Technical Bushings
Discussion in 'The Hokey Ass Message Board' started by bobkatrods, Jun 6, 2023.
  1. bobkatrods
    bobkatrods
    from aledo tx
    Any recommendations where to get 1.250 4 bar bushings? I have checked all the suspension manufacturers that I can think of seems most common size is 1.125.
  2. Lloyd's paint & glass
    Amazon shows these. I Googled 1.250 4 bar bushings. Screenshot_20230606-161102_Samsung Internet.jpg
    lothiandon1940 and pprather like this.
  3. Jmountainjr
    Jmountainjr
  4. rockable
    rockable
  5. stephen alquist
    stephen alquist
    I have a 47 Ford coup & I found new front end parts for my car at a great price on ebay & rockauto.
  6. bobkatrods
    bobkatrods
    from aledo tx
    They only have 1.125.
  7. bobkatrods
    bobkatrods
    from aledo tx
    already ckd those, but looks like Loyds Paint-Body has found them
  8. bobkatrods
    bobkatrods
    from aledo tx
  9. bobkatrods
    bobkatrods
    from aledo tx
    Thanks looks like the ticket, I somehow missed amazon, even typing in the 1.250
  10. Bearing Burner
    Bearing Burner
    from W. MA
    Br*** or bronze bushings are available from industrial supply housed.
  11. drtrcrV-8
    drtrcrV-8
    Have you checked Grainger Industrial Supply??
  12. chevyfordman
    chevyfordman
    Find a buddy with a lathe and make your own out of acetal rod or delrod. It will be easier in the long run.
  13. bobkatrods
    bobkatrods
    from aledo tx
    I have a lathe, didn't think of making them,where do you get delrod or acetal rod,
  14. bobkatrods
    bobkatrods
    from aledo tx
    Really looking for urethane
  15. bobkatrods
    bobkatrods
    from aledo tx
    I found some material Delrin
  16. rockable
    rockable
    Use the Energy Suspension part number and check Summit Racing. They probably have them in stock.
  17. chevyfordman
    chevyfordman
    I buy it from MSC, it is expensive but fun to make too and it comes in black.
    bobkatrods likes this.
  18. '29 Gizmo
    '29 Gizmo
    from UK
    Delrin is a bearing material. It has virtually no compliace capability. Your geometry may require the bush to flex to take stress our of the ch***is and linkages.
