Technical Gas in oil
Discussion in 'The Hokey Ass Message Board' started by SIDNEY SWEIGART, May 22, 2023.
  1. SIDNEY SWEIGART
    SIDNEY SWEIGART
    Does anyone have info on a inline pressure regulator for fuel line. I have a stromberg carb and it only wants 6 lbs of fuel pressure. My electric fuel pump is 12-15 lbs, I think that's my problem! I rebuilt the complete fuel system, and New tank. Any help is appreciated. Sid
  2. Budget36
    Budget36
    Many low pressure regulators out there. I think 3/4 psi is about the most you want to the Stromberg. I used an off shoot of a Holley, worked fine for my 221, but Holley’s are readily available, I’m sure many others.
  3. SIDNEY SWEIGART
    SIDNEY SWEIGART
    I just moved to a new County and found a new speed shop. He cut my Drums/ Hubs, and trued them. I'm hoping he can fix me up. Thanks budget!!:)
  4. Bandit Billy
    Bandit Billy
    Stromberg 97's run 2 to 3 PSI. I use a Holley 12-804 on mine, they come preset at 2.8 PSI and easily adjust.
  5. pprather
    pprather
    gimpyshotrods and Budget36 like this.
  6. ClayMart
    ClayMart
    Did you mean 3 to 4 pounds? 3/4 makes it look like 3 quarters of a pound.
    o_O
    Andamo and Budget36 like this.
  7. ClayMart
    ClayMart
    Also remember that a leaking diaphragm in a mechanical fuel pump can leak fuel into the crankcase.
    :mad:
    pprather and theHIGHLANDER like this.
  8. Budget36
    Budget36
    Lemme fix it for ya “3-4 psi” ;)
    Bob Lowry and ClayMart like this.
  9. Charlie's Speed made mine
  10. Blues4U
    Blues4U
    from So Cal
    Those dial type regulators are known to leak if the supply pressure is very high, I had a couple of them do that on me, left me stranded on the side of the road with fuel spraying onto the engine and even up onto the windshield. They're not great at regulating pressure either. Real POS's. I changed to a Holley regulator and have had no more problems.
    Bandit Billy likes this.
  11. gene-koning
    gene-koning
    If your electric pump is putting out 12 psi, and you only need 3 to 4 psi, you may also have to add a fuel return line to the tank from the regulator. Some regulators can't reduce the pressure if it deadheads against a much lower psi carb need, they need to return the excess fuel and its pressure back to the tank.
  12. Bandit Billy
    Bandit Billy
    Good advice Gene. My in-tank pump delivers a large amount of fuel pressure and gallonage per hour. I had to knock it down with a carburetor type reg with a return line on the frame rail (Holley - don't recall the part number) and then into the 12-804 mounted to the blower to dial it down to 2.5
    41 GMC K-18 likes this.
  13. carbking
    carbking
    What Stromberg carburetor do you have that likes 6 psi?
    As to regulators: as others have mentioned, an effective fuel regulator will have an internal pressure byp***, with a return line going back to the tank.
    The inline dial-type regulators available at most FLAPS are also extremely useful.............***uming you have a strong right arm, and a rabbit problem in your garden! :p:D;) If clean, they may also serve as paperweights.
    Jon
  14. 2.5 pounds max, any more and you wind up with gasoline diluted oil. Charlies speed makes a clean stainless system with a 0 to 10 pound gauge and regulator. also has excellent how to video's
    51 mercules and gimpyshotrods like this.
  15. ClarkH
    ClarkH
    Malp***i Filter King.
    big duece and gimpyshotrods like this.
  16. gimpyshotrods
    gimpyshotrods
    Those are good, too.
    They have a more old-timey look, unlike a Holley.
    big duece likes this.
  17. 51 mercules
    51 mercules
    Ran six carbs and only 2 1/2 psi
  18. AccurateMike
    AccurateMike
    I would chuck the 12psi pump and get a Facet or similar low pressure pump. 1.5-4 psi. 1103-2012.jpg Less to go wrong. Mike
    2Blue2 likes this.
