Projects built lots of cars, but never a 32 roadster...
Discussion in 'The Hokey Ass Message Board' started by SDS, Oct 14, 2021.
  1. SDS
    SDS
    That's a great idea, thanks!
    pprather likes this.
  2. SDS
    SDS
  3. SDS
    SDS
    Finally warmed up a bit...got it all plumbed. A few more things to do, like ftame welting, install the exhaust and e-brake lines, the the body goes on!
    PXL_20230413_215452896.jpg PXL_20230413_215605515.jpg PXL_20230413_215616992.jpg
  4. pprather
    pprather
    Before the body goes on:
    Much of the frame gets built from the top, but once the body goes on, it can only be serviced from down below.
    Check everything over to be sure it is actually serviceable from below.
    Ask me how I know?
  5. alchemy
    alchemy
    Are you putting rubber bump stops in the C notches? Will the brake lines running on the top side of the axle get smashed on a hard bump?
    Atwater Mike and X38 like this.
  6. RockyMtnWay
    RockyMtnWay
    I’ve done a few 9” rears in 32s, but a buddy of mine just turned me onto mopar b body rear axle brake line hardware. 1st time using it on my current project and it sure seems to work out well. I can add some more pics if folks interested in seeing the bits used, but as noted above you might want to ensure everything is safe from bottoming out and that you can service everything from the underside. The brake lines along the top of your axle scares me and being able to yank your 3rd member as easily as possible should be considered (that’s why I went on the backside on this project).
    Dak Rat, Atwater Mike and X38 like this.
  7. X38
    X38
    I'll 2nd what the two posts above said about the brake line. You need to re-do that.
    05snopro440 likes this.
  8. SDS
    SDS
    If that crashes, I have bigger problems...
    There is less distance between the top of the rear-end center and the floor of the body (3.25") than between those brake lines and the c-notch (3 3/4"). There's probably more of a chance of the brakes lines getting hit by the exhaust pipe where it goes up over the rear-end.
    I weigh 275 and stood on the rear spreader bar, then jumped up and down - the c-notches went down no more than 1".
    Does the rear suspension on cars with this setup really travel much? It has a Posies transverse rear leaf spring.
  9. alchemy
    alchemy
    Yes it will. When you least expect it. Mark my words, at some point you will have that axle use all the travel available. Even if the pumpkin is going to hit first, who’s to say you don’t have one tire hit a bump and the other doesn’t?
  10. X38
    X38
    If your rear only travels an inch, you’re going to have a **** ride. You need those inches.
    beater32 likes this.
  11. Anderson
    Anderson
    Don’t forget than when you turn a corner, you’re going to have body roll. Take a corner a little too hard that has a bump in it, and yeah there goes your brake line. I’m sure you don’t want to take the time to redo it…but redo it.
  12. NJ Don
    NJ Don
    Scott,
    Remember, with a full tank of gas hanging way behind the rear axle your rear ride height will be lower. Fill the tank then do your spreader bar jump and you will be surprised. My ride is different with a full tank of gas vs almost empty, although I have a 16 gallon tank. My .02$ is move the brake tubes.
    05snopro440 and pprather like this.
  13. SDS
    SDS
  14. SDS
    SDS
  15. NJ Don
    NJ Don
    More better brother!
  16. simplestone
    simplestone
    I'm glad you guys pointed out that potential problem with the brake lines - I never would have considered that!
    One of the reasons why the HAMB is so great.
  17. VI Lonewolf
    VI Lonewolf
  18. NJ Don
    NJ Don
    WOW! Cant argue with that!
  19. SDS
    SDS
    OK...got the hard side done this evening
    Went ahead and ducked it under the exhaust pipes too (there's certainly the propensity for the axle to crunch into the exhaust pipes when I hit a big bump too)
  20. SDS
    SDS
    I got the brakes bled tonight and luckily had no leaks - I'm having trouble getting a stiff pedal though.
    Master cylinder is a Corvette type unit made by Pete and Jake's for four-wheel drum brakes.
    Rear drums are stock for a 9 in Ford in the front drums are reproduction Lincoln.
    I have residual valves both front and back and they are mounted close to the master cylinder.
    I've bled all four corners twice and when you pump the pedal a few times, it gets stiff and holds - so that tells me there are no leaky wheel cylinders or anything like that. If I let the pressure off the brake pedal, and leave it sit for a few seconds, the brake pedal is no longer stiff and comes close to bottoms out. Any suggestions?
  21. Anderson
    Anderson
    Did you bench bleed the master cylinder first?
  22. X38
    X38
    They don't make them. Neither does Speedway, but everybody sells them.
    What psi valves? Not necessarily the problem though.
    Bench bleed is a good suggestion. Having said that and without jumping to conclusions, these off shore made 'Corvette' m/c's often seem to have problems. I don't know why they're so popular. Maybe because that's what Speedway etc. sell?
  23. SDS
    SDS
    Yep
  24. SDS
    SDS
    Wilwood, red valves
    Jerry at Pete and Jakes said he has these master cylinders made just for my application (manual, four wheel drum).
    Yes, I bench bled the master cylinder.
  25. vtwhead
    vtwhead
    Can you isolate front and rear to see where the issue is?
  26. X38
    X38
    10 psi. That is okay.
    Mmm.
  27. NJ Don
    NJ Don
    You have air in the system somewhere. I use a vacuum bleeder but you have to seal the bleeder valves so it doesn't draw air in through the bleeder valve threads when loose. A pressure bleeder would be a good choice since you don't have the body on and the master cylinder is accessible. "Speed Bleeders" are another option if you are by yourself.
  28. SDS
    SDS
    How would I do that? The MC is a split unit
  29. SDS
    SDS
    Can I power, pressure or speed bleed the system if I have residual valves?
  30. alchemy
    alchemy
    I like the speed bleeders too. In addition to making the regular operation of bleeding easier because you don’t need to continually tighten and loosen the bleeder, they have a sealant on the threads to keep fluid from seeping out or air ****ing in.
