Technical 49 ford car brake help
Discussion in 'Traditional Hot Rods' started by junkyardkat, Jun 4, 2023.
  1. junkyardkat
    junkyardkat
    Hi all, having a brake issue and am out of ideas. The car pulls hard left when applied. New brake cylinders, shoes, hoses. master cylinder and good drums. Loosend left brake adj. all the way still pulls left, does not do it in reverse if that helps. Totally out of ideas.
  2. Drum out of round? Short shoe in the rear position?
  3. junkyardkat
    junkyardkat
    Checked that all seems to be alright.
  4. Unless they gave you a wheel cylinder that's a smaller bore, I wouldn't know man, I'm out of ideas
  5. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Did you get grease on the shoes. Even a greasy fingerprint can cause issues. Did you replace the return springs?
  6. manyolcars
    manyolcars
    Pull the right drum, get someone to press the brake pedal, see what happens
    1971BB427 likes this.
  7. JohnLewis
    JohnLewis
    I'd assume its the same with drums as it is with disc brakes. How do the bearings look? A loose bearing causing pulling under braking, possibly?
  8. jaracer
    jaracer
    Pulling hard left probably means the right brake isn't functioning properly. The left one is working good. I'd be inspecting the right brake. Do the shoes fit the drums well? They should hit in the middle of the shoe with a few thousands of clearance at each end. Are the drums in good shape or at least in about the same shape?
  9. jerry123
    jerry123
    Check your rubber hoses
  10. I would pull both front wheels, and have someone lightly depress the pedal while you check the right drum, it should start out with a light drag and get harder to turn as the pedal is depressed. Since you replaced all at the wheel, the brake line could be kinked or plugged going to the right.
  11. junkyardkat
    junkyardkat
    Good ideas I'll give them a try, thanks.
  12. brando1956
    brando1956
    Have you checked all suspension components and made sure everything is right and tight? Did the problem exist before you did the brakes? Not familiar with the front-end setup on these but if something is loose or worn, braking can let things move around and "steer" the car. Don't forget the rear suspension, same thing applies.
  13. If nothing is loose in the front end, swap the drums side to side and see what happens.
