Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. mad mikey
    mad mikey
    Ahh , No laughs here. You built it, you are driving it, and you are going to run it. That is a win win win! :)
  2. Lloyd's paint & glass
    Thanks brother ;) I just went out and changed the secondary spring to the white one. See how it does, hopefully no bog.
  3. alanp561
    alanp561
    It is a small place and they do have it for the foreseeable future.
    In regard to the use of Ethanol in aircraft engines, the most common problem is the phase separation of Ethanol added gasoline which occurs when the aircraft is flying at different al***udes and temperature changes. The Ethanol gasoline breaks down and water forms which can flood the engine. Not a good thing because the engine can quit. Both Continental and Lycoming continue to build LL100 powered engines. Both are experimenting with diesel power.
    chryslerfan55, 427 sleeper and SS327 like this.
  4. SS327
    SS327
    I don’t care if it rains or freezes long as I got my plastic Jesus glued to the dash board of my car!
    Courtesy of The Pink and Plastic Plastic Icon Company of Del Rio Texas!
  5. alanp561
    alanp561
  6. SS327
    SS327
    Look up the original version from 1961 or 2. It’s hilarious! The Goldcoast Singers!
    alanp561 and 427 sleeper like this.
  7. 427 sleeper
    427 sleeper
    I've been using Torco Accelerator and am happy with the results, no detonation w/11.25 CR. It seems to stabilize the gas (93 octane E10) over the winter, too. YMMV :D
  8. SS327
    SS327
    And to think I was crying about $5.35 a gallon Union 76 108 octane for my daily driver El Camino back in the early 80s!
    mad mikey and 427 sleeper like this.
  9. tomcat11
    tomcat11
    Hey Lloyd, wanna make more power? Not trying to break your balls but, the A/F distribution on that manifold with a single 4 top is really bad. Not sure how the rest of your engine is built but, a 2 x4 top has a lot better distribution even if over carbureted. Or wake it up with good dual plane. :cool:
  10. Lloyd's paint & glass
    Yeah I got over that a while back, it's a dual plane weiand now. Much better. I sold both single 4bbl tunnel rams.
  11. Lloyd's paint & glass
    Back home, last night I closed the choke plate ever so slightly, put the short white spring in the secondary. About 5000 it's got a little bit of stumble. Pisses me off. 20230523_100107.jpg
  12. patsurf
    patsurf
    send it down to gary...
  13. Lloyd's paint & glass
    Lmao!! No...
    427 sleeper and J. A. Miller like this.
  14. Lloyd's paint & glass
    Serious question here, should I unhook the vacuum advance and go try it? My distributor has the adjustment in the vacuum advance and I never checked the timing after I hooked up the vacuum.
  15. saltflats
    saltflats
    from Missouri
    If the throttle is wide open the vacuum advance isn't doing anything at that time.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
  17. Lloyd's paint & glass
    No.
    chryslerfan55 and 427 sleeper like this.
  18. Lloyd's paint & glass
    When it hits 5000 it starts that popping ****, I can lift a tiny bit and it quits, or shift and it quits
    mad mikey and chryslerfan55 like this.
  19. Lloyd's paint & glass
    Just making sure. I believe the screw in the advance is backed all the way out so it advances quicker, is that correct? It has the least amount of resistance the way its set right now
  20. Lloyd's paint & glass
    Maybe when momma gets home from work this evening I'll get her to ride with me and video what it's doing so I can show everybody.
  21. Lloyd's paint & glass
    Gotta be the fire breaking down, right? Is it the dang coil? It was horrible with the hei, put this distributor in and made it 10 times better. Or, does the fact that i can let off of it a little and it straightens up man that it's leaning out? Never in my life did I think that a 283 would need any more gas than I'm giving it. It has stock power pack heads with 1.72 valves lmao!
  22. saltflats
    saltflats
    from Missouri
    What is your total timing at?
    mad mikey likes this.
  23. lumpy 63
    lumpy 63
    This isn't gunna be another 54 wcfb thread is it?:p
  24. J. A. Miller
    J. A. Miller
    from Central NY
    Come on boys, didn't you learn that things have to be done logically!:rolleyes:
  25. Lloyd's paint & glass
    36⁰ at around 2800 rpm. With the vacuum advance unhooked.
  26. Lloyd's paint & glass
    I'm telling you it's my secondaries!!! :p
  27. saltflats
    saltflats
    from Missouri
    What do the spark plugs look like?
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What valve springs (engine not carb)?
    chryslerfan55 and lumpy 63 like this.
  29. Lloyd's paint & glass
    Speak plugs look good, #1 and #2 anyway. Ash mark is just before the bend on the ground strap.
  30. Lloyd's paint & glass
    Stock, all he did was check them, don't remember the seat pressure. But it's not valve float in my opinion, if I let up on the pedal it'll continue to climb up the tach
    enloe, mad mikey and chryslerfan55 like this.
