Hot Rods '63 Rambler Classic 550
Discussion in 'The Hokey Ass Message Board' started by Greenblade, Oct 10, 2020.
  1. 64 DODGE 440
    64 DODGE 440
    from so cal
    Pull the pumpkin and carry it into the shop and you take a big part of the time factor out of the job or if you feel adventurous read up on the process and do it yourself on the bench.
  2. 51504bat
    51504bat
    I had 3.50's put in an 8 inch about a year or so ago. 500 bucks parts and labor by an experienced guy with a great rep. And that's in SoCal where everything is expensive.
  3. TA DAD
    TA DAD
    from NC
    It would be worth trying to find a core carrier and you could work on it and when done switch it out and leave the other unit useable. Save some money , buy a few tools and learn something new. Setting up a rearend correctly can be a time consuming process.
  4. Greenblade
    Greenblade
    This weekend I'll be taking the Rambler 200 miles down to scottsbluff for a car show. I'm hoping the Rambler is up for the trip.
    Me and dad got it up on the lift yesterday and shortened up the torque converter bolts that were ever so slightly digging into the torque converter. Was hoping that'd be the cause of noise cure but I wasn't. But while we were down there we also checked for loose bolts(wasn't any) and moved around the exhaust pipe in places that were suspect to rubbing/bumping against stuff. We took a short ride after that to see if the noise went away, and for the first mile, it mostly was gone! Or very quiet. Slowly but surely mile after mile the noise came back to its original loudness.
    So, after this trip to scottsbluff, back up on the lift it'll go, we'll get the new 3.40 gears in and see what can be done about altering the exhaust pipe. May have to take off body and flatten some bits out for extra clearance.
    I feels so close to figuring this out.
    Here's some pics I took yesterday. 20230612_183627.jpg 20230612_183634.jpg 20230612_183742.jpg facebook_1641950940449_6886841397330205596_1044834563463977.jpg 1.jpg
    Same spot many years apart
    vtx1800, Rickybop, Squablow and 11 others like this.
  5. Greenblade
    Greenblade
    First day at the scottsbluff carshow. Heres some pics. found a 62 rambler! And took a pic of a 39 fordor sedan to show that guy building one here on the hamb (but I forgot his name)
    20230616_161641.jpg 20230616_161701.jpg 20230616_185511.jpg 20230616_185522.jpg 20230616_180719.jpg 20230616_180935.jpg 20230616_180300.jpg 20230616_180322.jpg 20230616_170120.jpg 20230616_181155.jpg 20230616_181300.jpg 20230616_181418.jpg 20230616_181501.jpg 20230616_181349.jpg 20230616_183709.jpg 20230616_184634.jpg 20230616_184621.jpg 20230616_184735.jpg 20230616_185001.jpg
    Squablow, 41 GMC K-18, SS327 and 10 others like this.
  6. Greenblade
    Greenblade
  7. Greenblade
    Greenblade
    More show pics 20230617_082532.jpg 20230617_083652.jpg 20230617_084020.jpg 20230617_084357.jpg 20230617_100435.jpg 20230617_100502.jpg 20230617_101209.jpg 20230617_101218.jpg 20230617_101810.jpg 20230617_101815.jpg 20230617_101829.jpg 20230617_102807.jpg 20230617_122651.jpg 20230617_105309.jpg
    here's some more pics of our group Resized_IMG_0179_945613703172559.jpeg Resized_IMG_0182_945627676823588.jpeg Resized_IMG_0184_945639179228464.jpeg Resized_IMG_0181_945648553925381.jpeg winner winner! IMG_8618.jpg
  8. tombstone
    tombstone
    from sk.canada
  9. tombstone
    tombstone
    from sk.canada
    Great coverage …. Love that green olds ? torpedo back ‼️. Good to see all the family cruising together ‼️. Surprised that blue deuce Tudor actually made it ‼️‼️. … you know I’m just bustin his balls
    41 GMC K-18 and Greenblade like this.
  10. Greenblade
    Greenblade
    Last little trip here at the Scott's bluff now we're headed home! 20230618_090914.jpg 20230618_091012.jpg 20230618_090936.jpg 20230618_091209.jpg 20230618_091846.jpg
  11. rusty rocket
    rusty rocket
    A9684020-F552-4DAF-9CB1-CB68B77607C7.jpeg This was the first out of town trip for the rambler. Roughly five hundred miles with out a problem. In fact Brooks helped a gentleman who’s car wouldn’t start by giving him a jump.
  12. i.rant
    i.rant
  13. Greenblade
    Greenblade
    BIG CHANGE UPDATE!!!
    Changed gear and pinion from 2.79s to 3.40.
    Took it for a calm low speed test drive and I'm happy with how it performed. And the best thing yet, the knocking noise has gone away!!! Crossing my fingers that it's gone for good. I'm guessing the gear bearings were bad in that 2.79.
    These new gears are alot zippy-er and there's a bit of a high whine (not nearly as annoying as the old knocking)
    Another thing is the speedometer is now reading 10mph over actual speed so I need to change transmission speed cable gear, higher or lower gear? I don't know which.
    Next thing on the list is to figure out why my taillights are funky and start saving up for a 700R4 transmission.
    Great day!
  14. IMO, the 1963 Rambler Cl***ic was the best looking car to ever come from AMC., The 1964 grill changed the entire look of the car, and not for the better IMO. In 1963, the West Hartford Connecticut police department had Rambler cl***ic's for police cars, but they were 4 door models. I like your car, keep up the good times with it,
    Greenblade likes this.
  15. Greenblade
    Greenblade
    Took it out for the first highway drive with the new gears, drove fine but the speedometer was reading 100 on a 75mph road and everyone was p***ing me. earlier when me and dad were testing the gears on 30-50mph roads it was only reading 10 over. so it seems to get more inaccurate the faster I go.
    so obviously I need a new speedometer cable gear, is there a way I can tell what's in it now without pulling it out or should I just pull it?
    and when I do figure out what gear is in it, would I get a higher or lower gear to get a more accurate readout?
    guthriesmith likes this.
  16. Dick Stevens
    Dick Stevens
    Yes, the inaccuracy is in percentage, not just 10 MPH. I think you can probably search on google to figure out what speedo gear you willl need to get it right
  17. e1956v
    e1956v
    Alliance Vendor
    That much of an error won’t be able to be corrected by a driven gear change. It’s going to take a speedometer gear ratio adapter.
    I have information on the calibration page of my website on the best way to figure the amount the speedometer is off if you want me to build you a ratio adapter. Just hit the link in my signature.
    Let my know if you’d like me to help you out with this. www.speedoservice.com
    Rusty
  18. 51504bat
    51504bat
    @Greenblade good advice from @e1956v plus Rusty is an Alliance Vendor and offers a discount to Alliance members. Something worth considering but that's JMO.
    guthriesmith and 41 GMC K-18 like this.
  19. Greenblade
    Greenblade
    I'll do a mile test sometime here soon. But sounds like from the website, the speedometer itself is messed up besides the gear ratio? Guess I'll see with the test. Now to find a quiet road to measure a mile
    guthriesmith and Papas32 like this.
  20. Davesblue50
    Davesblue50
    Nice Rambler! What year and model is the orange and white pickup in your group? I am drawing a blank.
    Greenblade and 41 GMC K-18 like this.
  21. 41 GMC K-18
    41 GMC K-18
    That is a KB series International, that body style ran from 41 to 49.
  22. Davesblue50
    Davesblue50
    Wow. Thanks. I have never see one in the wild.
  23. In_The_Pink
    In_The_Pink
    That rear end styling is really well done. The way the trailing edge of the trunk flows, then bends back down and flows into the bumper...love it. Flowing' like @Greenblade 's mullet. :D
    Love where the exhaust dumps out, too.
    Hope you don't mind me adding this image of a '63(?) I saw at the Kenosha Homecoming Show last July. Obviously, I was mezmerized by it :cool:
  24. e1956v
    e1956v
    Alliance Vendor
    You can use highway mile markers, just run multiple tests, maybe 3 so you can get a good average. The speed that you run the measured mile isn’t important, a mile is a mile at 30 mph or 60mph. Getting the mile correct may put the speed reading in the ballpark that you’re comfortable with without having to work on the speedometer itself, it’s a personal preference not a mandatory thing.
  25. Greenblade
    Greenblade
    Made a graph. I'm hoping this will help figure out what needs to be done to get the speedometer and mile counter back to an acceptable readout.
    Thanks Dad for helping me with writing the numbers down
    TrailerTrashToo likes this.
  26. Greenblade
    Greenblade
    nice bumper! i wish mine was as straight as that one
  27. Greenblade
    Greenblade
    More info in addition to the graph above.
    Driving 1 measured mile, the Rambler says I went 1.2 rolling 1.3 of a mile
  28. Dick Stevens
    Dick Stevens
    Exactly what I said earlier, it is off by approximately 30%, so if you multiply the speed you want to be driving at you by 1.3, will know what speed the speedometer needs to read!
  29. Greenblade
    Greenblade
    Thanks to @e1956v and the speedometer gear adapter he made, my rambler is now reading proper speed and mileage. This is a huge relief for me, especially since right now is sturgis rally time and the cops will pull you over for anything. Now I can be ***ured I'm going a legal speed. I better watch out on that finicky taillight of mine though! Seriously though, if you need a speedometer adjustment, get in touch with @e1956v . (I sent you a private dm too e1956v)
    And thank you @rusty rocket for the help installing the gear adapter. I can always count on you for help. Love ya Dad!
    Its been a good day. Have a good one - BVP
  30. e1956v
    e1956v
    Alliance Vendor
    Glad it went well and it’s accurate, just remember now you have no excuses if you get nailed for speeding.;):(
