Projects 1950's Tube Frame Sports Car
Discussion in 'The Hokey Ass Message Board' started by jebbesen, Oct 5, 2015.
  1. ROADSTER1927
    ROADSTER1927
    Looks Great Buddy!
  2. Progress! 1 day at a time.
  3. Rand Man
    Rand Man
    You do good work.
  4. jebbesen
    jebbesen
    from Winona, MN
    Made a little more progress yesterday. Worked on the clearance bump that clears the kingpin lock bolt. 20230609_154304.jpg 20230609_154312.jpg 20230609_155808.jpg 20230609_155830.jpg 20230609_155915.jpg 20230609_155956.jpg
    Next I need to add a couple small gussets and then box the underside. Made a template this afternoon for the underside piece. 20230610_111504.jpg
    Stogy, BradinNC, ottoman and 9 others like this.
  5. ROADSTER1927
    ROADSTER1927
    Looks great progress is progress! Gary
  6. Dave G in Gansevoort
    from Upstate NY
    Looking good Jeremy. Remember tho to glue the nice Cheerios graphics on for the final finish...
    Squablow likes this.
  7. jebbesen
    jebbesen
    from Winona, MN
    Added the gussets and welded the underside boxing plate on. The sheet metal I used for the underside must have not been mild steel. I'll have to cut it out and redo that since it kept cracking along the weld. The sheet metal guys at work said it was when I got it from the s**** bin but who knows. The cracks don't show up in the last pic but they're there. I'll post some more pics when I get it fixed and 20230611_155448.jpg 20230611_155441.jpg 20230611_162232.jpg 20230611_155936.jpg 20230611_165528.jpg 20230611_180238.jpg
    Stogy, ottoman, brEad and 1 other person like this.
  8. jebbesen
    jebbesen
    from Winona, MN
    A while back I'd made a new set of tube axle kingpin lock bolts. That set was made to original Ford dimensions. Once I got my 4 bar together I checked to see how I was for tire clearance. At full lock I could just kiss the suspension with the corner of the tire. To make sure that didn't happen I sold that set and made some that had 0.100" additional head height. Finished the new bolts and nuts yesterday. Used 4140 hex stock. 20230613_173024.jpg 20230613_173123.jpg 20230613_173132.jpg
    Stogy, BradinNC, ottoman and 11 others like this.
  9. jebbesen
    jebbesen
    from Winona, MN
    Cut the cracked boxing plate back out and used a piece of .09 thick hot rolled to remake it. No cracking now. After grinding I blasted it and shot some etching primer on. 20230616_135758.jpg 20230616_135825.jpg 20230616_143322.jpg 20230616_151326.jpg 20230616_151345.jpg 20230616_151352.jpg 20230616_152002.jpg 20230616_152021.jpg
  10. ROADSTER1927
    ROADSTER1927
    Looking great Buddy!
    Stogy likes this.
  11. patsurf
    patsurf
    Stogy likes this.
  12. jebbesen
    jebbesen
    from Winona, MN
    HA! It'd take someone who is a way better and faster fab guy than I am to make a profit!
    Stogy, brEad and Dave G in Gansevoort like this.
  13. jebbesen
    jebbesen
    from Winona, MN
    Got some spot putty and filler primer on the arm this weekend. Also painted the portion of the arm and backing plate that will be covered once ***embled. 20230624_111739.jpg 20230625_182226.jpg 20230625_182235.jpg
    Stogy, dumprat, brEad and 3 others like this.
  14. jebbesen
    jebbesen
    from Winona, MN
    Finally was able to get the new steering arm on. I blasted the spindle where I'd heated and dropped it for tie rod clearance. Then painted the end of the axle and the back of the spindle. The new kingpin lock bolt drove in nicely. 20230702_151555.jpg 20230702_151604.jpg
    I had quite a battle getting the arm bolted on. I had very minimal warpage when welding it up but just enough that it was difficult to get all the bolts started. Eventually it worked and I torqued the 1/2-20 socket heads to 90lbs with red loc***e. 20230702_153807.jpg 20230702_153816.jpg 20230702_164026.jpg 20230702_164053.jpg 20230702_164103.jpg 20230702_164115.jpg 20230702_164133.jpg 20230702_164428.jpg
    V8-m, Stogy, cactus1 and 6 others like this.
  15. jebbesen
    jebbesen
    from Winona, MN
  16. jebbesen
    jebbesen
    from Winona, MN
    Next I'm gonna get the steering gear mounted so I can make the drag link. Set the old tie rod on to get a visual.
    Stogy and brEad like this.
  17. Dave G in Gansevoort
    from Upstate NY
    Looking good Jeremy. That steering arm is missing something tho... oh yeah I remember, the Cheerios box graphics!
    Stogy, X-cpe and brEad like this.
  18. Still one of the coolest threads going
    Stogy likes this.
  19. jebbesen
    jebbesen
    from Winona, MN
    Thanks guys. I try to compensate for being one of the slowest threads by posting lots of pics. Lol. I'll work on the graphics Dave!
    Got the other spindle on this afternoon. 20230703_154407.jpg 20230703_154419.jpg 20230703_160445.jpg 20230703_160542.jpg 20230703_161154.jpg
    Stogy, tractorguy, cactus1 and 3 others like this.
  20. Dave G in Gansevoort
    from Upstate NY
    And looky see those nice new tires! Period perfect! Car is looking good. And don't feel bad about the progress. You're still young and gainfully employed. I'm not making very good progress, and I'm gainfully retired!
  21. Dave G in Gansevoort
    from Upstate NY
    So going up over the hill into turn 1 at Road America the 1st time is going to be a real thrill for you. Skinny tires, old Ford brakes and suspension... oh yeah!
    hotrodfil, Stogy and jebbesen like this.
  22. jebbesen
    jebbesen
    from Winona, MN
    Yeah I'm under no illusion that this thing will actually be that fast, handle well or stop fast by modern standards :) In 1953 it would have been pretty hot though! The big Lincoln brakes should do way better than the typical early Ford ones that it came with!
    My 3rd kid was born on the 4th of July so it's been pretty busy around our place. Everyone is healthy though so it's all good!
    Tonight I got a little bit of time to work on putting the cast brake drums on the rear. I fitted them when I built the axle but them switched them for the original tin ford ones when I primed the axle. I wanted to be able to prime the cast ones inside and out before installing. They fit a little too well. I had to sand the primer out of the pilot diameter and stud holes.
    20230708_173344.jpg I also shot some paint on the right hand spindle before I pump grease in.
  23. Dave G in Gansevoort
    from Upstate NY
    I love your paint by installment plan. Have I ever told you just how much I? Maybe your way would make it tolerable. Glad to hear everyone is doing fine. 4th of July sounds like a great birthday.
    Stogy likes this.
  24. jebbesen
    jebbesen
    from Winona, MN
    I plan to take the suspension all back off and paint it after it's all done but then there is always spots that are really hard to get to. I figured I'd do areas like that knuckle so that the main spray job is just a second coat. Plus then if I grease it to test out the suspension there's already some paint in that area when some oozes out. The cream color I'm using is International Harvester white so the paint is easily available in both quarts or aerosol.
    Stogy, SS327, brEad and 1 other person like this.
  25. jebbesen
    jebbesen
    from Winona, MN
    Got the original rear shock mounts removed this afternoon and the new ones welded on. Tried to go slow and not damage the tube while I cut the old ones off. Took a lot of grinding and peeling layers off. 20230821_154954.jpg 20230821_161144.jpg 20230821_161929.jpg 20230821_162029.jpg 20230821_162406.jpg
    After they were removed I got set up to tack the new ones on. I'd made a board that had two holes the correct distance apart. Once the frame was level I just put a level on that board to align the new mount. 20230821_165845.jpg
    Then the board was removed and the rear halves bolted on with a shock sleeve to space them. 20230821_170025.jpg
    Once all the pieces were tacked I test fit the shocks and burned them on. 20230821_172602.jpg 20230821_173609.jpg 20230821_174131.jpg 20230821_174318.jpg
    Now I have to get the front shocks mounted.
  26. brEad
    brEad
    Nice job! Very clean.
    Stogy and The_Cat_Of_Ages like this.
  27. Dave G in Gansevoort
    from Upstate NY
    Okay Jeremy, it's time for an update. We're all in limbo wanting more information.
    And I know, I'm not a good one to talk. I'm just barely making progress these days...
    Anyway, hope you're doing okay.
  28. jebbesen
    jebbesen
    from Winona, MN
    Hey Dave, Sorry for the lack of updates. It has been a super busy fall. I'm fine and the car is fine, just haven't had any chance to work on it lately. Don't worry though, it'll still happen. One thing I did find recently is a used small Helling style air cleaner for it. Eventually I'll do some sort of multi carb setup but for now I like this better than the rusty JC Whitney one that came on it. I need to made a filter base that fits the 4-7/32 air horn on the 4GC. I know they make adapters, but I think I can keep it lower if I just made an base out of some s**** alum. Not the best pic but here it is sitting on the engine. Thanks for checking in.
    V8-m, Stogy, brEad and 2 others like this.
  29. ROADSTER1927
    ROADSTER1927
    Looks good keep at it Buddy! Gary
    Stogy likes this.
  30. Dave G in Gansevoort
    from Upstate NY
    So Jeremy, just looked back to the part about how you bored the axle for 53-56 Ford F100 kingpins, because I have managed to get a tube axle! And as you can guess, the pin bores are slightly oversized, just like yours was. 10 and 15 thousandths. Not having a mill, I'm considering using a 6 blade adjustable hand reamer to get it close, and then hone to size with my Sunnen honing machine. Seeing as how you've already been there done that, what's your opinion on the way I'm considering doing it? And now that I have a better lathe, I'm going to make those lock pins to your drawing.
    Kroombit likes this.
