Hot Rods BBC Rough idle with new carb, plugs, wires, cap
Discussion in 'The Hokey Ass Message Board' started by shedhouselife, May 24, 2023.
Tags:
  1. shedhouselife
    shedhouselife
    I replaced the plugs, wires, cap and carb. The BBC runs smooth all but when idling. It sounds like it's missing. I held my hand over carb when the engine was warm and while running and the idle speed increased quite a bit. Am I too advanced on timing?
  2. lostone
    lostone
    from kansas
    Sounds like vacuum leak
    Deuces, swade41, jaracer and 2 others like this.
  3. 427 sleeper
    427 sleeper
    Why did you replace the carb? Cutting off air to the carb shows that it's lean.
  4. Lloyd's paint & glass
    What is the timing set at? I'll second the vacuum leak though. Spray some carb cleaner around the carburetor and see if the idle changes
    shedhouselife likes this.
  5. squirrel
    did you play with the idle mixture screws?
  6. tomcat11
    tomcat11
    It would be helpful to provide more details on the engine like displacement, stock or modified, current timing, carb size/type and Jetting.
    Deuces and shedhouselife like this.
  7. shedhouselife
    shedhouselife
    454 V8 with stock intake, brand new Quadrajet. I don't know the timing or jetting. Just bought the car. I did notice that there was oil on top of the intake manifold and the bolt next to it was loose.
  8. shedhouselife
    shedhouselife
    I haven't touched the carb yet. It was brand new when I bought it. I bolted it on and it fired right up.
  9. shedhouselife
    shedhouselife
    I don't know what the timing is yet. Just got a timing light. Haven't ever used on before.
    Lloyd's paint & glass likes this.
  10. shedhouselife
    shedhouselife
    Thanks. I changed the carb because the one on the engine was a 600 CFM and the 454 V8 came with a 750 CFM.
  11. shedhouselife
    shedhouselife
    Y
    Maybe the intake manifold.
  12. SS327
    SS327
    Replace the intake manifold gasket. Then get back to us for carb tuning instructions.
  13. tomcat11
    tomcat11
    Maybe start with making sure all the intake manifold bolts are tight and make sure the carb to intake gasket is sealing and try your test again. As Lloyd suggested maybe spray a little carb cleaner around the gaskets and listen for a change in rpm.
  14. shedhouselife
    shedhouselife
    I found oil by one of the intake manifold bolts which was loose.
  15. bobss396
    bobss396
    How did it run with the old carb? Shoot some carb cleaner around the mounting surface, then go after the intake. Of course look for open vacuum ports around the back and side of the carb.
  16. Budget36
    Budget36
    As mentioned, you have a a vacuum leak. When you put your hand over the carburetor, it should want to start killing the engine.
    First just snug down the intake bolts, look on line for the proper pattern, but basically you start inside on one side, go the the other side, and keep doing that until you get to the ends. “Inside out”. Google will yield the proper pattern to do it.
    Use a box wrench. Some you can’t get a socket/ratchet on. So be consistent, keep in mind you’re not tightening the lug nuts on the car:).
    I say start with the intake bolts first, since you found one loose one.
  17. 1971BB427
    1971BB427
    from Oregon
    Which carb? And did it use an base adapter to bolt to the stock spreadbore intake pattern? I'd be looking at a possibility of a vacuum leak at the base plate gasket.
  18. carbking
    carbking
    Which Quadrajet? Identification number?
    Is it a new old stock original Rochester or Carter (yes, Virginia, Carter made Q-Jets under license from GM)?
    Or is it a new imitation?
    Jon
  19. AHotRod
    AHotRod
    What @carbking said ^^^^^
    We also need a picture of the intake manifold and carburetor.
  20. shedhouselife
    shedhouselife
    Thanks to everyone helping. It's awesome of you guys. So check this out. I have a electric fuel pump that is a cheap Chinese junker and so I am replacing it with a mechanical fuel pump. The electric fuel pump is on a switch. Today, I started the car cold with the electric fuel pump on, no pumps to the QJet, and it fired right up with a slightly high idle and no missing. Then I jabbed the gas and it started to miss. Then I turned off the fuel pump and the idle decreased and it really started missing. Would it be reasonable to suspect that perhaps the fuel pump is failing; meaning it's losing pressure?
  21. Budget36
    Budget36
    If the bowl was full of fuel, you should have a few minutes of “fun time” under no load. I/e idle and a few romps on the pedal.
    SS327 likes this.
  22. shedhouselife
    shedhouselife
    So what do you think my symptoms mean?
  23. Budget36
    Budget36
    I don’t know. I was just giving my experience based on your “could it be a fuel issue” after what you mentioned.
    Stumbles, etc are super tough to figure out on the internet for most of us. Some may know immediately what the likely 3 causes are. I’m not one of them. I have to have it in front of me and fiddle with it over a course of time.
  24. AHotRod
    AHotRod
    Deuces likes this.
  25. shedhouselife
    shedhouselife
    Ok I'll take some pics
  26. Budget36
    Budget36
    Did you do two things as suggested before, cinch down the intake and spray looking for a vacuum leak? If you did, I missed the results.
    Deuces and SS327 like this.
