Technical $129 F1 steering shaft or $265 Difference?
Discussion in 'Traditional Hot Rods' started by 28fordroadster, May 11, 2023.
  1. 28fordroadster
    28fordroadster
    Has anyone had experience with the F1 steering replacement worm and shaft to know the difference?
    CPP has it for $129 and Van Pelt has it for $265 Others have it for more.
    Want to know if higher price is better quality. Has anyone used the $129 shaft with no problems?
  2. Is one a repro and the other NOS?
  3. 28fordroadster
    28fordroadster
    Good question I think they are both repops
    anthony myrick likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Van Pelt over CPP
    1oldtimer and anthony myrick like this.
  5. krylon32
    krylon32
    from Nebraska
    You will never go wrong with Van Pelt. Also you might check with nealinCA on here.
  6. banjorear
    banjorear
    Also check with Fred @barnfind08 who is Southside Obsolete
  7. Atwater Mike
    Atwater Mike
    Agreed. Neal rebuilds these boxes, and is deep into them.
  8. stanlow69
    stanlow69
    How much is good steering worth. Most people put little value into it.
    Lone Star Mopar likes this.
  9. NealinCA
    NealinCA
    I'm not sure how CPP is selling those so cheap. They are the same shaft and worm that everyone else sells for double the price. They all come from CHS Steering Components in Argentina and are high quality replacments. Maybe they bought a container load or something to get the price down or they are still working off of pre-pandemic inventory.
    38Chevy454 and Budget36 like this.
  10. TA DAD
    TA DAD
    from NC
  11. V8RPU
    V8RPU
    from Nor Cal
    what does cpp stand for?
  12. alanp561
    alanp561
    Cl***ic Performance Products in Placentia, CA. About equal amount of horror stories and good reviews.
  13. 28fordroadster
    28fordroadster
    NealinCA thanks for your knowledgeable response. I appreciate it
  14. RMR&C
    RMR&C
    from NW Montana
    In the past I have replaced just the worm gear, instead of the entire shaft/gear unit. Was much cheaper, and not real difficult. Dunno if you can still buy the worm gear any more though?
    Budget36 likes this.
  15. Budget36
    Budget36
    Have a “ how to” to press the gear off and put one back on?
  16. AZ_Nick
    AZ_Nick
    Van Pelt still sells the worm gear. I heat it up with an induction heater and pop it off with a gear puller using a big washer on top of the gear to have something to grab on to and then heat the new gear and tap back on. The length makes it a challenge to use in most presses.
  17. Atwater Mike
    Atwater Mike
    I bought a worm only from a Ford truck parts co. in Calif. 4 years ago.
    Not CJ, but they were located in the central coastal region, around San Luis Obisbo as I recall.
    Worm was around $50.
    Easy press operation, used a 'C' type puller to press old one off; Cherry picker lifted my 20 ton press 3 ft. off the floor to get vertical clearance for mast shaft! Made my wife laugh.
    Desoto291Hemi, Budget36 and alanp561 like this.
  18. Atwater Mike
    Atwater Mike
    ^^^^ Good thinking on that induction heater, @AZ_Nick. (open flame torch could affect worm hardness!)
    Was unaware of Van Pelt selling worm only...
  19. RICH B
    RICH B
    Somewhere on here; Neal posted a how-to on removing and installing a worm gear.
    There are also posts on the Ford Barn about the same.
  20. RMR&C
    RMR&C
    from NW Montana
    The old gear comes off in 2 minutes using a thin cutoff wheel. Heat the new gear up in the oven and press back on, or use one of the methods described above.:)
    alanp561 likes this.
