Projects "Saving" a Studebaker
Discussion in 'The Hokey Ass Message Board' started by Jacksmith, Dec 14, 2022.
  1. Jacksmith
    Jacksmith
    from Aridzona
    So, while fiddle-fartin' around the shop, I've gotten a few things ironed out...
    The gas tank is in...
    The exhaust system is all but finished...
    The front seat (what there is of it) was installed & upholstered with the finest quality fabric that a '70's moving blanket could provide. Unfortunately the slider tracks are locked up & won't budge. Marvel Mystery Oil to the rescue there... however, the retracting seat backs are functional! You can lay these babies flat out & flush with the back seat. Very handy at the drive-in, I suspect... IMG_1862.JPG IMG_1863.JPG
    The tach found a home...
  2. Six Ball
    Six Ball
    from Nevada
    That is a lot of progress. Great work.
    Jacksmith likes this.
  3. Jacksmith
    Jacksmith
    from Aridzona
    The tail pipes are all welded except for the very last sections which will be 3" stickin' out the back. I've got the reducers required to finish the tail pipes, but I need to flip the shackle bolts to clear the 3" tail pipes. The leaf spring bushings are pretty fried, so they'll need to be replaced before I can do that.
    I had a new driveshaft built and the work is exceptional. However when I gave it a trial fit, the yolk won't go into the trans far enough. Grrr... I've got a new seal and bushing (not yet installed) and they fit the yolk perfectly, so I know the yolk is correct. It seems that there is just enough gunk on the splines of the output shaft to hold it back. For the time being I'm soaking the splines with good ol' PB Blaster to soften what ever the hell that gunk is, using a needle hook and and a gun barrel brush to clean out the grooves.
    Man if it ain't one thing it's three others.
  4. Jacksmith
    Jacksmith
    from Aridzona
    In the interest of having a bit more useable space, I moved the Lark to the center bay. IMG_1887.JPG
    For a change of pace I decided that I'd start the clean-up & upgrade of the engine, so out it came...
    With the block cleaned and a coat of paint done, the head studs are installed. IMG_1926.JPG Engine mounts got a set of Mr. Gasket bolts I found in the bin... IMG_1927.JPG
    More parts are on order and for giggles I ordered the rear tires. piecrust-1.jpg
    Torkwrench, bchctybob, Chucky and 8 others like this.
  5. Jacksmith
    Jacksmith
    from Aridzona
    IMG_1935.JPG IMG_1936.JPG IMG_1938.JPG Got the cam in, waiting for a ****on to check end-play.
  6. Six Ball
    Six Ball
    from Nevada
    That will make some noise, very mechanical. :cool:
  7. Jacksmith
    Jacksmith
    from Aridzona
    It is (supposedly) a "quiet " version... we'll see. I really don't mind the noise though, it reminds me of my ol' Pan-Head.
  8. Jacksmith
    Jacksmith
    from Aridzona
    While wondering through the Auto Parts section of CL, I stumbled onto an add for a '60 Studebaker Lark 2 dr. sedan being sold as a parts car... It was very in-expensive due to the lack of an engine and a major "ge-duge" in the back. It had, however, a bunch of stuff I could use to improve my project car. Turns out it was about a mile & 1/2 from my house. (Really??)
    I called, set up a time to look at it, and, well...
  9. Six Ball
    Six Ball
    from Nevada
    The front looks good. You can never have too many Studebaker parts. A least that is what my son & I tell my wife. She's not buying it! :(
  10. In_The_Pink
    In_The_Pink
    That close = 99% chance of coming home with it....maybe higher.
    bchctybob and Jacksmith like this.
  11. Jacksmith
    Jacksmith
    from Aridzona
    I had to take a minute to wrap my head around the price and the close proximity to my place! I guess even a blind squirrel finds a peanut once in a while!
    bchctybob, lumpy 63 and bobbytnm like this.
  12. Jacksmith
    Jacksmith
    from Aridzona
    So here's the scoop; In '77 this 6 cyl. 3 speed/O.D. daily driver was on it's way home from work. While waiting to make a left turn 2 blocks from home, it got ***-ended by a drunk driver.
    The impact was brutal, broke the back of the driver's seat and put him in the back seat! The frame was broken off in front of the right rear rear spring shackle.
    The car was dragged home, parked in the back yard and didn't move 'till I put it on my trailer. With only 57,000 miles on the odometer, there are still a lot of great parts here to make my car better:
    bchctybob, Torkwrench, egads and 7 others like this.
  13. bobbytnm
    bobbytnm
    Wow, nice find.
    I wish I could stumble upon something like that around here. The 259ci in my Champ is a bit loose on the bottom end. I have a few leads on a replacement engine, but dang! It would be great to find something with that low of mileage on it.
    Of course, my ol' lady would have a few things to say about it.......LOL
    bchctybob, Six Ball, SS327 and 2 others like this.
  14. 327Eric
    327Eric
    Be careful with that at***ude. One Studebaker begets two, then a parts car or two, and those fenders, and soon you have 22 Studebaker's in 4 counties. At least that was me in the 90s.
    bchctybob, rod1, Jacksmith and 2 others like this.
  15. Six Ball
    Six Ball
    from Nevada
    I have 2 Larks and 2 Conestogas in the yard. There are 10 or so 359 engines and a few OD ******s at a friends in Texas. If I ever get my flatbed back on the road I've thought of picking up the Texas stash and distributing them to the needy in my way back to Nevada. :rolleyes: A really cool road trip? :cool: Probably won't happen. :(
    That parts Lark was a great find. I hope the engine & trans find a way to someone's driver. Being an inline guy I know there is a home for it out there. Do the front fenders have the usual rust by the doors? Maybe Arizona saved them.
  16. Jacksmith
    Jacksmith
    from Aridzona
    Yeah I agree, I feel lucky to have found this car... The engine is long gone but the trans is in the back seat. I've toyed with the idea of using it, but I doubt it would be stout enough for the V-8. I'll sell it if someone can use it.
    As for the fenders, (& doors) they are absolutely rust free! The floors have surface rust but are basically solid. It has the complete clutch pedal & linkage including the cross tube. All the gl*** is excellent. The dash-board is a cream puff. The dash in the green one is funky and all the switches and so forth are locked up, so I'm swapping out the whole dash & steering column.
  17. Six Ball
    Six Ball
    from Nevada
    The pilot bushing part of the pilot shaft is different for L6 & V8. There are different sizes for the bearing retainer too but they both fit the case.The BW OD is fun to drive. It is probably a T86 & R10 OD. My son went through a few of those with the supercharged 289 in his Conestoga. I'm putting one in my roadster with a 153 Chevy 4 cylinder.
    bchctybob likes this.
  18. Jacksmith
    Jacksmith
    from Aridzona
    I've been shoveling ap-kray from the interior of the orgin donor... looks like I've got me some floor board replacement panels. Ha-ha I bet they fit better than aftermarket panels!
    The O.E. sound / heat shield is in remarkable condition. I'm going to attempt to surgically remove it for aesthetics.. Wish me luck, it seems pretty brittle.
    I'm changing the steering column and dash board as well.
    I also got a closer look at the broken frame... man that had to have made a gruesome noise!
  19. Jacksmith
    Jacksmith
    from Aridzona
    Although my main objective is to move forward toward getting this car up & running, I'm still taking it apart.
    The original dash is very rough and has a fair share of rust. After determining that the dashboard controls are all inoperable, I've decided that a dash transplant would be the best option. The dash on the organ donor is pretty nice, all the controls (except the heater control) work very well. So... IMG_1982.JPG
    In typical Studebaker form, the wiring is a rat nest of tangled confusion. Wiring is not my strong suit, but I'll sort it out and get some organization... Ugh, sometimes it seems like I'm trudging through quicksand.
  20. BLACK STUDE
    BLACK STUDE
    I rewired my 55 stude with a Painless wiring harness. It was a pretty simple install and has been trouble free for years. Best money I ever spent on that car. I’m no electrical genius either but the instructions were easy to follow and I got through it.
    bchctybob and Six Ball like this.
  21. Jacksmith
    Jacksmith
    from Aridzona
    Yes, I agree that Painless kits are the standard these days.
    Since the wiring in both cars are in remarkable condition all things considered... not brittle and completely intact, I'll see if I can just comb them out enough to not look like spaghetti.
    Swapping the dash and getting the controls working will be a big step forward.
  22. Six Ball
    Six Ball
    from Nevada
    We used a Painless set on my son's '54. Some of the stock Studebaker wiring was nit as straight forward as I was used to. The turn signals were down right weird, but if you are just cleaning up and swapping controls you should be fine.
  23. In_The_Pink
    In_The_Pink
    It appears to have sat out in the open without a windshield, and the paint was baked away by the sun? I think you made a wise decision to swap dashes, if so.
  24. Jacksmith
    Jacksmith
    from Aridzona
    Yeah it does appear that way... I was told that the windshield was laid in place... with the rubber on it, but not actually installed. I do know that it sat out for around +/- 40 years in the Arizona sun. (Coincidentally, the white one did also)
    The white one faired much better. It may have been at least partially shaded judging by the lichen around the side trim. What ever the case may be, I'm using the best parts from both cars to attempt the "Saving" of one.
    bchctybob and guthriesmith like this.
  25. Jacksmith
    Jacksmith
    from Aridzona
    The rear tires arrived today. After mocking them in place, I've determined that I'll need a deeper back space on the wheels so I don't have to mess with the openings to mount them... Wheel Vintiques has what I need so I ordered a pair from the nice folks @ Summit. IMG_1993.JPG IMG_1994.JPG
  26. Jacksmith
    Jacksmith
    from Aridzona
    UGH! The wheels came in, but they are not going to work... My intention was that a deeper back-set on the same size wheel would afford the extra clearance between the fender-well and the tire. Turns out my wheel gauge is out of whack; I thought I had 7" wheels, but they're actually 6-1/2" wide. So when I ordered 7" wheels, the increased back-set is mute. O.K., pain is how we learn. IMG_1997.JPG
    Back to the drawing board...
    bchctybob and SS327 like this.
  27. Six Ball
    Six Ball
    from Nevada
    There's a MOPAR wheel that came on a van I think that worked well on my son's '55. when it had the stock rear end in it. They were not easy to find. They are shallow in the front with a good offset on the backside. Pretty sure they are 7".
  28. Jacksmith
    Jacksmith
    from Aridzona
    Thanks, 6, I'll talk with W.V. on Tues. and get what I need... now that I know what that is!
    Six Ball likes this.
  29. Rynothealbino
    Rynothealbino
    What are the rear tires? Towel city it looks like? I have been looking at those for my '54 in one of the skinnier sizes.
    Still running the stock rear end, but things are getting too wide, right? That's what I was running into on mine. Could always pop the center out and increase backspace?
    Or I will come visit you and narrow an 8.8" if you come visit me and put exhaust in our Lark? Looks amazing by the way. What size of tubing and brand of ball and socket joint are those? I've never used them before, do they work good?
    Six Ball and guthriesmith like this.
  30. Jacksmith
    Jacksmith
    from Aridzona
    Yeah, those are Towel City 15 x 8". I need 1/2" more room between the fender lip and the tire. Deeper backset on the wheel will do it. IMG_1998.JPG
    I'm sticking with the Dana 44. I've got two of them, one's a 4.56 for bar hoppin' and one's a 3.31 for road trips.
    I'm using 2-1/2" pipes because they fit nicely on the header collectors. Probably a smidge too big, but I can live with it. The tail pipes after the diff are 3" for obnoxious effect. (should sound bad-***)
    I got the ball & socket joints right out of Summit. I used them on the coupe and they work quite well with no leaks at all. The sweet thing is if you need to you can just un-bolt them, pull the trans, or whatever, then bolt 'em right back on when you're done... no gaskets or anything else to fuss with.
    I mounted the front bumper from the white car on the back of the green one and it fits like a glove. The original got bopped along with the right rear quarter panel many moons ago.
    Kind of ironic; both Larks had 1973 Az. plates on them, they both got hit on the right rear and they both sat outside ever since...
    bchctybob, lumpy 63 and Six Ball like this.
