Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. 327Eric
    327Eric
    I must not be a car guy. I sure can eat though.
  2. Lloyd's paint & glass
    Riddle me this, will a mark 4 big block oil pan work on a gen 5 block? Everything I'm seeing is up to 1990. Mine is a 92 truck engine. I guess I'll need to change the pan to go on my car?
    enloe likes this.
  3. Budget36
    Budget36
    I’m in the “no” camp. I’m betting 1pc vs 2pc pans are different.
    Check summit, I’d bet they have pans for both types.
    mad mikey, enloe and 427 sleeper like this.
  4. lumpy 63
    lumpy 63
    It wont work due to the 1pc rear seal....
  5. Los_Control
    Los_Control
    from TX
    LOL, so true. I married my wife in 1990, not because she could cook.
    Now I'm retired, I handle the shopping & cooking :rolleyes:
    mad mikey, enloe, 427 sleeper and 3 others like this.
  6. Lloyd's paint & glass
    So was a 90 model 2 piece or 1 piece? I figured it was 1 piece! Lol
  7. Budget36
    Budget36
    Pretty sure all Gen 4 BBCs are two pc RMS.
    If it’s like a SBC, the rear of the crank where the FW/FP bolts on will be a round inch+ thick flange for the 1 pc seal.
    Lloyd's paint & glass likes this.
  8. Lloyd's paint & glass
    OK I'll get a new truck pan
    mad mikey and 427 sleeper like this.
  9. lumpy 63
    lumpy 63
    You could sandblast your old pan and just fill the pinholes with bondo, Im sure it will be fine:D
    SS327, loudbang, bchctybob and 2 others like this.
  10. saltflats
    saltflats
    from Missouri
    I have one of the pans that would come on a 502 crate engine with one piece rear main seal.
    mad mikey, enloe, 427 sleeper and 4 others like this.
  11. Lloyd's paint & glass
    How much ya want for that weed Popeye? ;)
  12. saltflats
    saltflats
    from Missouri
    Your welcome to it.
    mad mikey, enloe, 427 sleeper and 2 others like this.
  13. Lloyd's paint & glass
    Check out the edelbrock i just pulled the top off of.... little seafoam and call it good? Lmao! 20230607_173216.jpg 20230607_173219.jpg 20230607_173221.jpg
  14. Lloyd's paint & glass
    I'll pm ya
    mad mikey and enloe like this.
  15. lumpy 63
    lumpy 63
    Thats FUGLY
    enloe, 427 sleeper and scotty t like this.
  16. saltflats
    saltflats
    from Missouri
  17. chevy57dude
    chevy57dude
    Confirmed, MK IV and Gen 5 pans do not interchange. Went through this myself. Gen 5 has a slightly better oiling system.
    mad mikey, enloe, lumpy 63 and 2 others like this.
  18. 427 sleeper
    427 sleeper
    W.T.F. do they put in the gas down there? :confused: We've got straight **** for gas up here, but that don't happen! **** Me... That's Brutal!!!
    mad mikey, enloe, scotty t and 3 others like this.
  19. swade41
    swade41
    from Buffalo,NY
    I bought a pair of Edelbrock's here in the cl***ifieds, sorta famous pin striper from California, the carbs were complete garbage inside, totally unusable, the outside looked good though.
    Every time I see him on TV I say there's the guy that ****ed me on a pair of carbs
  20. Brian Penrod
    Brian Penrod
    Also have to be aware of different heads and head gaskets on Gen 5. Do your research.
    mad mikey, SS327, chevy57dude and 2 others like this.
  21. Lloyd's paint & glass
    Yeah I got the head gaskets and fuel pump sorted out. And the oil filter adapter :D
  22. gene-koning
    gene-koning
    First off, if I have to cook it, you don't want to eat it, and would probably be well advised not to try. I can push the ****ons on the microwave though... When I cook, we go someplace to eat and I buy.
    I've owned two Chevies in my life, both for about 20 minutes, and both were sold. I never even drove them. I did make a few bucks off of them. Over the years I've fixed a lot of broken Chevy cars and trucks for others. I drove a different make of GM car, and owned and drove the 2nd different make GM car. I killed both of them, they don't hold up very well for me.
    That carb looks about like the last 3 or 4 I've taken apart. This stuff they call gas kills old carbs pretty quickly. Up here in corn country, we don't have another choice. Back when I was running carbs, I had to pull them apart and clean them up and put a kit in them every year if I wanted it run correctly. One of several reasons there are no carbs at my house.
  23. enloe
    enloe
    from east , tn.
    you coming to Bowling Green next week James
  24. 327Eric
    327Eric
    My 427 had a moroso 7 quart pan. When I went to a 327, I used a 65 Impala oil pan. I know they are completely different engines, but take a look at the 65 small block pan, as it has a different shape that hit the crossmember. Here is a picture of the big block version. It hit on the front of the middle step. s-l1600.jpg I used the ****** 2 inch ch***is headers that went around the outside of the frame on the rear tubes.
  25. saltflats
    saltflats
    from Missouri
    No sorry we are covered with life and home improvements. How ever I did order some connecting rods for the 409 going in Geronimo. :)
  26. enloe
    enloe
    from east , tn.
    we will miss you this year
  27. lumpy 63
    lumpy 63
    Is the block at the machine shop yet?
  28. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    That looks like the aftermath of ethanol fuel rotting away in it. Fortunately, we can still get straight premium up here, but some of my friends are cheap ***'s and run the **** stuff and then have issues with the fuel system every spring cause of the moisture that condenses from sitting in storage. You could try to save it, but if it was me, I would move on to something else. Keep up the progress! Larry
  29. Lloyd's paint & glass
    Yes sir. Block, crank, and rods. Funny thing, those plugs that covered the bolts that held the oil filter adapter on, are 3/8npt, they fit the holes where the cooler lines came off :D it's like GM intended it that way ;)
  30. Lloyd's paint & glass
    Yeah I sent those pictures to the guy that owns the carburetor, he said toss it, he'll get a new one lol
    mad mikey, enloe, LWEL9226 and 2 others like this.
