Technical 34 Chevy Master Power Steering
Discussion in 'Traditional Hot Rods' started by 34ChevyMaster, May 30, 2023.
  1. 34ChevyMaster
    34ChevyMaster
    As noted above I’m trying to install the Flaming River column mounted power steering unit on my 34. Unfortunately Flaming River have not been helpful for doing this on my car.
    I am looking for anyone who has installed the above unit on a real hot rod. Not a 200k master piece. I have several questions.
    1. With the flexible couplers installed how do you keep the shaft ridged while measuring for mounting brackets under dash
    2. Anybody got a good mount design and where did you mount it to
    3. Anybody do it on a 30’s Chevy
    4. What flexible couplers did you use
    5. How did you keep the ***embly rigid while measuring for mounting brackets
    thanks for any help you guys might have
    P/s please keep responses to unit in question. It’s not the rack and pinion unit is the unit that goes on the steering column ( Microsteer)
  2. lothiandon1940
    lothiandon1940
    Be prepared, people will ask why you feel the need for power steering.
    Bob Lowry likes this.
  3. I use a short piece of 2x4 with a half circle cut out of the middle and a couple of ratchet clamps.
  4. CSPIDY
    CSPIDY
    My brother is building a 34 master 3 window
    he has a flaming river column with a power rack
    he will take some pictures and I’ll post them
    lothiandon1940 likes this.
  5. 34ChevyMaster
    34ChevyMaster
    I had both my shoulders replaced completely. Called a Reverse total shoulder replacement. I either get PS or sell my hot rod I have worked on 5 years.
  6. 34ChevyMaster
    34ChevyMaster
    And how exactly will that work in the confines of “ under the dash?? Ratchet straps certainly have there place but not here.
  7. 34ChevyMaster
    34ChevyMaster
    Thank you soooo much! That’s exactly what I was hoping for.
  8. Ratchet clamps, not straps. The little 6" clamps that get tighter as you squeeze the trigger. They also have rubber pads and hold well.
  9. CSPIDY
    CSPIDY
    I believe he bought the u-joints from Borgenson
    4E18D421-3410-4C90-907D-AEBFC9151009.jpeg 6CFB01F0-6865-4270-9BC2-3336A0364042.jpeg 0538A7D2-8A75-4CCC-9546-199A7EAABAFA.jpeg 5667B674-76BB-41A2-8050-9E0F1CD7850D.jpeg AE6C4DBC-8FE7-40FB-B104-0D03B0CBF7AF.jpeg A8E4D79D-1C97-404B-A5F4-F44D5A051993.jpeg 07119915-D535-4189-913B-58150BEA3124.jpeg 075D165F-8544-4ECD-9011-8720234FC5D4.jpeg B55E3B69-EFD9-4489-BC22-5EEF41C8A052.jpeg
    Hope this helps
  10. this is a very good reason to have power steering
  11. 1971BB427
    1971BB427
    from Oregon
    Not a '34, but on my '39 Chev coupe I simply used 3/8" all thread pieces from the dash down to the column to be able to adjust column height until it felt right for my seating location. Then I used wooden dowel round stock that fit into my steering joints to setup where a joint needed to be, and where to add a heim joint to support the shaft. Once it was all setup, I cut up my double D shaft, and permanently made up the steering, sliding my 3/4" heim joints over the shaft on places where I needed support.
    Honestly doesn't matter if it's power steering or manual as to how it's setup to steer.
  12. squirrel
    looks like some of you missed out on the fact that he was trying to install an electric power unit in the steering shaft, under the dash. That was his question, how to install that unit. Of course he neglected to tell us about what front end he's using (since it's probably off topic), or provide any pictures so we could see what he's actually dealing with.
    My guess is he gave up on us pretty quickly.
