Projects All in a day's work..
Discussion in 'The Hokey Ass Message Board' started by J.Fishbeck, Nov 8, 2021.
  1. And Conders art
    J.Fishbeck likes this.
  2. That's pretty cool looking.. I like that. A lot to see in that picture
    Tman likes this.
  3. The axle is rad. Norm was showing me a dragster he did, w/ an axle similar, to that rendering
    Tman likes this.
  4. Melted the bottom on. Norm approves
    das858, brEad and loudbang like this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Your becoming a Marcel De Ley the 2nd.
    51 mercules and J.Fishbeck like this.
  6. Installing a magnifying lens in the welding helmet, has definitely made a difference. Now that I can clearly see the puddle, fusion welding is quite a bit easier. Practiced on some s****, before welding on the dzuz pads, to hold the front grille. Continuity has been an issue, in my welds appearance. Feels like today should be Friday.
    El Mirage this weekend!
    20230518_105617.jpg 20230518_105621.jpg 20230518_105625.jpg 20230518_105629.jpg
  7. Flat 3003, to an attached grille shell, of Norms design. Stoked! Made the dzuz pads, attached the springs then drilled and dimpled the holes.
    I named the roadster, quick disconnect
    brEad, loudbang and Tman like this.
  8. Removed everything off the ch***is, once again, for better access to the areas still needing to be welded. Working with the different thicknesses has been a great learning experience
  9. I've been hitting this from all angles, tig'ing everything that needed finishing. Once right side up again, Norm wanted to start focusing on the grille, and figuring where the rockers are going to be peeking out, through the grill sides..
  10. Bolted the seat down, again and rechecked center. Then stepped back and eyed whether everything was lined up with the seat back. Then on to machining the bearing ID, to fit the upper steering tube.
    das858 and brEad like this.
  11. Still working on the grille shell and welding up the loose ends on the frame.
  12. I've taken the grill on & off, multiple times. Marked it and filed it, until the torsion rockers have enough 'clarance'. So now all the dzuz fasteners fit and I can fine tune the final shape. 20230627_123444.jpg
    Color sanding off the orange peel for the 30A truck.
    brEad, loudbang and Stan Back like this.
  13. For the most part, both front fenders are polished. Come morning, I'll get to the front apron, headlite buckets and finish up on the fenders.
    31Apickup, Squablow, Tman and 4 others like this.
  14. Happy 4th..
    Tomorrow, the new front bumper goes on. Then it's on to project next..
    Just figured out, how that "ignore" ****on works! OoooWee.. Happy days!
  15. Looks like I've been using anti-seize
    Jeff34, Johnny Gee, winr and 3 others like this.
  16. Nothing really photo worthy, has been going on, lately.
    Here's a pattern similar to the dash I made for my rdstr.
    Tman likes this.
  17. Now to tip up a flange on the bottom edge..
  18. That looks eggzactly like a dash they did in a sportscar inspired T 20 some years ago in SRM
  19. I got the idea from the original 26-7 roadster dashes. I exaggerated everything (that's what I'm mostly known for, anyways)
    51 mercules, loudbang and Tman like this.
  20. I had tried the same shape in my T but decided on symmetrical
  21. I told Norm, if we ever put a clutch in this thing, we'll have plenty of "knee room"
    brEad and Tman like this.
  22. Good call.
  23. I tipped a light bevel for character and then a 90° flange..
    brEad, loudbang, Tman and 1 other person like this.
  24. I want to french (small F) the taillights into the tailgate. I think it'd be worth the time.
    loudbang, patsurf and 51 mercules like this.
  25. Welp.. couldn't use the other taillights, as they weren't shallow enough to clear things inside the bed. So he picked up some 50 Pontiacs at my request. Frenching these in, is no bueno.
    Went and picked up the steering wheel center, after having it waterjetted (that's a word, now)
  26. A mini turtledeck
    Stan Back and J.Fishbeck like this.
  27. That's Norm's favorite part.
    I originally made the first piece, that didn't fit, without that upward transition, more like a 32 rdstr. So when I made the second one, I went with this idea, instead. It covers the breather vents, for the gas tank.
    51 mercules and Stan Back like this.
  28. Mocking up the first of the interior panels, out of some mystery, donor aluminium material
