Technical Overdrive Bolt Info
Discussion in 'The Hokey Ass Message Board' started by Hdonlybob, May 16, 2023.
  1. Hdonlybob
    Hdonlybob
    I put a 1951 Ford Three Speed OD transmission in my '49 Ford Coupe.
    The solenoid for the OD was missing, so I bought one for it.
    A friend put the transmission in the car, and I am somewhat handicapped, so unable to crawl under the car to see what bolts it requires to install I am asking of anyone can help me out.
    Thanks in advance.
    Cheers...
  2. wheeltramp brian
    wheeltramp brian
    The solenoid is held on by two 5/16/- 16842635821413068778798456063063.jpg 18 bolts that are about a half inch long
  3. Hdonlybob
    Hdonlybob
    Appreciate much !!!
  4. miker98038
    miker98038
    Is the solenoid installed and engaged yet, or is that yet to be done?
  5. overspray
    overspray
    About 18:16 into the video you see how the solenoid goes in to the transmission lined up with the flat side to the slot and then turned about 1/4 turn to line up the mounting bolts and the pawl.
    leon bee and miker98038 like this.
