Technical Model a 32 shell fit issues
Discussion in 'Traditional Hot Rods' started by DreamerJ, May 27, 2023.
  1. X38
    X38
    Mmm, that is significant too!
  2. clem
    clem
    Doesn’t the radiator sit mostly on top of the cross member ?
    The photo you show with the level, - looks like the fan would actually be in the middle of the radiator.
    Have you had the radiator bolted in the correct place ?
    With the shorter fan/water pump everything should fall into place ?
    Or maybe I just don’t understand what’s going on…..
    drdave likes this.
  3. DreamerJ
    DreamerJ
    Yes the rad is bolted on top of the cross memeber. The radiator has a slight forward lean and the fan is super close to the rad. I’ve got the stock radiator and my shorter aftermarket, both sit a donkey hair away from the fan. When I get home from SF, I will ***emble and show you in photos. My engine consumes every bit of space, the top of the head is half inch off the firewall, the fan is smack against the radiator.
  4. ClarkH
    ClarkH
    This is a new 4-blade fan I got from Bratton's. See that little extension protruding from the front? Near as I can tell, the fan blades are set back roughly half an inch from stock, but pulley remains in stock location. This fan might buy you the space you need.
  5. Phil Brown
    Phil Brown
    You have the A style pump to match your head (4-bolt mounting) so the B pumps won't work (3-bolt mounting)
    But in your pic things look too far forward ?
    Tried to get you a pic of my A (A radiator and shell with the hood) for reference. The radiator core is 2" thick 20230601_081401.jpg
    drdave likes this.
  6. Phil Brown
    Phil Brown
    Got another pic for ya of where the radiator would originally sit and its mounting, maybe it will help 20230601_084552.jpg
    drdave and X38 like this.
