Technical My new mallory paperweight
Discussion in 'Traditional Hot Rods' started by 66Special, May 29, 2023.
  1. 66Special
    66Special
    After 20,000+ miles my $50 estate sale Mallory bit the dust. After about 50% in depth, serious, technical diagnosis and 50% throwing parts at a horrible misfire/no spark issue on my 8BA, I finally discovered my distributor cam had 4 lobes considerably less "lobey". A variation of around 8 thousandths between my best and worst lobe made adjusting my points across all eight cylinders an impossibility. I installed my spare distributor and we're off again but here's my question, is my old distributor just a fancy paperweight now? I looked online and couldn't seem to find replacement distributor cams, are they serviceable? The cam has a part number stamped right on it. What's my next step if I want to make this distributor usable again?
  2. nochop
    nochop
    from norcal
    Make a lamp
    slayer, ffr1222k, dirt t and 2 others like this.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    What vintage is it? Is it the old two piece cap variety? I'm figuring that an eight lobe cam off of almost any other Mallory dual point of similar vintage would be interchangeable.
  4. distributorguy
    distributorguy
    from MN
    Are the lobes worn or is the shaft bent? Most of my customers think they have wear when the real issue is that the shaft is pushed off to one side, allowing more point lift on one side, less on the opposite. They're pretty soft so straightening shafts is a normal part of tuning distributors. The cam itself is case hardened, so anything rubbing on it shouldn't leave marks.
    winduptoy, alanp561, deadbeat and 3 others like this.
  5. Mark Grabo
    Mark Grabo
    from Upstate NY
    or possibly worn bushing in the housing where the shaft runs . it would be an easy check and fix
    alanp561, loudbang and Budget36 like this.
  6. Budget36
    Budget36
    Just thinking out loud, but I’d agree with the two posts above. Only other thing is it would have been drilled off center and been like that from day one.
    I’ve never heard of one or two, etc distributor cam lobes going flat;)
  7. ekimneirbo
    ekimneirbo
    How did you measure the lobes? Did you put a dial indicator against the lobes as you rotated it, or did you use a micrometer/dial caliper and measure the diameter across two lobes, or some other way?
    What and how you measured may play a part in the readings you got.
    IF, the lobes are actually "worn" that much or manufactured that poorly...... you could try using a hard honing stone and removing metal from the higher lobes to make them all more consistant. Not the best idea,,,,,but its not any good like it is.
  8. 66Special
    66Special
    I removed one of the ground posts going through the body of the distributor and stuck the dial indicator through the hole in the body, touching the cam, and then turned the distributor measuring that way
    ekimneirbo likes this.
  9. 66Special
    66Special
    i guess i could put the dial indicator on the shaft above the cam where the rotor attaches and check for any variance.
    ffr1222k likes this.
  10. 66Special
    66Special
    When the distributor was still in the engine i checked for excessive play in the shaft and the bushings still felt nice and tight to me. No movement from side to side or anything of that nature and negligible movement up and down. How would you check the bushings?
  11. Phil Brown
    Phil Brown
    Bushings could be good but if the shaft is bent just slightly above the top bushing it would make the distributor cam wobble in relation to the point plate
  12. Joe H
    Joe H
    While rotating and watching the dial indicator, watch the base diameter, not the lobe diameter. If the base diameter is not steady, then something is bent and wobbly.
  13. ekimneirbo
    ekimneirbo
    You should be able to tell if there is any shaft movement by using the dial indicator set up you mentioned and simply using your hand to try to move the distributor shaft. Expect a little movement due to the clearance between the shaft and the bushing. Maybe .001/.002
    As for the distributor shaft being bent, that same set up with the dial indicator against the shaft should tell you if it has any bend in it.
    If both of those tests are fine, you could use a drill to spin the distributor. Put a little ****m blue or permanent marker on the shortest lobe. Then rotate the distributor cam and put a fine file or a fine honing stone in a place where you can lightly touch the lobes as it spins. When you start to remove the ****m blue on the low lobe, all your lobes should be the same height. Then the question is whether the flat spots are low enough to let the points close. Probably be ok.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Does yours have a screw like this one or an oil pot or one of those spring loaded ball things. This is for oiling the bushing. I oil the one on my 40 every time I change the motor oil
    982A5AD4-C5FC-4E24-9165-9BFEAE92155B.jpeg 222D8F8A-0F78-4CA8-AE31-1344B89F18D8.jpeg
  15. Budget36
    Budget36
    I’ll be darn, I’ve never noticed that screw plug before, but never had an AM distributor, I ***ume aftermarket? My ‘59 Chevy 235 had a flip up cap like a generator does. Think that’s the only distributor I had that could take oil like that.
    Moriarity likes this.
  16. PMD406
    PMD406
    Some of the for truck 6 OHV distributors came with an oil port w/flip up cap. Kind of a mini Plews fitting..
    The 1974 F-100 300"6 I bought new had a distributor with an oil cup/port..
  17. 66Special
    66Special
    i have a screw like that, never knew thats what that was for. How do you oil yours? just a couple drops of 80/90 or what?
  18. SS327
    SS327
