Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. Jim Bouchard
    Jim Bouchard
    Leave them alone. They match the grill.
    New chrome on the lights will contrast against the old grill.
    The car is coming out awesome
  2. 33Doll
    33Doll
    Thanks!
    It’s not like this car is ever going to be out in the rain again…unless I get caught in a quick down-pour from a hot-rod run or something.
    (although I wanna do route 66 at some point!)
    bucket list!!
    Jim Bouchard likes this.
  3. Jim Bouchard
    Jim Bouchard
    This is still one of my favorite threads.
    You are building the car the way we used to
    The family connection is awesome
    The car is coming out really nice
    Be proud of your heritage and of your work.
    But, I know you already are
    Stogy, dwollam, 33Doll and 1 other person like this.
  4. 33Doll
    33Doll
    Thanks man!
    That means a lot! I also like sharing with you guys! One thing that ****s about now…compared to the old days is nobody goes to each other’s houses anymore! We’re all so busy!
    including me! But on the other hand, I’m talking to people all over the world!!!
    Stogy, brEad, -Brent- and 1 other person like this.
  5. dumprat
    dumprat
    from b.c.
    I agree with your wife.
    If they bug you later they are easy to get off and polish.
    Stogy and 33Doll like this.
  6. rod1
    rod1
    Your Dad was a Bad***. I love the shots of the car being used .You have done this car a great service. Great Job on the car.
    Stogy, brEad and 33Doll like this.
  7. 33Doll
    33Doll
    04733BBB-A844-444D-A037-A8D7C012FE06.jpeg 646550A6-0EDF-4928-8E68-40D5A6792B05.jpeg 14D475C0-6D51-4EE2-92F9-711D1ED08B14.jpeg Got alot more done. All wires are run to the right places. Just need to finish hooking up the components.
    Got the Fan All hooked up and wired
    The fuel pump, fuel sender, brake, switch, floor dimmer, wires run to where all the lights go. I also modified the kick panel so I should be able to hide the wires pretty good make some kind of cover for the cut out areas. I have two sets of panels, so maybe I can use the heat gun to tweak some pieces.
    I think what I’ll do….when I make sure everything works, is cut the zip ties on the harness and try to flatten it into more of a ribbon style then it might fit better behind the panel.
    Engine is next, baby!!!
    Did I mention…” THIS WIRING BUSINESS TAKES FOR-EVER”!!!!!
  8. 33Doll
    33Doll
    F4412E6F-885C-4C1E-B05E-96B256D643F2.jpeg 61738D8E-41D2-4FBF-A82E-2E67E35C833A.jpeg C64B15BA-94B1-4267-8386-021B9CE166EA.jpeg D842C136-DF82-429B-8187-1851810EF60A.jpeg So I like speedways parts for the most part, but they’re Chinese knock off ignition, headlight, floor dimmer switches of any kind are pieces of ****!!! The key falls out of the ignition switch and hangs up when you try to put it in positions! The floor dimmer switch plug came completely out of the body cause it wasn’t crimped properly. Tried to fix it but it that pot metal likes to break.!
    So I refurbish the original ones that were in the 33 and tested them. They work fine and I also bought some new old stock parts from the 50s 60s and 70s they were American made new in the box for back up.
    The headlight switch is a 57 mercury. It’s got five contacts on it which is what I need for my speedway wiring kit.
    Outback and Jim Bouchard like this.
  9. 33Doll
    33Doll
    So… I “refurbished” the 71 Ford Headlight switch that was in the 33.
    It works fine. Pulled each pin out of the plug and hooked them up to proper posts. Checked each post in there positions with my tiny computer fan and battery. So maybe it’ll last another 50 years who knows??? I ordered another switch just in case, although it was from the 57 mercury, but it should work for a backup.
    Now I have a working floor switch, ignition switch, and the light switch all original US made stuff!!! 11C2CEA8-986D-44B5-B2F8-80362B1067EE.jpeg E37AE2B5-E833-42EA-80A3-C116B570C713.jpeg EECEB1E7-680F-44D7-8075-C83AE3E63123.jpeg
    No more
    “China” Bill switches!!! The wiring harness, at least, seems like a good quality part???
    Just hope that looks aren’t deceiving!!
  10. 33Doll
    33Doll
    249B4592-6688-4A24-93A2-33F1ECDB3151.jpeg 75456448-7E0A-4EDB-8A2E-C85B58F009C6.jpeg 2AA279E9-1F2F-4320-96D8-DED05C737ECC.jpeg F4AC018B-3325-4075-93B9-FC9354B676A0.jpeg I’m such a goober!!!
    I get these new NOS parts because I’m tired of Chinese stuff…. But now it’s like opening an ancient tomb…and I don’t wanna use them….but… that’s the whole reason I bought them!!!
    It’s like opening a time capsule back to when things were good!!! Instead of this ****y, post Covid world!!!
    Dang!! I actually feel a little guilty.
    I don’t know why I get so emotionally attached to these nostalgia things!
    It feels like when I separated the 33 Dolls body from the frame for the first time in its life! Sad, but exciting at the same time…
    Outback, Papas32 and Jim Bouchard like this.
  11. 33Doll
    33Doll
    ADC027EA-85A7-4A40-9589-40D2B804CCA5.jpeg 8582393C-BEB2-46D7-9841-D6107D4CA1E5.jpeg B3793AC3-9964-44F3-A6BE-83D15314F4B5.jpeg 234E5D54-CFAC-4108-BA66-6554B226AE74.jpeg 16778964-F0C7-4419-A57A-E496031A14AE.jpeg A3294506-7C27-449E-B3C3-3C182EDEF20F.jpeg 5B7651BE-ABD8-401B-8C84-9AAF0E4F9932.jpeg Welp!
    Got surgery on my foot Monday.
    Big toe joint locks up due to arthritis…
    So they will shave down the knob, and clean the joint up, radius the edges etc.
    Got my right foot done about 12 years ago, and it is still working pretty good so I have some relief. Will be couch, bound for two weeks and then light duty for two weeks at work so….
    won’t be touching the 33 for 2-3 weeks.
    But I’m getting prepared to put lights on temporarily so I can finish the wiring and make the plugs so when I put the fenders back on…I can plug them back in.
    I found a way to re-purposed the old Cowl lights I’m turning them into back up lights I will change the amber to a clear bulb, and I will put them on the side of the frame somewhere under the rear apron.
    I got these cool motorcycle turn signals for the front where the fender’s swoop up.
    I am making Nerf bars out of 37 Ford bumperettes, front and rear, so there is no bumpers to block them from being hidden underneath. It’ll look cool trust me!!!
    Stogy and Jim Bouchard like this.
  12. 33Doll
    33Doll
    4A67DDA9-A983-4AE3-A5A8-CC3702370ACF.jpeg 3EB69ECF-1AAC-4948-BF39-4F77131FB22D.jpeg Looks a little done-ur!
    Mocking the lights up for wiring, and plugs for quick connections.
    Some reason the chopped stands make them lean in, gonna have to modify the buckets, so I can clock the bulbs and rings straight!
    brEad, guthriesmith, Tim and 2 others like this.
  13. 33Doll
    33Doll
    [​IMG] SHE LIVES!!!!!!
    YaaaaaaaaaaY!!!
    CC-Mo, brEad, Woogeroo and 9 others like this.
  14. Jim Bouchard
    Jim Bouchard
    HELL YES!!!!!
    That sounds great!!!!
  15. 33Doll
    33Doll
    3E2C391F-903F-4DB9-813C-41613A03D0C4.jpeg Thanks!! I dumped a qt of oil the first start! Forgot to put the extra oil sending plug in!!! But it started with a single bump of the starter! Gotta love electric ignition, and Fuel pump!
    ( sorry TROG guys! Lol!)
  16. 33Doll
    33Doll
    HAHAHA!
    I GOT BUSTED!!!
    The wife went to Starbucks and while she was gone, I was supposed to put the T tops on the bronco and I decided to dial in the fan on the 33.
    She came home and caught me rowing through the gears on the jackstands revving the motor lol.!!
    At least I know the clutch works the driveshaft not rubbing on anything rear end is working, brakes are working!
    And the fan holds it at 160*
    It’s 92 here today so that’s a good sign!!
    I was supposed to be doing honey-dews, and chores before my surgery tomorrow!!
    I guess I just have to stare at it for two weeks. I want to put it on the ground and drive it around the block but just don’t have the time right now.
    brEad, Johnboy34, NealinCA and 6 others like this.
  17. Stogy
    Stogy
    Big Milestone for sure, congratulations 33...as Jim said it really sounds ready to rock and roll...thoughts for a smooth medical day and recovery...
    Jim Bouchard, brady1929 and 33Doll like this.
  18. Tim
    Tim
    from KCMO
    Man I’ve never had anything but a flathead be so eager to start. Sounds great!
    Outback, Stogy, Jim Bouchard and 2 others like this.
  19. 33Doll
    33Doll
    Rick….You idiot!!!!
    So this whole time I’ve been running on seven cylinders. No wonder why I couldn’t figure out what that little pop was on the driver side. I just thought it was a Flathead thing. Well, listen to her now. !!
    Man, I sure wish I knew it was done to this motor because it sounds really healthy. Doesn’t have a bumpy cam, but it has some serious throttle response.
    Tim, Outback, Stogy and 1 other person like this.
  20. 33Doll
    33Doll
    Surgery went Good!
    The pain meds haven’t worn off yet. So I might change my tune! Nothing to now, but wait….think i will take a nap.
    Nighty-nite.
    Tim, Outback, Stogy and 4 others like this.
  21. 33Doll
    33Doll
    D0822A03-1D82-448F-9510-27C4B5B42E81.jpeg ….the pain meds wore off…
    See why they say keep it elevated!
    Soon as that blood rushes down when you step….GIVE ME THE NORCO!
    But The Mrs. Knows I have an addictive “personality” says…
    “You want a a Tylenol honey?”
    … I grit my teeth and…silently think about tying her up!… but… No,
    Women can give birth, and continue to plow a field, while holding a newborn, in one hand, holding a pair of Oxen reigns in the other….
    Me: Silently thinking “I want my Mommy!” …you big *****”!
    Outback, juan motime, CC-Mo and 6 others like this.
  22. Ford blue blood
    Ford blue blood
    You need to edit that picture! The government is going to come for that gas grill........
    loudbang and ottersea like this.
  23. 33Doll
    33Doll
    Is that the latest from the chief commander? No, wood, no gas now?
    Its Ahh-Natur-al. I quit listening to the news, so I don’t know what the hell is going on anymore. I don’t need a coronary.
    -Brent- and Woogeroo like this.
  24. 33Doll
    33Doll
    Someone finally informed me about the gas appliance Nazis coming for us in Cali! Now I get what you said!
    Funny, you know about another states **** before I do!
    that’s how much I pay attention to the
    (Changes daily) **** here!!
    (5 more years and we are outta here!)
  25. 33Doll
    33Doll
    Hi Y’aawll!
    So… those of you Guys who have been following this thread…
    (almost 4 Years or so??) …know I get bored when I am sick or had another surgery! I like to go back through my photos on this build and see how far I have gotten. Because in the “Present” day to day, it doesn’t seem like alot has been done. Which I know isn’t true. But Reality hits when you step back and look at the whole picture. It is pretty Freaking cool!!! I used to enjoy making you tube videos when I wasn’t so obsessed with getting this car done.
    So here is a pretty cool video I put together while my foot is healing!
    Thanks for the HAMB! and you guys… (all over the world by the way! How cool is that?!)….sticking with This-Rambling-Nostalgic-80’s-punker-rocker -Metal Head Weirdo!!
    ~Peace to you all!
    …Rick
  26. 33Doll
    33Doll
    …I think my Pops might have Forgot to put sealer on the water pump, and Thermost housings… in his defense, he was sick when he was cleaning up the Engine block, painting, re-***embling..
    Very Small leaks… but Hella annoying!
    Because I now have to drain, remove the radiator, disconnect my fan, jack up the motor, all to get to that stupid inner
    Bolt!!! Oh well, while am at it… i will take off the chrome crank pulley, and bead blast, and paint, it Flat black, and put a big old white timing mark!
    Since the Light just reflects back in my eyes, and cant see $hit!
    brEad, Woogeroo and Jim Bouchard like this.
  27. Rckt98
    Rckt98
    I hope your recovery goes well. Really enjoying this build thread.
    33Doll likes this.
  28. 33Doll
    33Doll
    Thanks!
    Its a love hate thing!
    Ha!
    Woogeroo and Outback like this.
  29. Outback
    Outback
    from NE Vic, Oz
    Thanks so much for updating this thread, such a cool story/journey. It"s lQQking great!
    33Doll likes this.
  30. Woogeroo
    Woogeroo
    from USA
    You have come a long way, get healed up properly so you can get back to wrenching.
    33Doll likes this.
