Projects Model A clock ideas
Discussion in 'Traditional Hot Rods' started by hurlbird, May 27, 2023.
  1. hurlbird
    hurlbird
    Id love to install one without drilling, a nice period correct clock in my 1930. I see sterling was the brand back then but i do not want to modify dash and im running 12 volts. Anyone come up with a nice period correct looking solution that isnt permeant? Thanks! -John
  2. X38
    X38
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Tim and Just Gary like this.
  4. Ned Ludd
    Ned Ludd
    For a long time the norm for car clocks was a clockwork clock which merely periodically gets wound up electrically. It could be that such a mechanism could be adapted to a non-automotive clock?
    Also, of course, hobby clockmaking is a thing. Try a search? (Rabbit-hole warning, though.)
    dana barlow and firstinsteele like this.
  5. dave agosti
    dave agosti
    Installed a battery clock movement($15) in altimeter gauge in my 32.
    hurlbird and dana barlow like this.
  6. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Id buy one of those new big face watches and put it in a spot with custom surround.
  7. AccurateMike
    AccurateMike
  8. 302GMC
    302GMC
    from Idaho
    Get a wrist watch with a leather band. Wrap it around your rear view mirror ....
    X38 and Just Gary like this.
  9. Hit a pawn shop and find a cool old pocket watch.
  10. Bandit Billy
    Bandit Billy
    Sun dial is more traditional. It won't work in the PNW most days though.
  11. 5window
    5window
  12. X38
    X38
    More effective with a stationary engine than a moving vehicle;):D
    Ned Ludd, Bandit Billy and 2Blue2 like this.
  13. You can buy a battery powered clock mechanism real cheap and install a "AA" battery outside the housing underneath the dash. These mechanisms can be used to replace the original dead unit, and come with different shaped hands which can be cut down, painted, etc to suit. You can install these in any clock with a face bigger than about 2". I once found a real neat wris****ch and removed the band, ground off the band mounting tabs so it was just a round housing, and mounted it with a piece of sticky velcro so the battery can be changed.
  14. Turns
    Turns
    This is what clock I have set aside for my 1930
  15. mr.chevrolet
    mr.chevrolet
  16. BJR
    BJR
    Is that red logo Olds, Packard or what?
  17. Tim
    Tim
    from KCMO
    I dig the clock in the mirror option but I’ve put a wrist watch around the spoke of a steering wheel more than once as well
  18. I have 2 wind up clocks slated for cars. ****py pics (I need to get another photoshop program).
    Westclox for the '28
    Wittnauer WW2 era 8 day bomber clock, had it in my '54 panel before I sold it.
    dirt t, 5window and jnaki like this.
  19. hurlbird
    hurlbird
    thanks for the ideas...
  20. Joe Blow
    Joe Blow
  21. Jeff34
    Jeff34
    This clock/mirror came with my roadster. It's in the '34 now for safe keeping. Only problem with it is that the spring only runs the clock for about a day. It will most likely go back in the roadster once it's done. IMG_3033.jpeg
  22. Ned Ludd
    Ned Ludd
    That's why you have a clockwork mechanism to keep it oriented the right way :D
