Technical 1962 Ford Fairlane starter removal
Discussion in 'The Hokey Ass Message Board' started by Malpass, May 31, 2023.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ I only covered the basics. Jim went further in depth and all valid.
  2. Malpass
    Malpass
    Thanks guys! I’ll give that a shot in the morning!
  3. sunbeam
    sunbeam
    With the key on have you lost any other electrical? The power to the car comes from wires that go on the same terminal as the battery cable at the starter. Did you leave one off?
  4. manyolcars
    manyolcars
    I had the same start/but not continuing to run. It was a bad ballast resister
  5. Malpass
    Malpass
    Oh, and fwiw: the distributor has been swapped out for an HEI style unit, if that makes any difference.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    HEI prior to starter swap or during?
  7. squirrel
    A test light is your friend
  8. Malpass
    Malpass
    The HEI was prior
  9. Malpass
    Malpass
    Test light confirms that I have power on both posts upon ignition, but once the key is released I lose it. ¯\_(ツ)_/¯
  10. Malpass
    Malpass
    This is the way I have it wired…
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s the starter wiring. What about distributor wiring?
  12. Malpass
    Malpass
    The distributor wiring hasn’t changed since I put it in, so I would be shocked if that was the issue.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ok but your diagram doesn’t tell any of us how your distributor is wired? Now if your distributor is wired to the key switch/push ****on terminal of starter relay that would explain why it run’s only for a few seconds.
  14. Malpass
    Malpass
    Ok! Got ya. So yes, the dizzy is wired to the ignition switch
  15. Malpass
    Malpass
    Just curious why this would all just start happening now, however.
  16. AngleDrive
    AngleDrive
    from Florida
    Cause you worked on it. Happens to all of us.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I don’t have an answer. Vehicle is with you and I can’t see a thing. Jim (Squirrel) did say to put a test light to things to see what wires are doing when ignition switch is at On position and Start position. Some disconnecting of wires required.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Been there.
  19. Malpass
    Malpass
  20. Malpass
    Malpass
    @Johnny Gee all good my man, I appreciate all of the help from everyone! I just verified, with the key on, I have power going to the distributor, and it stays on and lit, even after the car dies
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    How does the wiring look? Are the terminals hanging by two strands which would be enough to get a reading but not enough to get all the voltages to the distributor.
  22. Malpass
    Malpass
    @Johnny Gee No sir, all of the wiring is about as fresh and clean as it can be. I’ve tried to be sure that if anything looks unkempt I immediately replace or repair it all properly with the correct connectors and heat shrink.
    Johnny Gee likes this.
  23. Malpass
    Malpass
    Ok, so I fooled around and swapped some wires and it starts and runs now. But weirdly it starts by turning the key to the “on” position. And when I turn the “off” you can hear the starter slowing down. This is a giant pile of WTF. I took a video to show what I’m talking about but hopefully you get the gist.
  24. Malpass
    Malpass
    I think I figured it out finally!
    There was an extra, but apparently not needed wire on the starter solenoid. I removed that and VIOLA! Car starts and runs as it should!
