Projects My 57 is home
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Jul 19, 2013.
  1. 57 Fargo
    57 Fargo
    It’s only money! What fun would it be if we actually had some! Haha!
    Stogy, 51pontiac, enloe and 2 others like this.
  2. I went through some of what you're doing with the trim some time ago. Like you I have a pile of it. I cherry picked what I had to get a nice set for the windshield and back then learned a lesson. Several pieces of mine had been Pulled out of the rubber instead of Cut out. This stretched the corners out and even though it set in the Rubber and seemed like it fit the Gl*** it sure didn't fit the Body correctly. I had to send the Gl*** guy home while I worked for a couple days to get the SS to follow the Body Curves correctly. This was my last major setback like 2 years ago in that I still haven't rescheduled the Gl*** guy to come back and install either front or back gl***. Yes, my headliner is in and all the upholstery is ready to set in place. I just can't get back to it.
    Stogy, enloe, Thor1 and 1 other person like this.
  3. sidevalve8ba
    sidevalve8ba
    Are replacement heater cores available?
    lothiandon1940 and Jeff Norwell like this.
  4. Squablow
    Squablow
    With a same year Chevy, windshields are cheap new and sedan rears are a dime a dozen. On the other hand, some of the Mopars there's not even a rear window gasket available new.
    A friend of mine did a '55 Buick Roadmaster and had actually driven out of state to buy a whole parts car to get a good windshield, and I got to install it, since no gl*** shop wanted to touch it. Got it in there OK, but that was a nerve wracking job. Lots of stainless on that one too, and a very specific sequence to install the stainless, some in the rubber, some before or after.
    It can be done if you take your time, but I do not envy that job at all. It feels like you're holding a baby in one hand and juggling a chainsaw in the other.
    Stogy, Tim, '28phonebooth and 2 others like this.
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    This is Exactly how I feel and the issue..... a real pain.... I already had a gl*** installer back out because of the stainless trim.
    I have my Painter and my friend Rob(Fabricator) to swing by and help with the install.
    The cost factor(new gl***) and the careful install are a nerve wracking procedure..... combined with the fact.... its original gl***.... and brittle.
    Well, we shall find out.....
    Stogy, hrm2k, enloe and 4 others like this.
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes..... kinda..... My heater core is a truck heater/dealer installed unit.
    This car was a heater delete car.... and the truck unit fit perfectly.... but I should of tested the core before I installed and added coolant.
    I did not and my bad.
    So.. I checked for a 54-56 Ford truck heater cores... most are "out of Stock"... and most seem to be $300-$350.... by the time I ship and pay duty and money exchange.. I am out over $500.
    My Scottish Heritage says no way.
    I do have a local retired rad man that is willing to see what he can do... but,.. its kinda like a racket... only one source brings or imports these in..... and the prices have skyrocketed.
    In reality. it won't stop me.I will just plug it until I find a solution.... Just complain haahahah.
    Stogy, hrm2k, enloe and 3 others like this.
  7. Squablow
    Squablow
    My buddy's Buick windshield had a tiny bullseye in it that was too close to an edge to fill (apparently) and we had to install it with that in there, and I had to beat on that old windshield pretty hard to get it into the hole. A good hook tool (like one of those bent-over pick things that you use to pull cotter pins out) works good to wiggle the lip of the rubber around on the inside, if it doesn't just pop in to place using the rope.
    The key seems to be when you first drop it into place, it needs to be dead-on centered in the hole before you start getting any of the rubber lip in place. It will not want to move side to side once you start pulling any rubber into place.
    Stogy, Tim, Thor1 and 3 others like this.
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I also think... Its a memory time issue when working on mid 50's-early 60's cars.....
    I have never viewed these, any brand, make or Model as a "HotRod"...
    To me(my opinion only).. they have always been a new old car... if that makes any sense..... I view them just as a modified production car.
    saying that.... they are 55-68 years old now.... and like all the vehicles before them...., parts are becoming scarce....... so, rubber, gl***,working replacement parts are getting harder and harder to find.
    Not impossible.. but harder. Anyhow... thanks for hanging out on this ride.I always appreciate the help, the ideas and the encouragement.
    June 1st is my drive date.... damn the Torpedoes, Hell or High water..... I am driving this summer.
    Stogy, 41 GMC K-18, enloe and 9 others like this.
  9. y'sguy
    y'sguy
    from Tulsa, OK
    The thing that most folks don't often realize about an old cars windshield frame is that just like any other panel on the car, the frame is a loop. Like a rubber band, it can get all twisted out of shape or stretch and distort. The gl*** doesn't have that much give to it. It can be a tedious adventure to reinstall especially an old FORD or similar wraparound style piece.
  10. Sky Six
    Sky Six
    from Arizona
    Reading the last page of posts, I sense frustration and a few other emotions. The window installation, both front and rear, is a colossal pain in the rear end along with the headliner. Just realize that you have friends, followers, and it will all p***.
    And finally, just remember that you will have two of the baddest '57's on the planet. DUMP THE CLUTCH and make us all happy.:D
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hahaha. Yes Dan.... I am frustrated on some points.... and you are so right. The finish line is so close.....
    Good news is the interior guy is coming Sunday.... so..... thats half the Push.
    Stogy, 41 GMC K-18, Okie Pete and 5 others like this.
  12. bobss396
    bobss396
    I pressure tested my core, easy since the dash and heater box were out of the car. The core looked like new. I dread taking my back window out and my gl*** guy retired last year, he did a lot of work on high-buck restorations. I'm not even sure I can source a back window for a Custom 300.
    I had 2 pieces of the upper trim for the back gl***. The OG one, I damaged it with the garage door, bad news. I bought another one and the little corner tab is missing. Not a big deal, I'll need someone to silver solder a tab before it goes back on. I too have a bunch of duplicate trim for the car. The best stuff I have in cardboard tubes, I'll eventually sell off the rest. I was able to source all the trim clips for the entire car.
    Stogy, lothiandon1940, Thor1 and 2 others like this.
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Well....a good weekend.
    My buddy Jesse came by and wrapped up the headliner with the wind lace..... so very happy.
    I must say, after watching him work,... its definitely not a job for a wannabe (me).. Not anything I would want to to tackle with zero experience.
    Lots of little tricks and special cuts made to make the whole process easier.
    Very talented guy.
    The Friday and Saturday I prepped and painted the interior trim and garnish mouldings .... so good push forward.
    IMG_5572.jpeg IMG_5573.jpeg IMG_5574.jpeg IMG_5575.jpeg IMG_5584.jpeg IMG_5593.jpeg IMG_5595.jpeg IMG_5599.jpeg IMG_5601.jpeg IMG_5603.jpeg IMG_5604.jpeg
  14. Squablow
    Squablow
    I've done a few headliners in my time, they are tricky. Never got one perfect, despite investing many hours into them, but have gotten them "acceptable" by my standards. Getting one in there even and tight is almost an art.
  15. 57 Fargo
    57 Fargo
    I loves me some white interiors.
    Stogy and Jeff Norwell like this.
  16. y'sguy
    y'sguy
    from Tulsa, OK
    The windlacing makes it perfect.
  17. deathrowdave
    deathrowdave
    from NKy
    Grandma’s steam iron is your friend , an old time friend if my told me he worked headliners at Norwood , Oh , GM factory . He says every seat cover and headliner got steamed .
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes... Jesse had his steamer and used it... looks like a alien from War of the Worlds...
    Stogy, hrm2k, Squablow and 3 others like this.
  19. Sky Six
    Sky Six
    from Arizona
    Well, that explains why mine looked like doggie dodo.
    Your entire interior mirrors the outside, great job.
    The seats are just so cool also.
    Stogy, 41 GMC K-18 and Jeff Norwell like this.
  20. Jeff Norwell
    Jeff Norwell
    MODERATOR
    @Sky Six ...... Dan. the seats and door/rear panels and such will get done one the next winter season....rest of the interior.
    No time or $$$ for that now.
    Stogy, 41 GMC K-18, hrm2k and 6 others like this.
  21. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Oh boy.. here we go.........
    Stogy, Thor1, silent rick and 10 others like this.
  22. I read the other day that the mark of an extremely smart person is to know what you don't know. That's when you call in for help. Most of us can get by. if you want to be better than that, you ask for help. :) I dread your gl*** installation almost as much as you. I do flat gl***. Curved gl*** beats me up. Hold your mouth right and good luck. :)
    Stogy, Thor1, bobss396 and 4 others like this.
  23. 41 GMC K-18
    41 GMC K-18
    It would be so cool, for you to have go pro camera set up to capture the entire installation of the front windshield, so that the HAMB Universe can learn something about how tricky this process can be.
    Even if there is a mishap or mistake, it would be valuable information visually for those that could really appreciate how the installation goes!
    Thanks from Dennis.
  24. 1930artdeco
    1930artdeco
    from Lynden, Wa
    I watched the local gl*** company do mine-front and rear. It 'looks relatively simple' and it is. You just have to take your time and go slowly. Although, the next time may be by the same company-if they still have someone who can do it. If not I will do it myself. Good luck Jeff.
  25. L.O.L. Watching and doing is two different things. It always looks easy when you have experience and know what you're doing. I used to have customers watch me weld and metal finish pieces and they would say "that didn't look so hard". My regular reply was, why didn't you just do it yourself?
    Stogy, Thor1 and Squablow like this.
  26. bobss396
    bobss396
    I used to do curved gl*** by myself, or with my brother. With gl*** running $40 used back then, the risk was minimal. Even being dead broke, we always sprung for a new gasket.
    I had my Ford windshield done by a mobile gl*** guy (now retired) exactly 8 years ago in a pouring rain outside, we were in a dry garage. I was giving him a hand and cringed while he tried to slap the bottom of the gl*** in place... so out it came. That was a fun filled event... not. But we got it done.
  27. atch
    atch
    ...and don't forget to use the corect vocabulary.
    Stogy, Thor1, Jeff Norwell and 2 others like this.
  28. 1930artdeco
    1930artdeco
    from Lynden, Wa
    I am fully aware of the watching vs. doing part. Which is why it will get farmed out if at all possible.:):) I did the side gl*** which was not all that hard, but it is flat gl***.
  29. bobss396
    bobss396
    My side gl*** uses that welting tape, or whatever it is called. So he picked that up from me and brought it back when he did the windshield. Money well spent. He said that the gl*** is 100% made off shore and is a chore to install most of the time. I de-coded where my gl*** was made, some country I had never heard of before. It was wrapped in newspaper, I wish I had saved it. Definitely a very foreign language. I'm used to seeing Czech, Polish and Russian script, but this was stump-the-band material.
    Stogy, SS327, Thor1 and 1 other person like this.
  30. 1930artdeco
    1930artdeco
    from Lynden, Wa
    My windshield was made in Thailand.
