Art & Inspiration non automotive parts you have used on your hot rod or custom
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 13, 2023.
  1. bobbytnm
    bobbytnm
    I've often shopped the local hardware store looking for truck parts. Here's one pic.
    I used a 1 1/2' rigid electrical conduit 90 degree sweep for an upper radiator hose.
    I also used some toilet seat hinge pieces as tailgate strap anchor points, numerous sizes of steel pipe for various things, PVC pipe and fittings for overflow tank, 176130_520.jpg etc.
    Jibs, ken1949car, Just Gary and 2 others like this.
  2. OahuEli
    OahuEli
    from Hawaii
    Used half a pair of worn out wire strippers for the turn signal handle in my avatar. Some people thought I had a Klein turn signal switch.:D
    Okie Pete likes this.
  3. There is something fishy about how you did this.
    Okie Pete, jaracer and Just Gary like this.
  4. It gives your instrumental panel an Art Deco look, too.
    Okie Pete and fleetside66 like this.
  5. bobss396
    bobss396
    Very creative stuff here. I use what is around too. I needed padding between my gas tank and trunk floor. I looked around Ace Hardware, finally selected a rubber mat that is used to keep carpet from sliding. One side was sticky.
    Another was a gasket for my heater duct. Nothing was available on the Ford parts sites. I had a wheel barrow tube around, that got cut up and worked out.
  6. neilswheels
    neilswheels
    from England
  7. Used a boat dash panel to hold my gauges on the coupe i had.
  8. Ned Ludd
    Ned Ludd
    It has been suggested that these lights are boat items. I couldn't identify them otherwise. They were going to be B-pillar indicator repeaters on the Morris Minor.
    Okie Pete, brEad, WC145 and 2 others like this.
  9. Yes, I will get better photos went I get home from work.
  10. Joe Blow
    Joe Blow
    Old cabinet friction catches for plug holders.
  11. Bearing Burner
    Bearing Burner
    from W. MA
    On my mid '60s dragster made a brake handel from a lever off a horse drawn pice of farm mach
    Used s 6 volt dry cell battery to run the fuel pump.
  12. willys36
    willys36
    We used tigerwood decking for the bed in our '59 Elky. Added stainless strips intended for Advance Design Chevy pickups.
    Jibs, Okie Pete, Rolleiflex and 13 others like this.
  13. 31Apickup
    31Apickup
    Made a fuel filler door out of a cabinet side that I pulled from a s**** pile at an estate sale. Just made the coupe rear roll down window pan out of the stainless steel s****ped top from my old grill.
    0C14B0FE-6EB0-4505-B953-2E5253319658.jpeg E2258AFF-FEFB-4D60-9849-6E8BB8B1BA1B.jpeg
    Okie Pete, wraymen and natrlgas49 like this.
  14. natrlgas49
    natrlgas49
    A broken cable from an exercise bicycle, makes a good throttle cable, with SS tubing as a shield works great. IMG_1397.JPG
    Okie Pete, WC145 and Just Gary like this.
  15. CA. 280
    CA. 280
    100_1305_0065.2.jpg Overflow tank out of stainless exhaust pipe and s**** plate.
    Ready to be finish welded.
    Okie Pete, Just Gary and 31 B'ville like this.
  16. rustydusty
    rustydusty
    The dash in my T was made from an old mahogany church pew… F0BE03E4-C429-4D4F-B53B-68A9C783AF6C.jpeg
  17. Okie Pete and Just Gary like this.
  18. rustydusty
    rustydusty
    Aluminum water bottle overflow tank… BE2EBA57-DB81-47B2-A978-FB1CCF50F4B8.jpeg
    Okie Pete, WC145, chevy57dude and 3 others like this.
  19. Ned Ludd
    Ned Ludd
    I love the old "diver's helmet" taillights as made by CAV, Rotax, Lucas, etc. but they are rare, and the new ones are hellishly expensive at somewhere around USD1100 each. So I sporadically try to figure out how to replicate them. My first thought was the ball knuckles used in industrial balustrade stanchions:
    Balustrade stanchion 1.jpeg Balustrade stanchion 2.jpeg Balustrade stanchion ball.jpeg
    At least one local steel merchant sells the ball knuckles separately, and I went as far as to buy two, but on reflection thought they're a bit heavy (0.1" wall) and rather co****ly finished.
    There are other possibilities. This stainless steel curtain rod finial scales to about Ø3¼" — just about right:
    Okie Pete and WalkerMD like this.
  20. ebs121781
    ebs121781
    from Spring, TX
    I used one of those little gray plastic ammo boxes from Northern Tool for a speaker box in my Advance Design truck. I put a pair of 4" speakers in it with a wad of pillow stuffing and have it tucked up in the dash in the stock speaker location, secured by a bolt from the bottom lip of the dash.
  21. Johnny99
    Johnny99
    914 Porsche seats in the Willys, can't have the stock headrests, whack those off, nice upholstery lady does a nip and tuck and a knee pad from an old weight bench becomes a headrest. Old belts are great for door pulls, door check straps, and holding down stuff like the toolbox in my old 56. Denim pocket on the Willys door panel for stuffing time slips in to.
    DSC00992.JPG door pull 2.JPG door pull 3.JPG door check.JPG DSC01431 (1).JPG m5612.jpg
    Okie Pete, pirate, LOST ANGEL and 4 others like this.
  22. Frying pan skillet lid for an air cleaner cover
  23. Bert Kollar
    Bert Kollar
    Okie Pete, Just Gary, WC145 and 2 others like this.
  24. R A Wrench
    R A Wrench
    from Denver, Co
    No Pictures, but the rolled rear pan on my 49 F1 is made our of the old furnace body from my house. ( a 53 )I trimmed the edges to fit, one short weld down the middle and a recess for the license plate.
  25. In_The_Pink
    In_The_Pink
    Picked up this cutie for $10 yesterday, then saw the rear radiator panel was louvered... I think I lucked into a nice under-engine bellypan/shield, measuring 23"x24":
    A little straightening here and there and it should work fine with some tweaking.
    Okie Pete, -Brent-, loudbang and 4 others like this.
  26. 31 B'ville
    31 B'ville
    from SE Pa
    IMG_6194.jpeg IMG_6240.jpeg I used a piece of copper water pipe for a battery cable guide under the toeboard and a piece of aluminum tubing from a folding outdoor footstool to route the cable to the starter.
  27. jnaki
    jnaki
    Hello,
    Bluetooth in a speaker is impressive. It would have made things a lot easier in our 58 Impala. I had wired two drive in speakers to hang loose except for the original hooking mechanism(s). we hooked them up and set them on the window channels for a cool look. The speakers were nothing to write home about. But, it gave the interior some extra head turnings from those that walked by and talked to us when we were at the local drive-in restaurant parking lot.
    During the time we used those silly “reverb boxes” to the system, it was strange sitting between the two speakers. That did not last long. Novelty at best ...
    Jnaki
    Jump up many years and when I got the El Camino, there was only the stock speaker. So, I wired in the same two drive-in speakers to sit behind the seat on the floor. We no longer hung around any drive-in restaurant parking lot during those times. We just wanted a different sound and we got it. The extra sound coming from behind the seat in a small enclosed cab was not too bad. Plus, it was now, FM, not AM, so the technology broadcast was a lot better, anyway.
    But, I took those out when new 6x9 speakers, I put in a pair of custom wooden boxes for the area, took over. The drive-in speakers were sitting around our house on a small table for decoration. When, my brother visited us one summer, he wanted one of those metal drive-in speakers. He got the first one back in the late 1958 era. Mine came from the 1960-61 era. So, now, I only have one left and it is used as an office bookshelf, book end item. No wires, just a clean metal part of early So Cal history still in place.
    Okie Pete, deadbeat and WC145 like this.
  28. reyn
    reyn
    gotmark73, clem, Okie Pete and 23 others like this.
  29. KenC
    KenC
    Me Too! Way to many years ago to have a pic. Pulls I used looks kinda like early 50s Buick dash knobs. Put them on an aluminum mesh in my '52 chevy.
    There's sure a lot of ideas in this thread. I'm gonna use the header flange holder for sure.
  30. In_The_Pink
    In_The_Pink
    I was considering (still might) using these Mirro Medallion mid century spun aluminum serving trays as alternative Moon style discs, paired with a dog dish style cap. They are mocked up inside a 16" Ford donut spare in the pics, but the fit is almost perfect, just need to figure out a secure way to mount them.
    They have just enough dish IMHO to p*** the eye test, and they are thick enough that distortion when affixing them shouldn't be a problem, either.
    Okie Pete, brEad, Rolleiflex and 4 others like this.
