cfm range.
    The linkage makes it work on a flathead engine and would probably work with other 4 barrels.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Could be one of summits ( or other) holley clone ..
    Deuces likes this.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
  7. brigrat
    brigrat
    from Wa.St.
    Who are the go to guys for a carburetor kits now a days?
    Deuces likes this.
  8. Mark T
    Mark T
    Not a clone, that is a 4100 Autolite that was originally on a ‘62 Ford.
    These carburetors came in 2 different sizes, The 1.08 flows around 440 CFM, vs. 590 for the 1.12.
    A 108 should run pretty good on your Flathead.
    These are very easy to rebuild.
  9. Budget36
    Budget36
    Check with @carbking for quality and if he has what you need.
  10. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^ He's kinda cranky, but OK!^^^^^^^^^^^^^^
    Deuces and Okie Pete like this.
  11. stephen alquist
    stephen alquist
    60's Ford 352 v8 or a 390
    Deuces likes this.
  12. Budget36
    Budget36
    Hmnn, I sent him a PM (never followed through) about a kit, I didn’t get that impression from his reply to me.
  13. gary macdonald
    gary macdonald
    It’s easy to rebuild.
    Deuces likes this.
  14. carbking
    carbking
    "Grumpy" is a better description :p:D And it has been "Monday" ALL DAY!:mad:
    PM sent.
    Jon
  15. AccurateMike
    AccurateMike
    Great carb. I like them. Yours is older. It has the ball-check in the accelerator pump, rather than the later rubber valve. Might have br*** throttle plates and shafts (usually the secondaries). It appears to be manual choke too. Factory manual choke is worth more than a converted auto. Yours looks to have factory hardware and provisions for an auto choke. Hard to say, I'd venture converted. Walker has kits and parts. I have some organ donors. The late 50's 4100's came on a bunch of stuff (Edsels etc.). It's a keeper. Looks a mite rusty though. Mike
    Deuces, Okie Pete, Tman and 2 others like this.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Someone must have added the manual choke parts to it. C2SF is 1962 Thunderbird
    Deuces, Squablow and Beanscoot like this.
  17. Marty Strode
    Marty Strode
    They came in 2 sizes, one for 289 and another for the 352-390 engines. Great carburetor, better fuel mileage than a Holley. This one came off a 1965 -289-225hp. IMG_0093.JPG IMG_0095.JPG
  18. jimmy six
    jimmy six
    He makes up kits….no longer overhauls carbs
  19. Beanscoot
    Beanscoot
    The early ones had Holley type main jets, I'm not sure if 1962 is old enough.
    Later ones use the bigger Ford jets (5/16-32 threads IIRC).
    The vast majority are 1.08 or 1.12 venturi size, the other two sizes are unlikely to be encountered.
    Deuces and Mark Yac like this.
  20. bchctybob
    bchctybob
    I’ve had them on a couple of cars over the years, two T-birds, and a ‘53 F100 with a 390 in it. They are not a maximum performance carburetor but they are easy to rebuild and virtually trouble free. I’d keep it and run it if you have an engine that it is sized right for.
    Deuces and brigrat like this.
  21. Beanscoot
    Beanscoot
    I tried a 1.12 venturi one on my 260, it was too big and the car was slower off the line (low to mid range rpm) than with the original 2V.
    So I replaced it with a 370cfm (sic) Holley four barrel which worked great.
    But I do like the Autolite 4100s, and finally got a 1.08 version.
    Those were used on most of the few small blocks that came with 4V carbs plus a small number of bigger engines. But way more big blocks came with 4V carbs (usually the 1.12 version) so those carbs are more common and cheaper.
  22. AccurateMike
    AccurateMike
    In the core pile that I pick from, 1.06's and 1.19's are hen's teeth. 1.12's outnumber 1.08's 4 to 1. Most are off of old, big engines. People pluck the manual choke parts off of 2100's all of the time. More than 1/2 of the manuals I see are converts. I turn them back to auto. It's harder to sell a modified carb. Older carbs also had metal arms on the secondary diaphragm. These get picked too. New plastic arms are available. The metal in the older carbs is better, especially compared to a later 2150 or 4300. I get later carbs more corroded all of the time. The Zamac turns dark and gets pitted. I have junk 2150 bodies with holes eaten through them. Also, I like the older ball-check accelerator pump. It will never "harden up". Most of what I get are from junk cars, the pile gets added to constantly. Often pretty rough. If I see a fair 4100, I try to get to it before it gets too much "hangar rash". If there is an 1100/2100/2150/4100/4300 that someone is after, I can keep an eye out. I'm not the seller, just the rebuilder. I can put you in touch with the powers that be. An old 4100 gets my vote as the most bullet-proof 4 barrel carb out there. Mike
  23. brigrat
    brigrat
    from Wa.St.
    It was a joke, he has always been very helpful with my "problems"! Wealth of info!
    Deuces, Okie Pete and Budget36 like this.
  24. brigrat
    brigrat
    from Wa.St.
    I am getting 1.56 under the ****erfly's, off the charts for a 4100...........................measuring in the wrong place? Interesting local find. Dizzy looks to be a converted SBC, welded Aluminum anchor lock down tab, chevy guts?
    Deuces, Okie Pete and chryslerfan55 like this.
  25. AccurateMike
    AccurateMike
    The venturi size is on the right side of the primary bowl. In a circle. Mike
    Edit: I have a 1.12 here and it is ~1.56" too.
    Edit Edit
  26. brigrat
    brigrat
    from Wa.St.
    Same here, thanks! 600 CFM, hope they have hopped up this little unknown flatty to handle it!
    Deuces, Okie Pete and AccurateMike like this.
  27. 38Chevy454
    38Chevy454
    I think the confusion might be venturi diam vs throttle blade diam. The 1.12 or 1.08 is venturi diam which would be a lot harder to measure than throttle blades.
    Okie Pete and brigrat like this.
  28. BamaMav
    BamaMav
    from Berry, AL
    I’m running the Summit copy on a couple of engines. Really like them. No gaskets below the fuel level. I looked for an original Autolite, but by the time I bought a kit and built one the Summit was cheaper.
    Truckdoctor Andy and brigrat like this.
  29. tubman
    tubman
    By "square bore" you are reffering ro the AFB/Early Holley pattern, not "square" (which is early WCFB, early 4G's and a few others), aren't you? I have a four flathead 4-BBL manifols (a Fenton, an Offenhauser, an Edmunds, and a Sharp) as well as an old Offenhauser dual quad for an Olds Rocket that all have the old "square" bolt pattern. The carbs I know that fit are hard to find and expensive when you do. I have never had a 4-BBL manifold for a flathead made by Edelbrock. Does the Edelbrock have the "square bore" pattern, or does it have an adapter? I sure would like to find another type of "square" carbs if it exists.
    I think a better description of the bolt pattern would be helpful. Maybe "Old Square"?
    Deuces likes this.
  30. brigrat
    brigrat
    from Wa.St.
    From Eddy's add;
    "Edelbrock 4-Barrel Intake Manifold for 1949 to 1953 Ford/Mercury Flathead V8 will allow the use of commonly available Square-Bore (4150-Style) Carbs such as our Performer or AVS Series on the Late Ford Flathead Engine." There is an adapter but it comes with the manifold, will know tomorrow after I take adapter off to see what pattern the manifold is without it.
