Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 1971BB427
    1971BB427
    from Oregon
    My most irritating annoyance is squeaks! And Sat. morning headed to a local car show I hit a bump in my '39 Chev and heard the squeak! Went ahead to the show, and Sunday I went out to find it. It was coming from the right rear corner, and I could put my knee in the trunk on that side and push down hard to make it squeak, but darned if I could tell where it came from? Metal to metal sound, and I guessed maybe body mounts since springs, and all the suspension I did new less than 2 years ago.
    So I jacked the car up on stands, and loosened all the rear body bolts about halfway up both sides. One at a time I removed a bolt and slid in urethan shims II cut with a 3/8" hole drilled to slip the bolts through. After 3 hours I let it down and checked again, and the same damn squeak still!
    Back to the trunk and pushed down to hear the same squeak, and this time I began spraying some penetrant into places I thought might be the cause. Last place I tried was the spot welded joint where trunk floor meets the inner fender panel at 90 degrees. Sprayed along the joint, and suddenly the squeak stopped!
    I tried a thin screwdriver, and a putty knife in the joint to see if any spot welds had broken, but all was tight and solid. No idea what caused it, nor why it stopped spraying the joint. Now I'm planning to clean it well and use seam sealer along the joint in hopes that stops it from ever returning.
  2. Cut and buff, and buff, and buff.... :rolleyes: 20230502_144748.jpg 20230502_144802.jpg 20230502_172601.jpg 20230502_172614.jpg
  3. Oh, and I took the left rear tire off of my car, and took it to the tire place to get a new valve stem put in it. After 30 minutes of trying to break the bead, I threw it in the truck and headed to the top of the hill. He broke the tire down, replaced the stem, balanced the tire, and told me $10! I reach him $20 and said lunch is on me. Then on the way home I realized that it's damn hard to eat lunch for $10 these days!
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. swade41
    swade41
    from Buffalo,NY
    Cut my hole, lined up pertinear perfect
    Screenshot_20230502_170429_Gallery.jpg 20230502_160649.jpg 20230502_153744.jpg
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Reason for template (paper doll). 58E66BDB-8B3C-48FE-A251-A925993E8042.jpeg 8081AF3B-8220-4DB4-85E4-0F23F546F16C.jpeg
  7. atch
    atch
    Any lunch you can buy for $10 these days is probably a fast-food grease burger and at my age I'm just pretty much over that.
    I love it when a plan comes together.
  8. alanp561
    alanp561
    Okie Pete, chryslerfan55 and swade41 like this.
  9. 51504bat
    51504bat
    Don't forget "Good enough for Government work":cool:
    Okie Pete, chryslerfan55 and alanp561 like this.
  10. alanp561
    alanp561
    Have you tried a vinegar/baking soda paste? Rub it on until the area comes clean, rinse and wipe dry with a clean cloth. Another option is SimiChrome. Used to use it for blued exhaust pipes on my motorcycles.
  11. swade41
    swade41
    from Buffalo,NY
    I won't lie, I was sweating it a bit, at the last minute I measured from the body down with a 1 3/4 tube and it was a little different from measuring from filler tube up.
    I had used that little 5 inch square and it showed the angles were pretty much the same, the smaller footprint of the tube showed they weren't so I moved it a half inch up.
    That's where the doubt creeps in lol
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    After being layed off due to Covid no more machine shop to walk into. So what do you do when you need a few .000’s off? Get creative. Only need 4” so don’t be thinking I’m doing the whole 36”. Just mock up to see if I can spin some stock. 23D6CB62-17E8-4DC1-96E1-8CEF8A868FD7.png
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Good old fashioned paste wax lovin... I bought a half dozen new old stock cans from the 70’s a few years ago.... I hate modern ****....
  15. swade41
    swade41
    from Buffalo,NY
    This was my jig to hand file a straight line, to clean up the fins on a scoop, creativity is only limited by the imagination.
  16. OpenThrottle
    OpenThrottle
    from So Cal
    I’ve been working on this.
    Tickety Boo, Okie Pete, hfh and 5 others like this.
  17. Did a headliner with momma, she isn't comfortable doing them by herself yet :D:cool: 20230503_182333.jpg
    Yeah I know there's no dome light, he didn't have one, he's putting that in himself
  18. Dick Stevens
    Dick Stevens
    Looks very good and I'm not surprised!
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
  20. 64krusty
    64krusty
  21. OpenThrottle
    OpenThrottle
    from So Cal
  22. Day 2
    Day 2
    from ga
    Thought I had a bad u-joint, turns out it is a bad tailshaft bushing. Called around to four different trans shop, same answer,, we can't get parts!!Got on the net and hand two coming within ten minutes, be here Monday...Sad when people just don't want to help. F'em
  23. LOU WELLS
    LOU WELLS
    from IDAHO
    Preparing The Delivery For Summer Use....New Fluids... DSCN7347.JPG .
  24. I've been through that here, luckily a place called Camargo transmissions keeps a stock of redi-sleeves on the shelf.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Redi-sleeve or tail housing bushing?
  26. Every one I've got from them is in a redi-sleeve box
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Oh the old adjustable wrench vs Cresent wrench debate. I’ll accept your answer then. :cool:
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    By the way Lloyd, thanks for the shout out about linkage. I’ll be putting my Jr thru High School and to this day friends resent purchase (to replace his he had before) 65 El Camino back to the column from cheesy cheep floor shifter.
  29. So the stuff enloe has will work?
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sorry, I didn’t go backwards on that thread to see. I’ll go back.
