Projects Buick/Olds Aluminum V8 in a Model A
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Mar 27, 2023.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, it's probably from a '61, which only had three speeds available. The four speed showed up the following year. I believe this bellhousing used a Borg Warner T96 transmission.
  2. coilover
    coilover
    from Texas
    I bought a brand new long block Olds 215 back in 1967. After sitting under a table in my home garage for 50 years I sold it to a customer that needed one for a 1962 F85---it's original home. He is a very happy camper.
    rod1 likes this.
  3. Flatrod17
    Flatrod17
    Thanks for the info, but its not for a T85 or T86, I have those. Looking at pics on the net it looks like it for a T96. One I never heard of.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I just looked at my post, and saw the typo; I meant T96.
  5. In_The_Pink
    In_The_Pink
    Yes, that is the early 3-speed transmission bolt pattern.
    Pictured below is the later dual pattern bellhousing featuring both 3- and 4-speed bolt patterns:
    This will work with pre-metric ('88 and older?) GM T-5s from multiple HAMB-unfriendly donors.
  6. nochop
    nochop
    from norcal
