Technical New Lifters - Clean up or return?
Discussion in 'The Hokey Ass Message Board' started by Moedog07, Jun 3, 2023.
  1. Moedog07
    Moedog07
    I am building a SBC (Probably from a Corvette :eek:).
    These are the new Speed-pro hydraulic lifters part number HT-817R. (The "R" must indicate rusty edition) They were mail ordered and arrived in the original packaging from Advanced Auto Parts. The discoloration is mild corrosion or rust.
    My question is should I go through the h***le of returning them or use a scotchbrite pad or 800 grit sandpaper to clean them up? The rust is only on the areas shown in the photos.
    20230603_212729.jpg 20230603_212736.jpg 20230603_212751.jpg 20230603_212756.jpg
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    ***uming you bought these recently ,absolutely , return them .
    If you've had them for a time ,penetrating oil & a rag , no abrasives !
  3. lippy
    lippy
    from Ks
    Send em back that's BS. Lippy
  4. Bird man
    Bird man
    from Milwaukee
    Wow, those are Fugly.
    Depends, are you willing to risk a cam replacement?
  5. I wouldn’t use those on a bet!! Send them back from whence they came.
  6. alanp561
    alanp561
    What he said^^^^^^^^^^^^^
  7. 427 sleeper
    427 sleeper
    You paid for Brand New, Ready to run part's... Those are NOT it!!! Send 'em back.
  8. Given that "perfectly" good new lifters fail all the time why would you chance it?
  9. 427 sleeper
    427 sleeper
    You DON'T want them to be FLAT!!!
    Jet96, b-body-bob, RICH B and 24 others like this.
  10. Jagmech
    Jagmech
    Junk, order quality lifters from Jones Cams, USA made, pay the correct price for quality. Do some research on the **** that companies we used to trust, 30 years ago, are selling. Melling, Sealed Power, Comp, don't use them anymore because quality is terrible.
  11. gimpyshotrods
    gimpyshotrods
  12. tomcat11
    tomcat11
    That rust is a blessing. It made you question them and now your not going to use them. Lucky you. Return that junk to sender.
  13. jaracer
    jaracer
    But the bottoms are supposed to be convex, not flat. I'd send them back.
  14. ClayMart
    ClayMart
    Do you suppose the "R" might stand for Resurfaced or Refurbished?
    The machined finish on the faces looks kind of strange to me. The straight pattern running radially from the center of the face just looks out of place. It makes it look more like the convex profile of the face would almost be more conical rather than a smooth radius. Maybe it's the lighting.
  15. slayer
    slayer
    I thought the R is for rusty! lol
  16. That's a heck of a dilemma since you are in Norway and besides all the h***le of long distance communication, timely resolution may be a pipe dream....
    Is there a cam grinder in your area that could help you evaluate these things? As was pointed out above, could the "R" denote resurfaced or refurbished? I would sit down with a mic or calipers and measure each one to know what you have. Do they all match?
    It might be possible to clean and polish those to a satisfactory finish, but you'll still be at the mercy of the worst one.
    Good luck!
    And yes, your SBC is probably from a Corvette (aren't they all?)
    Moedog07 likes this.
  17. spanners
    spanners
    Given the dude is in Norway I'd be inclined to get a local to reface them but I'd be contacting the supplier and let them know of the issue. If they are sent back who know how long before another set turns up and what if they are just as bad?
    '28phonebooth and lothiandon1940 like this.
  18. bobss396
    bobss396
    Possibly a run of counterfeit parts, or someone cut corners on a cleaning process. Most lifters I used to get were well-wrapped to prevent **** like this from happening. Maybe they were reboxed and the protective coat of lube was washed off them.
    ClayMart likes this.
  19. goldmountain
    goldmountain
    On the other hand, maybe they just have a little of surface rust because they are new old stock from back in the day when they made good quality lifters. Good luck with whatever you decide.
    Tman, Algoma56 and vtx1800 like this.
  20. ray
    ray
    from colorado
    that is exactly what most aftermarket "new" lifters are. i read some time back this is one of the causes of lifter failures. while dimensional checks etc. may be done easily enough, if a heat treated part is re-ground, re-heat treating is hit or miss, if an option at all.
    also, Iron oxide(and most all oxides) are actually harder than the metal was before it became oxide. so no,, you certainly don't want hard spots of rust rubbing against your new cam.
  21. Moedog07
    Moedog07
    Who sells Johnson Lifters? Do buy directly from the manufacturer?
    Jegs, Summit?
  22. lippy
    lippy
    from Ks
    What's the story on being a Marine in Norway? Just wondering. Lippy
  23. Ebbsspeed
    Ebbsspeed
    His profile says USMC 1993-2001. Probably married a Norwegian hottie who wanted to move back. They do, after all, have a functioning democratic political system and a relatively neutral media.
  24. Moedog07
    Moedog07
    Norwegian father, American mother. Benefits to both countries, when money is available, dual p***ports and I always wanted to be a US Marine.
    Semper Fi.
  25. metlmunchr
    metlmunchr
    I agree with Claymart that the finish on the face doesn't look right, or at least it doesn't look like the finish on any quality lifter I've ever looked at.
    Also, although there's no side view to compare, the chamfer on the edge of the face looks too large. Standard is around .010" just to break the sharp edge. If the combination of lobe profile and chamfer depth causes the lobe to contact the chamfer then the cam will be destroyed. As one writer put it, this is something that has always been known, but never presented a problem prior to the widespread use of imported lifters with poor quality control.
  26. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Probably the salt air on the trip frm China got to them.........
    To the best of my knowledge, Johnson doesn't make flat tappet lifters anymore, only roller.
    Did you ever wonder why they call them Flat tappet if they are convex ?
    IF......you are stuck with them, you might try hydrosonic cleaning in some kerosene. If you dis***emble and soak them in kerosene for an extended time (a week) it should disolve the rust without harming any surface finish. I have never tried using kerosene in a hydrosonic cleaner and don't know that it might not catch fire, but doubt it. I figure the hydrosonic action coupled with the natual ability of kerosene to disolve rust would do a through job. I would however attempt to get replacements as my first course of action.:)
  27. Budget36
    Budget36
    Recent purchase or? If recent send them a pic and have them send you a mailing label.
    Also ask for an RMA so when they get them, they can easily receive them and send out a good set.
  28. krylon32
    krylon32
    from Nebraska
    Nothing more to say here. Contact the seller, get a return authorization and send them back. Parts are to expensive today to accept those.
    s55mercury66 and 427 sleeper like this.
  29. I got a feeling he's either AWOL or has been placed in the witness protection program, but in any case, we've probably blown his cover now!
  30. Thank you for serving. I'll leave my Jarhead jokes at the door ;)
