Technical Battery/electric 6v &12v at the same time
Discussion in 'The Hokey Ass Message Board' started by ActionYobbo, Jun 1, 2023.
  1. ActionYobbo
    ActionYobbo
    Why cant I series 2 6v batteries to get 12v for the headlights and the radio and run the 6v stuff of 1 6v battery. Or whats thd best way to run some stuff 6v and some 12v
    6v would be gauges, horn and interior lights and starter for now until its upgraded.
    12v would be head lights, tail lights, blinkers and brake lights and starter in the future.
    Thanks
  2. Ned Ludd
    Ned Ludd
    You'd need to keep the 6V and 12V circuits separate, and use the frame/body as ground for either one or the other. I think?
  3. The horn and starter will live on 12 volts, the horn will be louder and the starter will spin faster, excessive crank times and horn blaring times will burn them out, normal use will last a long time. Interior lightbulbs can be changed to 12v, the gauges can have voltage reducers installed.
    gimpyshotrods likes this.
  4. CSPIDY
    CSPIDY
    I’ve seen it done on electric golf carts
    they would have either 6 or 8, 6 volt batteries connected in series
    then tap off for 12 volts to run the lights
    they used a floating ground because of the fibergl*** body
    sdluck, gimpyshotrods and 1oldtimer like this.
  5. You could do it, but as mentioned, 6volt starters and horns will still play on 12v, and you can run a 6volt 5A regulator to run any odd 6volt stuff (Fan motor, fuel guage, etc.). !2 V conversion is easily done, if you have good wiring.
  6. sunbeam
    sunbeam
    Tap in between the batters for 6 volts. especially with no more 6 volt load than you have and change the starter now.. I have seen 6v 8
    n Ford tractor 6v starters run for years on 12v.
  7. squirrel
    If you're gonna run part of the car on 12v, you really ought to run all of it on 12v. Your life will be easier....
    firstinsteele, CSPIDY, Jrs50 and 5 others like this.
  8. winduptoy
    winduptoy
    My old Mack trucks have a series/parallel switch. All the lights and accessories run on 12V and the starter on 24V.
    It adds a lot of additional wiring and complexity but it can be done I suspect with a 6V to 12V but finding a 6V series parallel solenoid will probably be next to impossible....the contacts are mechanically connected
    Budget36 likes this.
  9. Instead of having two batteries, are there inexpensive transformers to drop 12 Volts to 6 Volts?
  10. 51504bat
    51504bat
    IIRC, years ago JC Whitney used to sell 6/12 volt combination batteries. Doubt there is any use for them anymore.
  11. winduptoy
    winduptoy
    mmmmm, yes.....for alternating current
    Transformers are an inductive device that rely on the collapsing magnetic field to induce a voltage and that happens at 60 Hz in US AC voltage.
    I guess a high tension ignition coil is really a step up transformer that relies on the breaker points to collapse the voltage
    Crazy Steve likes this.
  12. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    12 volt batteries with a center tap used to be available but probably aren't now. You can use two 6 volt Optima batteries and a 12 volt, one wire alternator to achieve the 12 volt part and tap off the center between them for 6 volts. Properly installed, the alternator will keep the 12 volts charged and still give you 6 volts with no other mods. I've done that before and it works fine. I say Optima batteries because they are small and make a neat installation. Expensive, though.
    sgtlethargic likes this.
  13. BJR
    BJR
    Look here.
    https://www.jalopyjournal.com/forum/threads/how-to-build-a-voltage-regulator-for-3.448589/
    Just need a voltage drop for electric gauges. Horn and starter will live fine on 12 volts. So will the GM clocks that use 6 volt power to wind the movement. If your clock clicks every 3 minutes or so that is when the spring gets rewound by an electro magnet. Since it only uses 12 volts momentarily to wind the spring it works fine. I have been running a 6 volt clock on 12 volts for 10 years now. Same with starter and horn.
  14. rusty valley
    rusty valley
    On my 52 army jeep I converted the military blackout lights to turn signals. The jeep is 24 volt, (2 12vs in series) but to use cheap 12volt stuff I had I had in stock I wired the new turn signal system to the first 12 volt battery, and the rest of the jeep is stock 24 volt. Works fine and I don't need to search for 24 volt flashers or bulbs
  15. lippy
    lippy
    from Ks
    I'm with Jim. All the time and work you will invest to make it work, seems to me you could have it all changed to 12 volt. ?o_O:)
    ekimneirbo likes this.
  16. jaracer
    jaracer
    Years ago I saw a 6 volt car with a 12 volt battery. It had a 12 volt generator and 12 volts to the 6 volt starter. The rest of the car electrics were run via screw tapped into the third cell connector on the top of the battery. That's when the cells were connected outside the case.
    Boneyard51 and hemihotrod66 like this.
  17. This . What you will pay for 2 6v batteries and the extra cabling .
    buy a ford voltage drop regulator for your gauges .
    fan and starter will work fine on 12 v and your done .
  18. bill gruendeman
    bill gruendeman
    Some 6volt systems are pos ground and as far as I know all 12 volt systems are neg ground.some old semi trucks had 6 volts batteries in series for 12 volts seems like I needed lots of jump starts.
  19. Budget36
    Budget36
    Isn’t the switch also an isolator? I have one somewhere off a Pete that had a Detroit in it, switched to 12v after start ****on was released.
  20. Boneyard51
    Boneyard51
    On my 55 Ford that I put a 430 Mel in , I put a 12 volt battery in it , to start that big engine , but I taped in to the center of the battery ( they used to have lead bars on top) and fed the rest of the car on that six volts. I had a 12 volt generator and regulator! I added a 12 volt wire to feed the ignition! Worked great!
    Bones
    brading likes this.
  21. johhn00
    johhn00
    You really ought to run all of it on 12v. Checking the voltage of a 6V vs 12V battery is not enough to determine what type is best, but when you go from a 6-voltage battery to a 12-voltage battery, you are effectively doubling the amount of voltage.
  22. What is a device (edit: are devices) called that lower(s) 12 V to 6 V for things such as "gauges, horn, interior lights and starters"?
  23. BJR
    BJR
    See post #13
  24. lippy
    lippy
    from Ks
    Oh, that would be a "Short". :D
  25. ActionYobbo
    ActionYobbo
    Thanks for the replies. Looks like I will do everything I can 12v and get a 6v regulator for the dashboard
  26. You can do what you described, but what type of car is it?. It would be cheaper to put a Runtz on the gauges also is the battery tray big enough for 2 6v.
