Event Coverage Big daddy goes racing with the 60 Elco!
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, May 27, 2023.
  1. hotrodjack33
    hotrodjack33
    The "R" looks a little fatter than the rest of the letters...like it might have been an "F" at one time...kind like a tattoo cover-up;):D
  2. Lloyd's paint & glass
    ****, I didn't know it had to be perfect jack! I should've gotten vinyl lettering :rolleyes:
    mad mikey, SS327 and 427 sleeper like this.
  3. Lloyd's paint & glass
  4. 427 sleeper
    427 sleeper
    I Love the Bomb on the fender!!! :cool::cool::cool:
  5. hotrodjack33
    hotrodjack33
    LOL The lettering is fine buddy...but you aren't fooling us. I just think you started out with ****US...and had second thoughts.:p
  6. Lloyd's paint & glass
  7. Lloyd's paint & glass
    Hey @squirrel , I'm all in at 2200 now. 34⁰ seems to be where it wants to run best. I'm at 10⁰ initial. And at the suggestion of @Moriarity , I then hooked the vacuum advance to the manifold vacuum and checked it against initial, it was 24⁰, so I backed the screw out until I hit 20⁰. So, now I'm at 10⁰ initial, 34⁰ all in at 2200rpm, and with the vacuum advance hooked up at light throttle 3000rpm, I'm at 44⁰. Sound like a plan? Runs good like this. No detonation either.
  8. 427 sleeper
    427 sleeper
    I know you didn't ask for my input, but you need to remember that a street tune and a track tune are 2 COMPLETELY different animal's. In all reality, your tune up isn't the problem. It's the gear and the converter that's ****in' you.
    RodStRace, mad mikey and squirrel like this.
  9. Lloyd's paint & glass
    Yeah I understand that, I'm trying to make the car run correct. Not fast. It will never be fast with this engine. No way I would put gears in it to crutch the lack of power. I'll just put power in it when I get to that lol
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, the combination of a small cube engine with maybe a little too much camshaft combined with a tight converter and tall gears are all killing bottom end (launching) torque
  11. It's good that you understand the true issue. Helps keep all the parts inside the Oil Pan.
    alanp561, mad mikey, SS327 and 3 others like this.
  12. Lloyd's paint & glass
    I don't know if I would call this excessive camshaft Mark lol 20230411_220444.jpg
  13. squirrel
    you just need some 4.56 gears and a 10" converter. Then again, a big block might fix the issue without the gearing changes :)
  14. Lloyd's paint & glass
    That's what I'm talking, and still be drivable
    alanp561, mad mikey and Moriarity like this.
  15. 427 sleeper
    427 sleeper
    That's pretty wild for what you want to do with a stock converter and a 3.42 gear It'd probably be quicker with a Duntov cam. And STILL be driveable... ;)
  16. 427 sleeper
    427 sleeper
    When did a 4.56 gear become unstreetable??? ;)
    swade41, Motorwrxs, carpok and 5 others like this.
  17. It's not big, per se but just about anything aftermarket is going to move the torque up and farther away from the stall speed.
    I wonder if you can foot brake it up higher with the timing change?
  18. Lloyd's paint & glass
    The converter is gonna be a 3000 stall with the big block. And I believe you told me that you can't drive your car to Bowling Green because of the gears you're running :p
    chryslerfan55 and 427 sleeper like this.
  19. Lloyd's paint & glass
    Not sure, didn't try it yet. I'm just tickled to have it running good lol. With the carb that was on it, if you matted the pedal from idle, it stuttered and fumbled like a kid that you caught up in a lie lol.
    mad mikey, 427 sleeper and Moriarity like this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    Big blocks don't really need slippy converters... they have gobs of bottom end grunt....
  21. squirrel
    That depends on how fast you want to go. One neat thing about them is that the often end up with a TH400 behind them, which you can do some neat converter tricks with...like switch pitch...
  22. Lloyd's paint & glass
    My fire chief is building a 72 vette, but he's going all stupid on the drivetrain. It had a fresh 400t in it, I've already told him he owes me for the work I've done on his ch***is, plus I know it'll be at my shop for paint lol
    chryslerfan55 and mad mikey like this.
  23. Lloyd's paint & glass
    Jack i didn't understand what you was saying at first lol
    alanp561, SS327 and hotrodjack33 like this.
  24. wraymen
    wraymen
    Lloyd, I bet you already picked up a couple of tenths with the changes you made from the advice given. Very interesting thread, wish I had more to contribute. I do agree with the converter change.
    Lay off the race gas and just put some high test in it (or even mid grade). After a few weekends you’ll be able to get a converter with the $ you save.
    I’m guessing your at 8, possibly 9:1 comp. You don’t need 110, hell it might even hurt your times.
  25. lippy
    lippy
    from Ks
    Marty I had a 49 packard that I know would run at least 185 mph off the side of Pikes Peak, but it wasn't on the chart. LOL but I get what you're saying.:) Lippy
  26. Lloyd's paint & glass
    Factory specs on this engine is anywhere from 9.25-1 to 9.5-1 factory. It's .030 over, and the heads were cut .007 so it's over that, I didn't bother with CC'ing as its sole purpose was to replace the 350 in my 57. But yes, back down to 10⁰ and 34⁰ total, I'm not hearing any detonation now. Which it still has good gas in it. We'll see what happens when Friday gets here, I'm going over for test & tune at the track. I'm not gonna invest anymore cash into this setup, from here, my money will go into the big block, and to Mark for the sweet wheels he made me a deal on :D:D:D
  27. Not that it matters here but the only way to know the true compression is to check everything.
    Rebuilder oversize piston usually have the crown height reduced over standard bore so as to not raise c/r.
    .007 probably not 2 cc.s less in the chamber. It depends on who did the valve job and where the valves ended up.
    Anyway, I'm thinking pump gas 462, oval port, hyd. roller, 2800 stall, 3310 carb , 4.10's. Easy 7's in the 1/8th
    That oughta tear the rear suspension out of it. LOL
  28. olscrounger
    olscrounger
    Is that the cam I sent you? It was strong mid range in her 55 snotty 327 with a PG and 3.70 rear. Ran mid 14's back in the 80's When I redid the motor some years back the cam is again a SIG same intake specs but more on the exhaust.
  29. SS327
    SS327
    The nice thing about if you pop for a converter now you can still use it with the big block! Even if you switch to a 400 trans at some point.
  30. chevy57dude
    chevy57dude
    Show us a pic of the wheels!
