Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. j hansen
    j hansen
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Wow thanks Jack. I'm still trying to wrap my head around this. For example, the top photo shows three carbs, two in back and one in front. Did some air / fuel get inducted into the rear carbs and directly into the crankcase and other air / fuel get drawn into the middle cylinder and then force fed to the other two? All three jugs look to be of similar bore.
  3. looks like 3 pipes to me...
    J
  4. Jack E/NJ
    Jack E/NJ
    from NJ
    Later designs were apparently true triples. 3rd cylinder converted from a supercharger pump to 2-stroke combustion.
    Deuces and THE FRENCHTOWN FLYER like this.
  5. j hansen
    j hansen
  6. AmishMike
    AmishMike
    ^^^. Great pic wonder what year. Still appears no true expansion chamber exhaust. Guess they came later
  7. Dick Stevens
    Dick Stevens
    The expansion chambers on the DKW are not the most common cone to reverse cone style but are expansion chambers just the same.
  8. j hansen
    j hansen
    It is a 1954.
  9. Hope this is okay to post here...Gordie Bonin's twin-turbo funny car:
    Jet96, Thor1, egads and 4 others like this.
  10. Deuces
    Deuces
    Twin 1800 watt Revlons....:D
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    More like 900,000 watts.
    Deuces likes this.
  12. Jet96
    Jet96
    from WY
  13. Deuces
    Deuces
    Moser small block chevy with 4 valves per cylinder....^^^^^
    Thor1 and jimmy six like this.
  14. AmishMike
    AmishMike
    With an old junior fueler screaming to 9000 rpm, what would the moser spin?
  15. j hansen
    j hansen
  16. Deuces
    Deuces
    Imagine those heads on a chevy 302....:cool:
  17. jimmy six
    jimmy six
    I met Pete 25 years ago at the Pomona Fathers Day Swap Meet and Show. In his booth there were at least 10 engines all with overhead camshafts. We talked about a GMC six but the SCTA rules didn’t allow them unless you ran heads up against cubic inches.
    I don’t think there was an engine he wouldn’t put a set on. We are currently the same SCTA Member club. I’ve admired everything that man has done..
  18. AmishMike
    AmishMike
    Would love to know more about those engines & see pictures
    Deuces likes this.
  19. '51 Norm
    '51 Norm
    from colorado
    I have always been curious about where a person would get cams for a one off set of heads.
    Deuces likes this.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Many cam manufacturers will grind one-off cams for projects. Of course they could get pricey as setup costs are significant. You may have to supply the cam blanks too.
    egads and Deuces like this.
  21. Jet96
    Jet96
    from WY
  22. j hansen
    j hansen
    Deuces likes this.
  23. 64 DODGE 440
    64 DODGE 440
    from so cal
    Corvair with shielded military style ignition?
  24. j hansen
    j hansen
  25. down-the-road
    down-the-road
    I'm not sure how to cl***ify this engine, but it was running strong on the "circle track at the Big Knob Grange Fair this past week!
    Seating for four drivers! It might be a little too big to enter in the valve cover races.
    Lepus, Thor1, 41 GMC K-18 and 5 others like this.
  26. choptop4
    choptop4
    My two .
    KiWinUS, Thor1, LAROKE and 8 others like this.
  27. Plymouth Indy motor perhaps...?
    KiWinUS, Thor1, Deuces and 9 others like this.
  28. Deuces
    Deuces
    Those look like Gurney Weslake (sp) heads.... I could be wrong....
    Ned Ludd and seb fontana like this.
