Technical B.W. Overdrive electrics
Discussion in 'The Hokey Ass Message Board' started by Skylaker, May 10, 2023.
  1. Skylaker
    Skylaker
    Getting 51'Merc ready for the season here in Michigan. 255 Flathead with B.W. Overdrive 6v.
    At some point before the Relay had been replaced with a starter Relay/Solenoid.
    Over the Winter I bought a Solenoid and Relay. After further inspection I noticed a rattle in the relay, and found the contact point floating inside the case.
    So I looked at the Solenoid, I noticed the contact point on the top(plunger) is missing.
    Question is, does anyone rebuild these or are the paperweights now?
    Deuces likes this.
  2. jaracer
    jaracer
    I "rebuilt" the horn relay on my 57 by removing the guts and putting a mini relay inside. I connected the terminals to the original relay terminals. With the can on it looks very original.
    46international and 302GMC like this.
  3. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Someone here or on Fordbarn posted something to the effect that he had solenoids for sale. Old age and brain fog prevents me from giving more info. A thorough search might help.
  4. tubman
    tubman
    If you haven't already done it, the first thing you should do is get back to the seller, who basically sold you junk.
  5. overspray
    overspray
    IS THERE ANYONE THAT KNOWS & REPAIRS OVERDRIVES? Here's the wiring diagram to use a bosch relay in place of the stock Ford/Mercury relay. If you want you can remove the "innards" of the original relay and put the bosch relay inside the housing.
    Skylaker likes this.
  6. Some Guy
    Some Guy
    I used a 30amp relay for off-road lights and hid it under the original cover.
    1oldtimer likes this.
  7. banjeaux bob
    banjeaux bob
    from alaska
  8. Deuces
    Deuces
    Where in Deatborn are ya???... I'm at Ford rd. 1/4 mile east of Henry Ford's birth place.... Howdy neighbor!...:cool:
  9. Skylaker
    Skylaker
    Pelham and Outer Drive.
    I'm running 6volts. But I like the idea.
    Deuces likes this.
  10. dan c
    dan c
    i think i talked to you on another forum. a mid-'60s mopar starter relay will work.
  11. Skylaker
    Skylaker
    I think you did, I think you referred to a 12v system?
    Deuces likes this.
