Hot Rods Powerglide Transmission Flexplate/Converter Questions
Discussion in 'The Hokey Ass Message Board' started by davvet2, Jun 3, 2023.
  1. Marty Vanin
    Marty Vanin
    A lot depends on the output shaft that’s in the trans.If its a stock shaft,putting a speedo gear on it isn’t a problem.If it’s a hardened aftermarket shaft there is no hole to locate the speedo gear or a hole drilled thru the shaft for the governor pin which you will need along with a valvebody to put it back to automatic shift.You will need all the linkage that goes from the ****** to the carb.
    Kevin Ardinger likes this.
  2. davvet2
    davvet2
    Thanks, that info helps. I don't have a third member in the car yet, and the tires and wheels are just to roll it around, so I have a lot to do. Jim
  3. Kevin Ardinger
    Kevin Ardinger
    I think you can get a speedometer set up that uses magnets on the driveshaft for pickups. That trans specialties output shaft, probably does not have provisions for a speedometer gear.
  4. davvet2
    davvet2
    I may have to go that route, especially if I leave the trans brake in. Thanks, Jim
  5. Kevin Ardinger
    Kevin Ardinger
    I think they even have them that are GPS operated. Don’t even need magnets.
  6. davvet2
    davvet2
    Decided to sell the racing powerglide transmission, and have the turbo 350 I bought rebuilt and get it installed. Thanks to everybody that helped me with this project. Jim
    s55mercury66 and squirrel like this.
  7. davvet2
    davvet2
    I posted a want ad for this -- no response yet.
    I'm looking for a Winters/Fairbanks/Sidewinder gated Powerglide reverse patten shifter at a reasonable cost.
    Anybody have one? Thanks, Jim
