Art & Inspiration Ford "Y" block engine pictures..
Discussion in 'The Hokey Ass Message Board' started by Deuces, May 24, 2023.
  1. Deuces
    Deuces
  2. squirrel
    It's a beauty!
    not like the one I had...
  3. egads
    egads
  4. dana barlow
    dana barlow
    from Miami Fla.
    In 1959,I was lucky I thought:D,to get a 1955 Thunderbird 292 engine n 3 speed:p out of a crash.. I had been looking for some time for any OHV V8 for as close to free as pos.;) Like the rest of my hotrod build,much more time hunting parts and then clean up an use. The "Y" was the last big part ,to now add to my Bobtailed 28A Roadster> as its old body had been crashed in the backend pretty bad/ so just cut off what I could not fix[ as a teen]. It was my sr high school ride,I liked it ,so kept it still*. Made my own speed stuff mostly,later got some Ford alum "T" covers,an homemade 4x2 intake from cutting up a drive shaft.
    Now days,I use a Alt. vs the old gen. an update to alum rad.
  5. AVater
    AVater
    Aspirational but inching along.
  6. miker98038
    miker98038
  7. sunbeam
    sunbeam
    I have a question what is that link from the wishbone to axle bolt that goes to the steering arm
  8. AVater
    AVater
    Not sure I understand the question so here goes: 1) the steering arm is disconnected from the pitman arm and is laying on the floor beneath the steering box making that look funky 2) the wishbone-axle bolts have a goose neck bend towards the backing plate. By the look of the picture angle, that appears to meld into the tie rod but not so. Just an illusion.
    Please let me know if I answered or missed your question.
  9. jimmy six
    jimmy six
    Mine! Thank you… lucky, to be the first one posted.
  10. Blue One
    Blue One
    from Alberta
    My 26 RPU. Tim Mcmaster built 309 inch, 292 block with a 312 crank etc etc.
  11. LowKat
    LowKat
    stuff I work on
  12. loudbang
  13. Deuces
    Deuces
    Hey L.B. Guess I should have looked before posting this thread.... My bad!.....:oops:
    I'll leave it up to the mods to delete this one if they want... Sorry..:(
  14. garage2small
    garage2small
  15. garage2small
    garage2small
  16. silent rick
    silent rick
  17. sunbeam
    sunbeam
    Yes it looked like the there was a link that would have locked the wheel in the straight position
    AVater likes this.
  18. Bleach
    Bleach
    Nice mostly original 31k mile 292 in my’56 Fairlane.
    CSPIDY, williebill, AVater and 4 others like this.
  19. Hotrod1959
    Hotrod1959
  20. guthriesmith
    guthriesmith
    I’ll play...the last one I messed with was a 57 312.
    74D16B16-5411-49A4-8AEF-1D51DD271C99.jpeg 955E86B1-9979-466E-B59F-B6296D82114E.jpeg
    CSPIDY, williebill, AVater and 6 others like this.
  21. 57fordor
    57fordor
    Here's the 312 in my '57 Custom 300:
    And the 292 in my old '60 F100:
  22. Baumi
    Baumi
    811A123D-39B1-4A1B-9EB8-2C48350160A7.jpeg 9EDC4FF1-FAA7-4671-817C-CF9E153AF5F2.jpeg My ex-312, going in a 40 Ford at the Moment.
    57fordor, CSPIDY, williebill and 8 others like this.
  23. My brother's '32 with a 292:
    And the P code 312 in my '56 Sunliner:
    -Dave
    y'sguy, 57fordor, dana barlow and 9 others like this.
  24. Thanks Guys. Now you got me wanting a Y.
    y'sguy, Deuces, OahuEli and 2 others like this.
  25. warbird1
    warbird1
    A really old, grainy picture of one I had in a '56 Ford 2 door wagon. 292 bored .125 which gave it 312 cu. in., Jahns 12-1 pistons, Isky or Weber cam, polished and ported "G" heads with lightened valves and a -B intake running a large AVS carb from a Lincoln. Backed up by a T-10. Not as nice appearing as the ones posted above, but it was a fast car in it's day... 312.jpg
  26. miker98038
    miker98038
    Not pretty, just a mock up on a core motor I have. Leading me to realize I didn’t have the technical or financial means to make it work on the street. “The things dreams are made off” 41C0C1BF-7F7F-4A88-9D6C-4E5DAA56D287.jpeg 41C0C1BF-7F7F-4A88-9D6C-4E5DAA56D287.jpeg 405BC858-DCA1-4076-B89B-AE57CE8B43C1.jpeg
    Sorry about the double picture.
  27. jimmy six
    jimmy six
    Doable with SBC’s…..engines are just air pumps and constant flow injectors don’t know what they are on.
  28. Deuces
    Deuces
    Bump...'....
  29. HOTRODNORSKIE
    HOTRODNORSKIE
    Here's a couple of mine for the club a 292 and a 312 20221102_213032.jpg 20221230_153127.jpg
  30. OahuEli
    OahuEli
    from Hawaii
    At least you didn't have that front crossover pipe like I did, burned the **** out of myself more than once!:confused::D
    Deuces and squirrel like this.
