Hot Rods Flathead V8 powered 1920 Buick
Discussion in 'The Hokey Ass Message Board' started by OpenThrottle, Apr 6, 2023.
  1. OpenThrottle
    OpenThrottle
    from So Cal
    Bought me a flattie w/original trans for my 1920 Buick roadster on Model A ch***is. Also got a T5 w/adapter from an S10, because you know…. “Hot Rods have three pedals.” Or so I’ve been told
    brEad, CSPIDY, enloe and 7 others like this.
  2. OpenThrottle
    OpenThrottle
    from So Cal
    Here’s more. I have most of the parts collected to build a post war styled traditional Hot Rod.
    brEad, enloe, Petejoe and 7 others like this.
  3. X38
    X38
    A Buick bodied AV8.;)
    OpenThrottle likes this.
  4. v8flat44
    v8flat44
    Dare 2 b different....love the idea, watching ...
    lowrd and OpenThrottle like this.
  5. OpenThrottle
    OpenThrottle
    from So Cal
    Yeah I hope to add to this thread as I build.
  6. 1952henry
    1952henry
    A Ford in a Buick on a Ford, can’t wait to see the end product.
    enloe and Desoto291Hemi like this.
  7. rusty valley
    rusty valley
    I think I may have a windshield for that car, need one?
    Tow Truck Tom and OpenThrottle like this.
  8. That should work. Similar body to the early vintage Dodge roadster body. Garbage containers are nicely positioned too :D.
    s55mercury66 and OpenThrottle like this.
  9. OpenThrottle
    OpenThrottle
    from So Cal
    Yeah I do, I was going to fab something but it would be better to use the right windshield
    enloe likes this.
  10. OpenThrottle
    OpenThrottle
    from So Cal
    Alright follow this thread, because this is going to be my build thread. 2nd HotRod my friends and I have built. Should be more fun the second time being we learned a ton on the first 1. Plenty of Kustoms under our belt to. Hopefully this kinda goes as planned.
    brEad, enloe and 210superair like this.
  11. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Gotta, gonna love this.
    Ford in a Dodge, that cowl shape should showoff those Offy heads nicely.
    May the build be smooth, It's already cool.
    Plan to keep us in the loop.
    enloe and OpenThrottle like this.
  12. OpenThrottle
    OpenThrottle
    from So Cal
    So I went and picked up the motor and transmission(s) this weekend. 1 is the 1949 shoebox 3 speed with cable actuated overdrive in working condition, the other is the T5 out of an 80s S10. Also came with the Speedway adapter. However, since the Motor is out of a 1949 Shoebox Ford, aperantley I need a 42'-48' truck bellhousing so the Speedway adapter will work.
    Basically, I need an adapter to adapt the adapter so I can adapt the later model Chevy transmission to My 49' Flathead V8. LOL
    enloe, Ziggster and 210superair like this.
  13. 1952henry
    1952henry
    Thinking you need what is called the hogshead, they were used up til 52 in F1s- F6s.
  14. X38
    X38
    Put an ad in the wanted section for a hogshead.
  15. ERguitar
    ERguitar
    There is one on eBay now $150 plus shipping. Seems to about what most of them go for.
    X38 likes this.
  16. studebakerjoe
    studebakerjoe
    Check the parts for sale cl***ifieds here. I know someone is selling the adapter you're looking for and there's also a truck hogshead. I don't recall who is selling them.
    X38 likes this.
  17. OpenThrottle
    OpenThrottle
    from So Cal
    Oh and I ditched those ****py air cleaners for a pair Frogmouths I had lying around.
    Ziggster likes this.
  18. studebakerjoe
    studebakerjoe
    20230305_102348.jpg 34ratrodder has these for sale.
    enloe, OpenThrottle and X38 like this.
  19. OpenThrottle
    OpenThrottle
    from So Cal
    Update, still gathering parts BUT I found and bought the “intermediate bellhousing” and correct starter plate off of Epay. I also bought some more small items like F1 style upper shock mounts, reversed eye front spring. And 2” dropped A Model front X member. Hopefully this next Saturday I can get the frame into my garage and start building the front end.
    brEad, enloe and Ziggster like this.
  20. OpenThrottle
    OpenThrottle
    from So Cal
    84845C79-1311-4A56-AE17-3C893E3159D8.jpeg 6C636677-A8A5-4E2F-8A52-288F58AEE894.jpeg 34638A0C-D1E5-4C7F-B950-E7A9909B82E2.jpeg So I’ve been really busy with work lately, but I try to get out in the garage every weekend to turn a bolt or two at-least. I’ve heard that turning a bolt a day is better than doing nothing.
    I was able to order a few missing puzzle pieces this past week and to much excitement on my end, those pieces arrived yesterday. So I woke up giddy as school kid on the first day of summer break and went out to my garage to inspect and trial fit some of the components for my suspension.
    First I tried out the rear spring u-bolts to see if they fit the original model T rear spring AND rear model T crossmember that I acquired from a model T swapmeet a few years back. Seems like everything is going to fit like it should, but I have questions about the bottom bracket/plate. We can go cover that another time and hopefully the more knowledgeable on the HAMB will be able to point me in the right direction.
    You probably noticed there is a original model A front spring and a Posies brand front spring with reversed eyes sitting together. I’m torn between running the original with my original model A axle, or the reversed eye Posies spring. I’m enjoying the original period style builds here on the HAMB, and I know the Posies spring kinda isn’t the ticket for a true traditional build. Also, take a look at the length of the Posies spring compared to the original. I’m not convinced the Posies is the correct length? Wouldn’t be the first time I’ve bought the wrong part.
    Next weekend I should be able to get the frame into my garage and work out some of the fitment kinks. I plan on wedging the rear model T crossmember int between the model A rear crossmember and burning it in. Then probably have to gusset the crossmember as well. I also purchased a dropped model A style front crossmember from Speedway. I don’t really care for the way it looks compared to the original model A crossmember so I plan to cut some of the steel from the original and add it to this new crossmember so it looks the part. Stay tuned for what I have planned.
    Crusty Chevy likes this.
  21. OpenThrottle
    OpenThrottle
    from So Cal
    Another piece to the puzzle, scored a 47’ banjo rear end from a local guy and chrome front spring clamps. I already have a complete set of 40s rear brakes for this rear. Next I will get the Speedway 6spline conversion kit.
    enloe and rusty valley like this.
  22. OpenThrottle
    OpenThrottle
    from So Cal
    Myself and a club buddy got together today, test fitting my front axle with reversed eye front spring. We tried putting the lower shock mounts from speedway on the perches, but I don’t see how you can put the cotter pin through the castle nut on the perches. 09D4DDF2-70D8-4B22-BFCB-1EE77F7F7A89.jpeg 288978BF-09F2-48B7-A05A-630D7A6424A4.jpeg CBBDA020-3545-4CBF-8C02-F7C958D1FB84.jpeg 86BC9F88-7F00-4FFF-9E2A-0F364B0C542E.jpeg Bare in mind we didn’t build the entire spring with the rest of the spring pack, so I hope the spring pack will tighten up the clearance and sag of the spring shackles.
  23. [QUOTE="OpenThrottle, post: 14855649, member: 388377") We tried putting the lower shock mounts from speedway on the perches, but I don’t see how you can put the cotter pin through the castle nut on the perches.[/QUOTE]
    Cotter pin or split pin ? Cotter pin goes through the kingpin and axle at the end of the axle.
  24. OpenThrottle
    OpenThrottle
    from So Cal
  25. OpenThrottle
    OpenThrottle
    from So Cal
    Did a little something. Painted my front wheels. I’ll paint the rears when I’m ready to build the rear of the frame.
    brEad and enloe like this.
  26. enloe
    enloe
    from east , tn.
