Projects Model A build
Discussion in 'The Hokey Ass Message Board' started by Scrappy’s designs, May 4, 2023.
  1. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    This build is going to start with a little story about how life started with me and this car. About a year ago I drove what seemed like half way across the country with my dog and picked up this running, driving 1930 Model A hot rod. The car is great and has already given me a ton of fun. On the drive home I stumbled across some other hot rodders in Nebraska and they invited me to the High Plains Riot. (I’m new and not sure about the rules on naming events.) I followed them to the event and within 24 hours of buying my car I was at a multi day event where I was on the dirt track backing it into corners on Friday night! Then Saturday morning I had to get up early and clean things up because I placed it in the show where I was picked as one of the top ten! I spent the weekend and headed towards home.
    Once home I started going over things and planning some upgrades.
    LCGarage, Outback, swade41 and 7 others like this.
  2. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    First things first, I had to give this car the correct stance. The rear tires just weren’t working for me so I ordered wheels and tires and fixed the problem.
    swade41, Chief 64, AHotRod and 2 others like this.
  3. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    C1C6F7F2-2E45-48D8-8D95-E9E0BDFEEA3B.jpeg 4D400E59-69E5-4EEB-9446-0B5B95F0426F.jpeg D250D2D1-DCB6-4453-8A23-EF5CE1DF81A5.jpeg AA307E7A-72CC-478F-BF85-EFF9AB7076F9.jpeg C894E4F2-C43B-49CF-A432-227469C93673.jpeg 751BBD51-22BC-4AF8-A9F0-F6D1BDE609BE.jpeg C53AA893-4987-4E37-A470-2AB4AE110398.jpeg After a close look there’s several things that I don’t like about the way this car is put together. Just look at some of the welds on this thing! I’ve spent several months going through things and making it safe and reliable. Brakes, cooling issues, making the doors stay shut, replacing a couple of cracked windows as well as all new door gl*** felt. I even replaced the fuel tank. The old one made the car smell like gas and the new one is 4 gallons bigger for more range. The steering column was mounted using what looked like a hanger used for a fire sprinkler system in a warehouse, so I quickly fabricated a solid mount and it’s so much better.
    LCGarage, swade41, catdad49 and 6 others like this.
  4. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    When I bought the car there was no interior other than the seat and metal dash. At first I threw together some quickie door panels just so I wasn’t looking at raw doors all the time. Since the temporary door panels were in I decided that it needs red windows.
    duecesteve, swade41, catdad49 and 7 others like this.
  5. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    The temporary door panels were never meant to be there long. I have virtually zero experience with upholstery work but I went and bought a sewing machine and started practicing. Things weren’t so good in the beginning as you can see from some of my practice pieces, but after a bunch of practicing 27786770-3162-4E0E-9C5A-7B396D68756D.jpeg D353AE84-64FA-4BD8-8F6E-4141D7474FB3.jpeg 7B5CE01A-B366-4A94-A23B-D0371CDDFD85.jpeg A205F1F5-6980-49B6-BA20-3FA2C51FF5EB.jpeg 9B581766-BC9E-4550-9CF9-ADAD7D551C15.jpeg 7074E36F-5E85-4D85-9E89-13B94F889F1C.jpeg 693F78C4-35D3-449E-AA30-BAC76608FE43.jpeg BBBCB404-A9BF-4DCB-B5BE-1AC692087B81.jpeg B7EE0189-6BC9-4984-AF4C-972F6B8F1BD1.jpeg 04FF3761-EEB8-43E3-8BF4-678D8EF29C7D.jpeg 5CC6BF7F-78A1-4689-912D-7035C0066849.jpeg 453D4E43-8ABA-4BA5-903A-8277E737183B.jpeg CB5D7500-6BEA-47F2-A5AA-ADBCE9FA6B85.jpeg B86BDCBE-6971-4CEE-B450-A490654556C7.jpeg 15968535-311E-4E8F-9664-D0BBB9BC00E7.jpeg 42436070-31D6-4B35-BBDC-4C5196B1C4A4.jpeg 1881A95A-EA73-4037-A1B1-CDA696F9BBEA.jpeg 8460ADAF-0B01-46B2-8902-7CF0DF7C54EC.jpeg FBC41648-72CA-46B8-83EB-A03459A1A0BD.jpeg 370EF8D0-E629-45A7-9374-A0AA1CB58325.jpeg 1CC64021-F9C5-4459-9768-BAB0F8A6EFCD.jpeg F0BE5628-7371-4604-8DCB-5B25A19FF71A.jpeg I started in on the real parts. Things are going slow and I’ve had to make a few of the pieces more than once because of mistakes, but so far I’m loving the results! The one thing I’m not sure about is using that bright white. Time will tell if it’s going to stay bright white or show every smudge and dirt spec.
    LCGarage, hfh, swade41 and 23 others like this.
  6. guthriesmith
    guthriesmith
    Way to jump in with both feet before even getting home with the car! I will be following along as you make the car better. :cool:
  7. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    Thanks! It’s been so much fun so far. Except when it isn’t. There’s been a few of those time too. D050289B-253B-4166-AF0B-1408A0513310.jpeg D050289B-253B-4166-AF0B-1408A0513310.jpeg
    swade41, winduptoy, Toms Dogs and 6 others like this.
  8. guthriesmith
    guthriesmith
    Yea, one of my main sayings is "Old cars ****!" :p
  9. All do , one would hope!:D
    Ben
    guthriesmith likes this.
  10. TCTND
    TCTND
    Well, I hope the nice new upholstery won't keep the dog from riding in it.
  11. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    I wasn’t going to share this quite yet but it’s on my introduction post so here’s the new engine that’s going in along with a whole new frame/ch***is setup. It’s a 1957 Hemi 392 with a bunch of goodies on it. Going with a quick change rear end and still on the fence about which transmission to use. Whatever I pick is going to need to hold up to this Hemi that’s something like 500ish horsepower. When I swap the body over it will get chopped and channeled. I’m going to have a busy next winter. AF84F78C-B142-43DF-8E1D-7E62AC63D9D5.jpeg
  12. oliver westlund
    oliver westlund
    Tremecs 5 speed with furthest forward shifter location. 500 hp puts you in a category thats tough with vintage trans options and if youre gonna drive it cross country be easy on yourself. Those guys are worth calling! I normally wouldnt say that but nothing I have has 500 hp
    Scrappy’s designs likes this.
  13. patsurf
    patsurf
    the learning curve shown on upholstery---was VERTICAL!--nice!
  14. Atwater Mike
    Atwater Mike
    Bud and I took a crash course in upholstering his channeled '30 'A' coupe. Similar steps taken, but we had my Mom's heavy duty machine!
    Enjoyed reading with all the pics, excellent job!
    Big steps you're taking with that 392" Chrysler. Anxious to 'ride along' on ch***is fab, a REAL hot rod. Kudos.
    P.S. Your dog looks like my Annie. She loves to ride...Sits perfectly still, attentive.
    alanp561 and Scrappy’s designs like this.
  15. Illustrious Hector
    Illustrious Hector
    Good job! You're diving right into making it yours. I'm hesitant about upholstery,. Great pics always bring out the character of the build and owner. The chain driven Evo for example, not something often seen, and who hasn't fallen in love with that doggo.
  16. FiveNdime
    FiveNdime
    You dove right in the deep end, and I dig it. Learning the upholstery is on my list of to-do items as well. I'll be watching the build.
    Im currently building a Model A as well, threads on here. I'd give Modern Driveline a call, they were excellent to deal with, and treated me very well. They will walk you through what your looking for in your project and what you want as an end result.
    Transmission Conversions | TREMEC Solutions & Kits | Modern Driveline
  17. GordonC
    GordonC
    The dog cracks me up! He has the same look my wife gives me, which is "You ******* money away on that thing again!"
    Just Gary, duecesteve and catdad49 like this.
  18. dsiddons
    dsiddons
    from Indiana
    Man way to go! I had way more trouble figuring out this upholstery stuff. I would feel better if you struggled for a little bit longer. Hahahaha
    alanp561 likes this.
  19. AHotRod
    AHotRod
  20. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    I took a little road trip and picked up the Hemi. Sorry I haven’t posted for a few days but I drove about 2000 miles in 2 1/2 days to get this. I would have loved to spend some time and enjoy the trip but I’m now only a week away from my trip to the Grand Canyon with the Model A and have several things to get ready.
    I was really hoping to have the upholstery finished before the Grand Canyon, but with going to get the Hemi I’m not going to have the time. Reliability is key and that’s where 100% of my focus is right now.
    swade41, catdad49, Greenblade and 2 others like this.
  21. Scrappy’s designs
    Scrappy’s designs
    from Idaho
  22. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    Still fighting a cooling issue. The Hemi isn’t going in just yet so I’ve got to maintain what’s there. Hopefully this will fix it.
  23. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    31B4EB28-41C9-4505-A00A-E99E4B5B498F.jpeg 6123CF2A-A42B-4239-8B16-B8D7154692D1.jpeg 6C14856C-C4F3-4857-AB6A-A7DC6A0A6271.jpeg E7C90DC1-9DE7-4A9D-9064-A67DFDDC9997.jpeg D1E510BF-3391-484A-8DDD-A23D5A70EA03.jpeg Yesterday was the radiator, today I went back to the interior. The carpet is down on the floor as well as the back wall. I found some s**** aluminum pieces that work perfectly for sill plates and help hold the carpet in place.
    LCGarage, swade41, GordonC and 10 others like this.
  24. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    Sorry I haven’t posted in a while. I’ve been busy with events like a 1200 mile run to Lake Powell, Zion National Park and the Grand Canyon. It was an incredible experience traveling with 24 vintage hot rods!
    swade41, hfh, Toms Dogs and 9 others like this.
  25. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    Since getting home I’ve been busy ordering more parts and pieces. The new wheels are here and they were test fit to make sure back spacing and brake clearance is going to work. Tomorrow I should drop them off at the powder coat shop. New tires are ordered but not quite here yet. I’m being told I should see them next week. Timing should be perfect for mounting them on the fresh new wheels.
    Just Gary, WC145, swade41 and 4 others like this.
  26. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    I’ve been kind of stressing out about what intake setup to run on the new Hemi. Today the new setup finally arrived! These aren’t new parts and will take some rebuilding and polishing but should work great for my setup.
    LCGarage, Just Gary, swade41 and 7 others like this.
  27. metalhead140
    metalhead140
    Cool build! I have a 331 hemi slated for my Model A, one day... Enjoying playing with and building up the banger at the moment.
  28. Scrappy’s designs
    Scrappy’s designs
    from Idaho
    A few more pictures of things to come.
    LCGarage, swade41, GordonC and 4 others like this.
  29. 26hotrod
    26hotrod
    from landis n c
    This is good stuff!! Drive on..................
  30. Dick Stevens
    Dick Stevens
    It would be nice if you would select 'full size images' when you post pictures instead of the thumbnails!
    swade41, WC145 and Tim like this.
