Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. enloe
    enloe
    from east , tn.
    And we have to be in Bowling Green in a few weeks
  2. It's ready to hit the road brother! Gotta finish getting door gl*** in it for the drag race though.
  3. lumpy 63
    lumpy 63
  4. Probably sling a rod out of it at the race track and be balls to the wall getting an engine in it for Bowling Green lol
    chryslerfan55, Tickety Boo and enloe like this.
  5. swade41
    swade41
    from Buffalo,NY
    I couldn't find a fuel hose that was 2 inch to 1.75 inch, lots of straight 2 inch and 2 inch to 1.5 inch, so I cut the threaded section off of the filler neck
    And welded on an exhaust reducer that was 2 inch o.d. to 1.75 i.d., not supposed to be welding but I got it done complete with a blow through and fill it back in.
    My auto helmet doesn't work after getting a nice flash in the eyes lol, so I used an old school flip, which didn't help matters.
    Then I gave the weld a liberal coat of epoxy that I had used on that intake I had the corrosion spot on, tomorrow I'll give it a coat of paint and source a 2 inch hose to call that job done.
  6. 4speed411
    4speed411
    The Chevy 3 window is back on the ch***is, getting close PXL_20230520_221258726.jpg
    chryslerfan55, hfh, 41 coupe and 9 others like this.
  7. enloe
    enloe
    from east , tn.
  8. squirrel
    I put a door back on the Corvette, and got the latch installed and working. Not much, but it's nice to have at least one moving part on the car functioning again.
    I also am doing a front brake job.
  9. banditomerc
    banditomerc
    Pushing to get the merc ready for paint..
    chryslerfan55, hfh, swade41 and 6 others like this.
  10. Damn squirrel, is the paint on that car as good as it looks on the video?? You did good finding that car!
    enloe likes this.
  11. squirrel
    It's pretty bad, but good enough for me. Yeah, I got lucky. There is more missing than I thought, but most of that isn't too hard to find, I think.
    about 1/3rd of the hardware is missing....I don't know how people do that.
  12. swade41
    swade41
    from Buffalo,NY
    Marked out and ready to cut some fins, think I might try the hole saw method again
  13. 57 Fargo
    57 Fargo
    Installed the previously owned clutch and the newly resurfaced (80 grit on an orbital) flywheel on the 318 for the ‘64 Barracuda project. The four speed is bolted up and engine and transmission sitting in the car. IMG_4436.jpeg
    One step closer
  14. BJR
    BJR
    Tomorrow the Th400 goes back in my 49 Buick. Hope it lasts more than the 4 miles it went last time.
  15. saltflats
    saltflats
    from Missouri
    Working on some heads for my friends 55 post car.
  16. 51504bat
    51504bat
    Back in the '70's I worked as a mechanic at a local dairy. We "surfaced" many heads, exhaust manifolds, and flywheels by rubbing them on the concrete floor of the shop when time or budget issues prevented sending them out to the machine shop.
  17. 57 Fargo
    57 Fargo
    I actually think the flywheel was new, it was painted green. It came off an engine that had been used as a training aid for ***embly/dis***embly at the college here. I sanded the paint off and it looked perfect
  18. We're so much alike man :D:p
    alanp561 and 57 Fargo like this.
  19. -Brent-
    -Brent-
    Putting the fuse block in the back of my Model A.
  20. Dang son! You win for the sweetest fuse block mounting panel hands down! :cool:
  21. -Brent-
    -Brent-
    Thanks! It's a bit overboard/absurd... I do that sometimes. Hahaha.
  22. swade41
    swade41
    from Buffalo,NY
    I row done before heading off to the doctors, going pretty good
  23. BJR
    BJR
    Got the 2nd time rebuilt transmission back in my Buick. Works good so far.:)
  24. squirrel
    Fiddling with plastic....glued the console back in. I love the way this stuff looks in these cars, with the wrap around stainless trim running around the seating area.
  25. Jibs
    Jibs
    I'm helping my cousin with his 32 5 window, that he has owned since 1964. It was a C/Altered, ran infrequently at Pittsburgh International Dragway until it closed. Typical East coast rod, channelled, no chop.
  26. Just finished rebuilding my AOD with tons of help and advice from fellow Missourian Saltflats. Now I need to put the transmission together with the 351W I rebuilt last year, get the slippery fluids in both, the coolant in the engine, wire it, plumb it for fuel, jury-rig an old Explorer radiator to cool it while I break in the engine and just see whether I screwed up and where. I'm on year 49 of this project. Didn't expect it would take this long when I started it back in June 1974. I apparently have been suffering from delusions of adequacy.
  27. The37Kid
    The37Kid
    Moved a 4x8 table in the ba*****t and regained access to the file cabinets. Lots of stuff I forgot I had and plan to turn into project funds.
  28. image.jpg This is the engine and transmission we picked up at French Lake Auto Parts today for our 1950 3100 project. Now, I just have to finish the engine installation into Little Truckdoctor’s Cub Loboy 185 to free up shop space. Do you guys know if the front fenders and grille will come off of a 1950 Chevy truck in one piece, or do I have to dis***emble it?
  29. They should, Td. They will on a Buick. One CAN'T remove the bell housing from a Buick as has been done on that Chevy. Lot more must be removed first.
    Ben
    Truckdoctor Andy likes this.
