Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. swade41
    swade41
    from Buffalo,NY
    210superair and trikejunkie like this.
  2. trikejunkie
    trikejunkie
    from Scotland
    It looks faster than it was lol I was probably only doing 25!
    210superair and swade41 like this.
  3. lake_harley
    lake_harley
    Not actually today but last week my son came home for a couple days and help me blow the dragster apart. Had it sandblasted Saturday, primed it on Sunday, and painted it today. Now I just have to put this puzzle back together.
    Notice there's no black overspray on the floor and I didn't have anything under the ch***is when I painted it. I used an electrostatic paint system that I've had for years. I think it's something like 98 or 99% efficient. I only used about 1 1/2 pints each of primer and paint.
    I'm going to give it at least a couple days for the paint to cure and will then start re***embly.
    Lynn
  4. topher5150
    topher5150
    Not much other than spending way to much time over thinking that everything is wrong and then coming to the conclusion that ya know I think I can make it work.
    26 T Ford RPU likes this.
  5. swade41
    swade41
    from Buffalo,NY
    Finished up the fuel side on the Henry J
    Then made up some brackets and mounted the fuse box in the 41
  6. 4speed411
    4speed411
  7. Atwater Mike
    Atwater Mike
    Ready to play musical cars, need my carport to do some F100 stuff, shop's full of '27 T's.
    Daily driven exotics are cluttering up carport, so driveway #2 it is for them, with their respective car covers.
    RICH B and Papas32 like this.
  8. SuperKONR
    SuperKONR
    from Earth
  9. RICH B
    RICH B
    Pulled the sewing machine out and s***ched up some windlace for our '47. Another small step; too many distractions.
  10. DaveyJonez
    DaveyJonez
    from Houston
    092EA25F-ACC0-414D-AFD2-E52DD9315383.jpeg Started lining up my grill, splash aprons, etc
  11. RICH B
    RICH B
    Started back up on building a fan shroud for my '35. Interesting to find the parts I did a year or two ago don't match the sketches I made when I started the project; guess a plan B must have taken over. Don't look like much now, next step is getting the big hole in the right spot, will get that tomorrow.
    BigRRR, dana barlow and j hansen like this.
  12. X38
    X38
    Went for coffee this morning.
  13. Pontmerc
    Pontmerc
    from Finland
    New alternator belt and wash and a little check the ranch cruise. IMG-20230618-WA0001.jpeg IMG-20230618-WA0011.jpeg
  14. 57 HEAP
    57 HEAP
    Went from this........
    to this..........
  15. RICH B
    RICH B
    My kid came over last night and helped with the fan shroud. Flat black paint so the ugly thing doesn't show to much. Sure helped to have a young guy around to do the getting up and down from under the car. Temp stayed down pretty good while he was playing with the carb and timing. Battery was on it's last legs, so he picked one from his "battery guy" and we put it in this morning. Going to install an overflow tank tomorrow and then see how it works on the road with the hood closed.
    TrailerTrashToo, swade41 and j hansen like this.
  16. swade41
    swade41
    from Buffalo,NY
    I met up with a couple club members and went to a cruise night, 738 cars there, open wheel and g***er were featured cars tonight
    20230619_144902.jpg 20230619_150124.jpg 20230619_155342.jpg 20230619_170710.jpg 20230619_170744.jpg 20230619_164713.jpg 20230619_164652.jpg 20230619_164700.jpg 20230619_155400.jpg 20230619_170016.jpg
    MO_JUNK, LAROKE, Grandadeo and 11 others like this.
  17. Bandit Billy
    Bandit Billy
    LAROKE, impala4speed and Papas32 like this.
  18. 100mph WHEELSPINNER
    100mph WHEELSPINNER
    Today I started designing a rear roll pan. 001 A001 MAIN COUPE BODY.JPG 004 A001 MAIN COUPE BODY.JPG 005 A001 MAIN COUPE BODY.JPG 006 A A001 MAIN COUPE BODY.JPG 006 A001 MAIN COUPE BODY(1).JPG 007 A001 MAIN COUPE WITH ROLL PAN.JPG 002 A001 MAIN COUPE BODY.JPG 3d scanned my model a.
  19. Max Gearhead
    Max Gearhead
    from Wisconsin
  20. topher5150
    topher5150
    I was gone for 5 days, I had the portable garage all zipped up, and one of these blueberry munching mofo's get into my tent and IMG_20230619_120024116.jpg hopped in the window and took a big blueberry dump on my t-bird seat
    26 T Ford RPU, j hansen and swade41 like this.
  21. Needed groceries:
    -Dave
    LAROKE, RICH B, 57 Fargo and 3 others like this.
  22. trikejunkie
    trikejunkie
    from Scotland
    Today-well at the weekend I raced my Coupe powered by a 4banger at Pendine Sands 2nd in cl*** at 70.5 mph and my missus was 3rd in cl*** just behind me ,only beaten by a well established car owned by the organiser .....not bad for a 9 month build
  23. 57 HEAP
    57 HEAP
    Went on the HRPT with this guy.
    Stopped in Carthage NC.
    And a picture with Project X.
  24. Finally finished the Dana 60 for the 57, it has 1967 dated 4:10 gears, Eaton true trac, moser 35 splined axles, GM 9 1/2" drum brakes. 20230515_125831.jpg 20230530_135431.jpg 20230617_120119.jpg 20230617_120447.jpg 20230617_122248.jpg 20230617_122300.jpg 20230620_175444.jpg
  25. swade41
    swade41
    from Buffalo,NY
    2Blue2, RICH B, loudbang and 3 others like this.
  26. dana barlow
    dana barlow
    from Miami Fla.
    I'm at least part way out of my rut :D:cool: Actually got some work done on my rebuild of my old hotrod Ford -Y. I've been stall out ,on it from Dec, over a year plus ago. Starting to put stuff back together,got new cam bearings in,added lifter n cam,oil plugs,freez plus are done! Will be dropping crank in block this weekend ,add pistons an rods next week. Little at a time. :D
  27. I looked at it while I was backing out to go to work and thought "I REALLY need to get to working on it!"
    swade41, vtwhead and dana barlow like this.
  28. Stock Racer
    Stock Racer
    Harvested some brackets from a donor housing for a future 12 Bolt install in my 62 Biscayne. No action shots, my ***istant was busy and I was try to not light myself on fire IMG_5379.jpg IMG_5380.jpg
    j hansen likes this.
  29. RICH B
    RICH B
    Overflow finally showed up; made some brackets and hung it on the shroud. Filled the radiator to the top along with new tank. Fired it up and it took quite a bit longer than pre-shroud to hit 180 sitting in the driveway, took a ride and temp dropped down on highway as before, so that part is good. Drove around side streets for a bit and temp stayed ok. Pulled back in the drive and let it run and the anti-freeze finally expanded enough to dump out the overflow. Will have to check the level when it cools down to see if it worked right. Never had a recovery tank on a hot rod before so new to me.
    Need to make it black at some point.
    TrailerTrashToo, j hansen and swade41 like this.
  30. choptop40
    choptop40
    Got my O.T van inspected today....Trusty material , parts hauler , mule.....ha ha
