Projects Barn Find '39 Deluxe 4-door Sedan Build
Discussion in 'Traditional Hot Rods' started by BarnFind39, May 10, 2023.
  1. ModelAMitch
    ModelAMitch
    Your rust spraying concoction looks like it worked great. It'll be awesome having all parts new and old looking like they've been there the whole time. Keep it up
    9200 IH and JalopyJimbo like this.
  2. T&A Flathead
    T&A Flathead
    Nice to see another more door getting some love. keep it up !
    I pulled this one out of a barn a couple years ago. Fixed the brakes, put some gas in it and it’s driving. Been running it as is ever since.
    dwollam, 9200 IH, 41fordor and 11 others like this.
  3. BarnFind39
    BarnFind39
    Thanks, I was amazed how well it worked. I didn't pay enough attention in science cl*** to understand the process but really liked the appearance.
    Beautiful car, I love the color!
    dwollam and T&A Flathead like this.
  4. 6sally6
    6sally6
    I bet you could sell that flathead to any number of restorers and put that "LARGE" amount of $$ into
    fixing-up one of those 428's or 9's ....and never look back.
    IF.......you plan to drive it a lot (I would!)
    Plenty of power & reliability ...I know-I know flatties can be made reliable....
    Plenty of great options for a real find.
    6sally6
  5. BarnFind39
    BarnFind39
    Wow, it’s a good thing I’m not a flat rate mechanic doing these brakes, I’d starve. Drum brakes have always been a weak spot to me but these are exceptionally bad. I bought a brake kit that came with the shoes, wheel cylinders, hoses, seals and springs. The kit looks nice but I had issues right from the start. I had to ream 2 of 3 wheel cylinder holes to get the bolts to thread in and then had to run a drill bit thru the 2 holes for the spreader bar pins. Finally, after struggling way longer than I care to admit to get the spring on I realized the new one is at least 1/4” shorter. I went back to the original spring and got it attached. I’ll reserve dumping on the company until I do the other 3. I’m certainly hoping I don’t have the same problems but I expect to. I couldn’t figure why the bottom of the rear shoe wasn’t tight against the backing plate. It ends up I didn’t have the e-brake arm in its clip:mad:. Tear it all back apart and redo it. That was a good place to quit for the evening. IMG_3241.jpeg IMG_3246.jpeg IMG_3247.jpeg IMG_3245.jpeg
  6. D Newcomb
    D Newcomb
    I've also got one.[Blue] These are really around a lot-survived the '50's. Popular with families I guess. I even grafted a bad coupe body to a 4dr ch***is/pan and cowl. See it as my avatar. Fit perfectly. Weld is around the rear wheel well, B pillar base and windshield posts. Newc
  7. BarnFind39
    BarnFind39
    Very nice and it doesn't surprise me it fit. It wasn't that long before these cars that the Model A was so universal. I always had preferred the coupes but I think I'll enjoy this one because I have more people than a coupe would hold that won't mind going to cruises.
    dwollam and Outback like this.
  8. BarnFind39
    BarnFind39
    This is a long winded rant or whining, however you want to view it. I also totally get that this car is 84 years old and I should be grateful that some of these parts are even available but this brake kit could possibly be the most disappointing box of car parts I've ever purchased. Friday night was the start of the issues but yesterday was worse. I solved all of the Friday problems, wasn’t happy about it, but they got corrected. IMG_3263.jpeg
    I previously had mentioned the brake shoes problem was the pin needing drilled and finding out the springs were too short. I found out having to slot a couple holes wasn’t the only wheel cylinder issue.
    As evidenced by the photos, the piston are maybe 1/3 the depth and the “good side” is twice as wide. I noticed this when I went to put the 2nd one together. I walk around to the other side and shook the top of the shoes. I made a short video of the clunking but I’m sure you get the idea. This really messes up what I wanted to accomplish this weekend, things were going so good while this box of stuff was sitting in the trunk. I decide to get the drum ready to go for whenever I get the wheel cylinder issue solved.
    I clean up everything real nice, re***embling as it was when I pulled it out. Go to my white box of garbage and in the bag of short springs were the 4 seals. They are solid front and back, originals were open in the back, so you had to be paying attention which way it went in. I found a perfect diameter wooden hole saw slug laying right beside my vice, no clue how it got there. I tap in the seal, just a couple more taps to fit the snap ring. Last hit sounded solid, remove my wooden puck and I couldn’t fit a paper c-clip in there. Upon closer inspection, I now have the bearing where it won’t rotate because that seal is pressing against the L shaped ring! Maybe these work if you left it out, I dunno. All I do know is this would only work with a max of 2 out of 3 of those pieces in my pic. Meatloaf song doesn’t apply here. Even if it was designed to have that retainer left out, woulda been ridiculous, there should’ve been a s**** of paper in the unmarked Ziploc giving a person that horrible advice. Every part I’ve lifted out of the box has been inferior. I’m feeling like the hoses will either be too short or have a bad flare or threads, maybe both. Sorry, I’ll be back with a positive post next time.
    dwollam, osage orange and Okie Pete like this.
  9. pkhammer
    pkhammer
    Unfortunately this sort of experience isn't uncommon this day and age where most of these parts are manufactured off-shore with sub-standard quality control. I recently did a rear spring kit on my '51 F1 and pretty much everything had to be modified to fit. If a person could find NOS or domestic NORS replacement parts you might pay more but it'd be worth it.
    Best of luck with the build.
  10. BarnFind39
    BarnFind39
    Thanks, I feel like I’m going to need it. I’m just fortunate having to not buy as many parts as most for this project. The fact I sell automotive paint and supplies doubles down on my experience with inferior parts. I’m around shops all day, every day that fight with garbage parts the insurance companies mandate, or try to anyways, and restoration shops that run into what I just did. I call on 2 places that work on old, sometimes odd, high end foreign stuff that don’t even have parts available. I had planned on refurbishing as many original pieces as possible anyways
    dwollam and Okie Pete like this.
  11. BarnFind39
    BarnFind39
    I decided to bend the last brake line because I didn’t think that could go wrong. I also was able to get 2 of the new tires mounted and balanced last night. I had planned to use whatever tire held air the longest as a spare. It didn’t take long to realize I really had only one that wasn’t cracked so bad you could see the tube. IMG_1606.jpeg
  12. two couped up
    two couped up
    from pa.
    Your shoes are on wrong, lockheed brakes the long shoes go in the front with the big wheel cylinder piston and the short shoes to the rear with the small piston.
    dwollam, BJR and Hamtown Al like this.
  13. BarnFind39
    BarnFind39
    Thanks for pointing that out! I’ve got to admit I looked for differences but notice the bottom was shorter on the one. Thanks again for pointing that out now! I’ll correct that when my new wheel cylinders arrive. I would never have swapped those pads
  14. BarnFind39
    BarnFind39
    I'm starting to get more parts trickling in. The wiring harnesses are installed except for the dash harness, still waiting to order it. I hope to be able to pick up my converted generator this week. I went with the Tanks Inc gas tank, part # 40G, and I'm real glad I did. The finish is really nice and it would be impossible for it to fit any better. It goes in and out way easier than the original and the 2 extra gallons of fuel will come in handy. Even though there's notes everywhere saying this tank doesn't work with a stock style sending unit, like the 99A-9275, I see no reason why that one won't work. It doesn't appear that new sending unit has the bulge on the bottom side, like the original, so it should sit down in there with no problem after an adapter ring is made.
  15. Dan Hay
    Dan Hay
    Nice car. Sold this one last October to a Hamber, and I miss it!
    dwollam, Okie Pete, Toms Dogs and 5 others like this.
  16. BarnFind39
    BarnFind39
    The fuel line could be removed out thru the front. I laid it out and bent the new one just like it. I left some extra line sticking up because I don't have the fuel pump yet and don't know if it will be the same as the original, I'm hoping to get the new one installed without much issue. The Tanks' unit has a nice pick up coming out the top so I needed to extend the line straight out from where it used to go into the original tank. I have it lined up to be able to tighten the hose clamp thru the access window for the sending unit.
    Fuel Line New Front.JPEG Fuel Line New.JPEG Fuel Line New Rear.JPEG Gas Tank Sending Unit Access.jpeg
    dwollam, Okie Pete, Algoma56 and 2 others like this.
  17. DylanW
    DylanW
    Sweet build! I need to get back to work on my '39 Mercury 4 door.
  18. BarnFind39
    BarnFind39
    Thanks Dan, that's a really nice car!
    Thanks Dylan! I'll be glad to give some motivation. I'm sure I'll be needing some from time to time.
    DylanW likes this.
  19. BarnFind39
    BarnFind39
    Got some good stuff happening today! I got my generator back after it was converted to 12V negative ground. He hooked me up with a quality USA made voltage regulator and I swapped the lid from a NOS 6V unit I snagged on Ebay just because I thought the lid was really cool.
    When I got home, I had some wheel cylinders from Speedway waiting for me. They were just what I wanted to see and look just like the originals. The difference of the first ones I bought is night and day. Of course I got the "we've sold hundreds of those brake kits with zero issues" story. More to follow on that
  20. n847
    n847
    I like your style on this build. Just fix what needs fixin so you can enjoy the car. No need to overthink the build at this point!
    9200 IH and Outback like this.
  21. BarnFind39
    BarnFind39
    That’s for sure. Besides procrastination, I have a major flaw of going way to far on a project, any project. I could see myself doing the body and paint work on this at some point but I’m going to enjoy it as is and only do that once the next project is completed. I’ve been without a ride to take to cruises for more years than I care to admit.
    dwollam, Okie Pete and Outback like this.
  22. BarnFind39
    BarnFind39
    Well, my day was made early! I was getting parts dug out to take to the machine shop and decided to look if I need an offset generator bracket. I had fingers crossed I didn’t and it appears I’m good! Only by the thinnest of margins but it’ll go. I did find the generator bolt thread is stripped but no biggie there. A dual carb setup seems like it could be a tuning nightmare, especially since I know nothing about these carbs. My plan is to rebuild a carb and put the single intake on. After I make sure it runs ok I will put the other carb on and after it runs ok, swap the intake last. Possibly not necessary but I think it’ll save me time in the end.
    dwollam, Okie Pete, warbird1 and 5 others like this.
  23. Nailhead Jason
    Nailhead Jason
    I did exactly that the Tanks brand tank in my 39 , but my original sending unit was toast, I ended up making an adatper and using the sending unit module for a 56 ford and modifying the arm to match the length of the original 39 float arm. Works flawlessly, and is very accurate.
    warbird1 likes this.
  24. Bandit Billy
    Bandit Billy
    Nice car! I hope you are going to give that shiny new tank a patina job, it is going to look out of place under there.
    Outback and X38 like this.
  25. Outback
    Outback
    from NE Vic, Oz
    Unless the car is very low, then only the die hards will see it!
  26. alchemy
    alchemy
    You have a Hexagon Tool intake! Those are rather rare. Note the carbs mount backwards compared to every other intake made for old Fords. You will need to get creative with your throttle linkage.
    dwollam, BJR and warbird1 like this.
  27. BarnFind39
    BarnFind39
    Good to hear! I had planned to make an adapter but then it occurred to me that I can probably just drill the 5 hole pattern in the 99A-9275 sender. I will know soon because it just arrived today!
    Thanks! Yeah, I gotta try something. That'll be my first attempt at spraying my rust color paint process on something that large so I'm not sure how it will turn out. Fingers crossed
    That's more of a "I'll know it's not right" kind of thing
    Backwards, seriously?!?! I never even noticed that! Thanks and boy is that embarr***ing
  28. Outback
    Outback
    from NE Vic, Oz
    I get it, loving the way you are attacking the sedan, It's a Cool thing, was trying to piece one together a while back.
  29. BarnFind39
    BarnFind39
    Thanks! I kind of regret not working on the car earlier in life but nowadays is the best time for people cruising a car that shows its age.
    Hopefully, I’ll get to post some progress over the weekend. I got another box of parts yesterday that should keep me really busy for a bit
  30. chiro
    chiro
    Holley 94's are great carbs and easy to work on. You may want to go with smaller jets once you have both on that intake and change out the power valves for smaller ones as well. I use 3 1/2 power valves and 46 jets in my dual carb setup. There is also a three position setting for the accelerator pump linkage. Play around with that till you figure out which hole for the link works best for you. Talk to Charlie Price at Vintage Speed. He makes the PROPER power valves for those carbs and will have everything fuel related you need. Go with the double thickness gasket for the tops of those carbys. They seal so much better. It really isn't hard to run the two carbs. Screw the idle adjustment screws in gently until they seat, then back them of 1 1/2 turns. Done. A cheap home use ultrasonic cleaner unit and rebuild kits and Bob's your uncle.
    Andy
