Have a problem with my motorcycles rear tire Help???
Discussion in 'The Hokey Ass Message Board' started by kustomd, Sep 21, 2006.
  1. kustomd
    kustomd
    I rode my bike about a 70 mile trip a week or two ago well I got back then the next morning I got up and decided to go for another ride well I got out there and the back tire was flat. I aired it up and it went flat right back again well the other night I decided to try and find out what was wrong well it turns out every spoke on my rear wheel is leaking!! I tried tightening them up but it still leaks. What should I do? Its also a tubless tire.
    I've never ran into this problem before.
    Oh yea my bike is a vlx600 shadow that I hardtailed.
  2. REJ
    REJ
    from FLA
    There should be a piece of rubber that goes around the inside of the wheel, where the spokes are, that keeps the air from leaking around the spokes.
  3. rizzorace
    rizzorace
    add an inner tube if all else fails
  4. Kustomz
    Kustomz
    That strip of rubber used is actually to keep the spokes from rubbing on an innertube. I would just put a tube in it and be done with it.
  5. ray
    ray
    from colorado
    just because the tire is tubeless doesn't mean the rim is! if it's a spoked rim, run tubes. only exception is if the ******s are siliconed over as done on some car rims, but rarely on bikes. the rim strip is only to protect the tube from abrasion from the ******s.
  6. touchdowntodd
    touchdowntodd
    word, tube with EVERY spoked wheel... no exceptions...
  7. zman
    zman
    from Garner, NC
    Actually there are plenty of exceptions.... Just FYI... My Jag wires on my Buick are tubeless... as well as a lot of the newer spoked rims on bikes...
    Most of them have o-rings and sealer... but the easy fix is to just throw a tube in her...
  8. oldspeed
    oldspeed
    from Upstate NY
    Motorcycle rims that use spokes need tubes, the spoke is always moving during operation and will never seat well enough to hold air pressure. To fix the problem you could try to seal each ****** or just run a tube.
  9. zman
    zman
    from Garner, NC
    Bet?
    Not saying they're foolproof, but there are more than a few out there... And if you're running Radials they actually make specific tubes, not sure the difference.... The first time I saw them I was skeptical. But the '94 KTM Duke had them. Pretty neat set up as well... I believe they used a nylon tape over the ******s as well...
  10. Hoptup Jalop
    Hoptup Jalop
    nope....my bmw has spokes and no leaks!!
  11. Hoptup Jalop
    Hoptup Jalop
    i saw in some chopper rag a while back that has a spray/brush on type sealer that eliminates the need for tubes on a spoked rim....
  12. oldspeed
    oldspeed
    from Upstate NY
  13. Take a close look: your BMW has spokes that end up on the EDGE of the rim.
    Seriously, where ever did you get the idea that you could put a tubeless tyre on a spoked rim without a tube?? Spokes go through HOLES in the rim, holes let in AIR (also out). Tubeless tyres work much better if the air stays IN the tyre, however, a tubeless tyre has a large OPEN section quite near the holes in the rim. This leads to a flat-ish condition.
    Go buy a tube, put it in like we have been doing for more years than not, and go riding.
    Cosmo
    P.S. There may be certain ways of getting around tubes in spoked wheels, but none of them are anything other than for show ONLY. Getting a flat while running at speed is often fatal, always painful, and a tube costs less than a dime note. Most hospital stays are more.
  14. zman
    zman
    from Garner, NC
    Ssshhhh... don't tell the Super-Moto guys that, they'll be bummed... :eek::D
  15. kustomd
    kustomd
    Where can I find a tube for my bike for a reasonable price? It has I believe a 170/70 15" tire or maybe a 170/80 15" tire?
    My bike came with tubeless tires with spokes from the factory. and it has radials I believe. I know the tread looks kind of like some of the sport bike tires I see. except mine are white walls.
  16. johnnykck
    johnnykck
    Yes I agree! There are company's that have made spoke wheels with a rubber seal on the inside of the rim, but after a while they all leak and lose air, best thing is to always put a tube in a spoked motorcycle rim no mater if the tire is tubeless or not!!
  17. I wouldn't put a tube in a radial tire.............but I see it done all the time.
  18. cleatus
    cleatus
    from Sacramento
    While you're at it check your spoke tensions. There is a reason it suddenly started leaking after all this time - Most likely because your spokes are getting loose and moving the ******s around a bit which then broke whatever the factory put in there to seal them up.
  19. oldspeed
    oldspeed
    from Upstate NY
    I just checked with my buddy that has a new KTM Duke, we went to see this bike. He has spokes with radials and guess what KTM uses tubes. So they have radial tubes for motorcycles. He did tell me that there is a racing wheel shop in Ca that convert these to run tubless but they have a seal under each ****** and teflon tape to the threads on the ******s, I don't know what the super motards are running, but if it was me I run a tube.
  20. zman
    zman
    from Garner, NC
    Which Duke? The first ones (1994) were indeed tubless spoked rims. Sorry if you saw one with a tube in it. And they had a seal on each spoke as well as tape...
