Technical a little blow by
Discussion in 'The Hokey Ass Message Board' started by Huckster59, May 7, 2023.
  1. Huckster59
    Huckster59
    my 40 has a little blow by. pcv on p*** valve cover and vented cap on other. so i’m getting sone oil out of cap. i’m guessing valve covers aren’t baffled what do you guys run. i’m sure i’m not the first.
  2. chevy57dude
    chevy57dude
    Mopar had a cap with a hose ****** so you could take it to the air cleaner.
    Maybe someone here knows a specific appliation.
    *Guess the flatty your '40 came with has given way to an OHV...
  3. 427 sleeper
    427 sleeper
    Let's see the valve cover's. That would help determine if they are baffled or not. Try to mimic the factory set-up as much as possible.
    alanp561 likes this.
  4. BJR
    BJR
    It would help to know what engine you are talking about.
  5. Richard L
    Richard L
    from Quincy, IL
    My Chevy 350 would get oil in the vent/breather. Replacing the PCV valve fixed the problem. You could shake the valve and hear a rattling noise, but turn it over and back again and the ball would stick in place.
    I hope this could work for you. Good luck.
    Rich
    The Shift Wizard likes this.
  6. chevy57dude
    chevy57dude
    20230508_062921.jpg This is what I did on one of my BBCs.
    guthriesmith and Tow Truck Tom like this.
  7. Budget36
    Budget36
    My engine is similar as above, PCV on the left VC, and a hose from the air cleaner to the right side VC.
    chevy57dude likes this.
  8. Huckster59
    Huckster59
  9. Huckster59
    Huckster59
    i have 62 corvette 327. eddy carb.
  10. Huckster59
    Huckster59
    this is how it is now. pcv p*** vented oil cap on drivers side
  11. jimmy six
    jimmy six
    When a PCV system is plumbed correctly the air drawn in from the “vented” side is connect to the air cleaner on the inside of the filter.
    If you have oil around your vent the system is not able to keep up with your engines “blow by”. The valve may be restricted with debris.
    427 sleeper likes this.
  12. BJR
    BJR
    Is the engine tired? Does it need rings or valve seals? If you disconnect the PCV and remove the breather from the valve cover, does lots of blow by come out? If so you have engine problems, not PCV problems.
  13. Blues4U
    Blues4U
    from So Cal
  14. '62 had a road draft tube as I recall. simplest setup if to run your PCV valve in the road draft hole. It should have a baffle in the lifter galley under the intake. if it does not Mr Gasket makes a baffled grommet for the PCV that works perfect.
    You have another option, use a '66 Corvette filler neck if you are using a vintage intake. It has a provision for the PCV in the filler neck and you run an inline PCV. Then breathers on both rocker covers.
    If you are actually getting blow by (get your engine up to temp and remove a breather if smoke comes out that's blow by) you probably have other problems aside from PCV. A way around that is thicker oil, or add Caseite Motor honey. A friend and me had a '65 Impala a 327 car back in the very early '70s, it was horrendous, the motor was wore slap out. We had a 30 gallon barrel of gear lube and that is what we used. Well until the engine finally gave it up and we had to build a new one. :D
  15. onetrickpony
    onetrickpony
    from Texas
    I have seen some engines carbon up the pcv ******, restricting the air flow.
  16. Huckster59
    Huckster59
    motor looks clean inside. now this sat for over 24 years also. i put the pcv on it. before it had two breathers
  17. Huckster59
    Huckster59
    down draft tube has freeze plug in hole
  18. BJR
    BJR
    If it sat for 24 years and you have not put many miles on it, I would run it for a while and maybe the rings will unstick and the blowby will go away. It still may need valve seals, as after 24 years they may be brittle.
  19. Huckster59
    Huckster59
    yep that’s what i was thinking. also valve covers are not baffled so i’m guessing ****ing oil a little. won’t cause the blow by but just another observation changed oil and put some 20w50 val in here.
