Hot Rods 1932 Ford Coupe with 48 Column, shift knob removal help please
Discussion in 'The Hokey Ass Message Board' started by 38 Chevy, May 26, 2023.
  1. 38 Chevy
    38 Chevy
    1948 Shifter Knob.jpg 1948 Shifter.jpg 1948 Shifter.jpg Hey guys, I need some help. I have a 1948 Ford column shifter in my 1932 3 window coupe. I would like to change the light gray shift knob to a dark brown knob. All I need to know is how do you get
    the old shift knob off the handle without damaging anything. The knob will rotate but not come off.
  2. 38 Chevy
    38 Chevy
    Need some help.
  3. pprather
    pprather
    I'd change the thread ***le to:
    Ford, column shift, knob removal help
    302GMC and LOU WELLS like this.
  4. I've never changed one, but I'd probably buy the new one and see if it comes with instructions. I've seen the arm without a knob and all there is is a shaft with 2 ribs in it to keep the knob from twisting.
  5. 325w
    325w
    I’m guessing the shifter has searations on the knob end. Press on. Could warm it and give a steady pull. When you change the light switch shaft knob heat and pull works.
    da34guy likes this.
  6. 38 Chevy
    38 Chevy
    Ok you would have to warm the outside of the knob a lot to get heat to the inside, So you then have dripping
    plastic. Yes I did use heat to put the light switch knob on. Wouldn't it be easier to split the knob with a
    Dremel tool and a baby death wheel. I was hoping to save original knob. Just wondered if anyone had
    removed the knob before?
    da34guy likes this.
  7. 325w
    325w
    I heat the metal shaft not the plastic. Splitting would be the easiest.
  8. da34guy
    da34guy
    Split it, remember it's been on there since 48
  9. wheeltramp brian
    wheeltramp brian
    When I did mine on the 41 I just crushed it down with some vice grips until it cracked and then pushed the new one on with a little bit of Permatex inside to keep it on
    ramblin dan, olscrounger and X38 like this.
  10. When in doubt call the replacement part supplier and ask what they recommend.
  11. Bluestreak-PA
    Bluestreak-PA
    from Erie, PA
    End of shifter has concentric ribs. Knob is two piece.
    Speccie and 34 GAZ like this.
  12. Dog gone if I didn't just learn something. Are the 2 parts then glued together? Is there a C clip then that holds the bottom piece on the shaft?
  13. Dak Rat
    Dak Rat
    from NoDak
    If the knob is in good shape, couldn't you just paint it the color you want?
    theHIGHLANDER likes this.
  14. 38 Chevy
    38 Chevy
