Projects Fm converter, how to set it up
Discussion in 'The Hokey Ass Message Board' started by The_Cat_Of_Ages, Jun 1, 2023.
  1. i just purchased an old sparkomatic Fm converter for very cheap, a manual wasnt included however, neither was a mounting bracket (bracket is the easy part) i was wondering what i tune to to make it work, aswell as anything i need to know about it before installing it. 20230601_211312.jpg
    down-the-road likes this.
  2. I think there was only two wires coming from the unit, one hot (possibly with an inline fuse holder?) and one ground. Disconnect your antenna cable from your AM radio and connect it to the FM converter. Take the antenna cable from the converter and plug it into the antenna jack on the AM radio.
    You might also search for an installation manual for an Audiovox FM Converter FM-1C. Appears to be the same unit with a splash of chrome and different branding.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ This. You’ll need to find AM channel to receive FM signal. Been so long I don’t even remember which end of the dial to go to. There’s alway’s play a second radio on FM station then match car to what’s playing. That’s what I did.
    The_Cat_Of_Ages likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ That’s a XM converter.
  5. squirrel
    from the internets:
    "Output approx. 1400 kHz (adjustable)."
    that means tune the AM radio to 1400 (or 140 or 14 on the AM band, depending on how the thing is labeled)
  6. Black Panther
    Black Panther
    from SoCal
    I had one on my 65 Mustang in high school. Yup...you just plug the antenna into it...then the pigtail from the converter into the radio...tune to a specific spot as mentioned on the AM dial and it works! Surprisingly well I might ad.
  7. FM?
    that's for hippies
  8. blue 49
    blue 49
    from Iowa
    I sorta remember having one that slid into my 8 track player.
    Gary
  9. KingArthursKnight
    KingArthursKnight
    Wow.
    I had one in a Willys. Simple to put in, station in my area was like Squirrel said about 1410. I don't know if that varies by location. Just fine tune the dial.
    If you really want to get current, I have a adaptor that you plug into your 8-track so you can play all the latest cassettes. Bee Gees, Hall and Oates, Oak Ridge Boys etc.
    The_Cat_Of_Ages and Algoma56 like this.
  10. KingArthursKnight
    KingArthursKnight
  11. I remember when there would be some time set aside on our FM station for special programming for hippies and rock, the rest of the time it was for the "other" long hairs! (classical)
  12. going to make a bracket tomorrow and wire it in, hopefully it works. i might have a baby chain setup in the future, an aux antenna insert intended for a sirus xm into an mp3 player, into the fm converter, into the am radio. it seems to internally ground to the bracket.
    thank you so much for all the helpful information. 1410 am, and i will look that manual up. hopefully install goes smoothly.
  13. Pete1
    Pete1
    from Wa.
    Those can be easily modified to listen to the cops if you are so inclined.
    Desoto291Hemi likes this.
  14. Once you have power to the converter, plug the antenna leads in, and when you tune across the AM dial around the 1400 Khz you will find a spot where the background hiss disappears. This is the output of the converter. Now tune the converter and you should hear the stations come in.
    Algoma56, ClayMart and squirrel like this.
  15. Now you can listen to "Classic Rock" All 100 songs...If you miss it today, listen tomorrow :eek:
  16. or rather my XERB archive... and my massive collection of... limewire blues
    Algoma56 likes this.
  17. installed and starting to work, i think my caps have given out at this point. audio is very quiet. 20230602_115758.jpg 20230602_115801.jpg 20230602_125539.jpg 20230602_161757.jpg
  18. squirrel
    how does the AM radio work on AM stations, when connected directly to the antenna?
  19. I installed a few of these many years ago, and from memory the low signal output to the AM radio meant you had to crank it up to hear anything. You could try an RF amplifier in series with the FM output.
  20. it used to work pretty well, but even with out the fm converter it started crackling. the caps need replaced.
  21. sunbeam
    sunbeam
    Just replaced the radio in my Japanese mini truck it had one of those tuners for FM because Japan uses a different FM band. If anyone can use it just pay the shipping It was working fine.
  22. I have a fairly new Audiovox one I bought around 1974, I have had it in a few cars. That one came with a bracket that could be taped or screwed into the bottom of the dash.
  23. proartguy
    proartguy
    from Sparks, NV
    The instructions for my Audiovox converter indicate to set the original am radio to 1400. I use a preset button on the original radio set to 1400 to switch to the fm and the other buttons for am reception. The converter works quite well.
